[PATCH] sapi: Remove obsolete README file
Mon Nov 30 17:52:11 UTC 2020
I see it already went through ;)
On Mon, Nov 30, 2020 at 10:51 AM Gedare Bloom <gedare at rtems.org> wrote:
> ok with me.
> On Thu, Nov 26, 2020 at 3:29 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>>  cpukit/sapi/include/rtems/README | 129 -------------------------------
>>  1 file changed, 129 deletions(-)
>>  delete mode 100644 cpukit/sapi/include/rtems/README
>> diff --git a/cpukit/sapi/include/rtems/README
>> b/cpukit/sapi/include/rtems/README
>> deleted file mode 100644
>> index 1b6dd77619..0000000000
>> --- a/cpukit/sapi/include/rtems/README
>> +++ /dev/null
>> @@ -1,129 +0,0 @@
>> -Configuring a System Using the Template in confdefs.h
>> -The file confdefs.h is a Configuration Template file which can be
>> -used to greatly simplify the creation and maintenance of RTEMS
>> -Configuration Tables.  The basic concepts are:
>> -   + confdefs.h provides defaults for all configuration parameters
>> -   + applications specify only those values they wish to override
>> -   + confdefs.h can be the only file which knows the precise layout
>> -     of the RTEMS Configuration Tables.
>> -The Configuration Template setup is used by all RTEMS tests to
>> -simplify the maintenance of the tests.
>> -Here is the section from the system.h file from test tm21 from
>> -the Timing Test Suite:
>> -   /* configuration information */
>> -   #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> -   #define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
>> -   #define CONFIGURE_MAXIMUM_TASKS              102
>> -   #define CONFIGURE_MAXIMUM_TIMERS             100
>> -   #define CONFIGURE_MAXIMUM_SEMAPHORES         100
>> -   #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES     100
>> -   #define CONFIGURE_MAXIMUM_PARTITIONS         100
>> -   #define CONFIGURE_MAXIMUM_REGIONS            100
>> -   #define CONFIGURE_MAXIMUM_PORTS              100
>> -   #define CONFIGURE_MAXIMUM_PERIODS            100
>> -   #define CONFIGURE_TICKS_PER_TIMESLICE        0
>> -   #include <confdefs.h>
>> -The above example overrides a number of the configuration parameters.
>> -It informs the template that it is a member of the Timing Suite,
>> -requires a console and timer driver, and that it needs 102 tasks,
>> -100 timers, 100 semaphores, 100 message queues, 100 partitions,
>> -100 regions, 100 ports, and 100 periods.   By default, the test
>> -would have gotten no drivers, 10 tasks, and no other RTEMS objects.
>> -The following shows the configuration tables generated by the
>> -template by default.
>> -#include <bsp.h>
>> -#define NULL_DRIVER_TABLE_ENTRY \
>> - { NULL, NULL, NULL, NULL, NULL, NULL }
>> -rtems_driver_address_table Device_drivers[] = {
>> -#ifdef CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> -  CONSOLE_DRIVER_TABLE_ENTRY,
>> -#endif
>> -#ifdef CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> -  CLOCK_DRIVER_TABLE_ENTRY,
>> -#endif
>> -#ifdef CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
>> -  STUB_DRIVER_TABLE_ENTRY,
>> -#endif
>> -  NULL_DRIVER_TABLE_ENTRY,
>> -rtems_initialization_tasks_table Initialization_tasks[] = {
>> -  { rtems_build_name( 'U', 'I', '1', ' ' ), /* init task name */
>> -    RTEMS_MINIMUM_STACK_SIZE,               /* init task stack size */
>> -    1,                                      /* init task priority */
>> -    RTEMS_DEFAULT_ATTRIBUTES,               /* init task attributes */
>> -    Init,                                   /* init task entry point */
>> -    RTEMS_NO_PREEMPT,                       /* init task initial mode */
>> -    0                                       /* init task argument list */
>> -#ifdef CONFIGURE_MP_APPLICATION
>> - *  NODE_NUMBER is assumed to be set on the compile line.
>> -rtems_multiprocessing_table Multiprocessing_configuration = {
>> -  NODE_NUMBER,                           /* local node number */
>> -  2,                                     /* maximum # nodes in system */
>> -  32,                                    /* maximum # global objects */
>> -  32,                                    /* maximum # proxies */
>> -  &MPCI_table                            /* pointer to MPCI config table
>> -#endif
>> - *  CONFIGURE_EXECUTIVE_RAM_SIZE is a rough guess based on the number of
>> - *  tasks in the system plus enough extra to get a whole 64K extra.
>> - *  The NULL address for the workspace area is assumed to be assigned
>> - *  at startup time by the BSP.
>> -rtems_configuration_table Configuration = {
>> -  NULL,                      /* executive RAM work area */
>> -  CONFIGURE_EXECUTIVE_RAM_SIZE, /* executive RAM size */
>> -  10,                        /* maximum # tasks */
>> -  0,                         /* maximum # timers */
>> -  0,                         /* maximum # semaphores */
>> -  0,                         /* maximum # message queues */
>> -  0,                         /* maximum # messages */
>> -  0,                         /* maximum # partitions */
>> -  0,                         /* maximum # regions */
>> -  0,                         /* maximum # dp memory areas */
>> -  0,                         /* maximum # periods */
>> -  0,                         /* maximum # user extensions */
>> -  RTEMS_MILLISECONDS_TO_MICROSECONDS(10), /* # us in a tick */
>> -  50,                        /* # ticks in a timeslice */
>> -  sizeof (Initialization_tasks) /
>> sizeof(rtems_initialization_tasks_table),
>> -                             /* number of init tasks */
>> -  Initialization_tasks,      /* init task(s) table */
>> -  sizeof (Device_drivers) / sizeof(rtems_driver_address_table),
>> -                             /* number of device drivers */
>> -  Device_drivers,            /* pointer to driver address table */
>> -  NULL,                      /* pointer to initial extensions */
>> -  &Multiprocessing_configuration
>> -#else
>> -  NULL                       /* ptr to MP config table */
>> -#endif
>> 2.26.2
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201130/8c105b33/attachment-0001.html>
