rtems waf, examples, and RTEMS_POSIX_API
Sebastian Huber
Mon Nov 30 19:02:56 UTC 2020
On 30/11/2020 20:00, Joel Sherrill wrote:
> > Similarly, RTEMS_POSIX_API should probably always be set and
> another
> > macro provided for POSIX signals.
> > The meaning changed without considering the impact. We need to
> account
> > for this.
> If RTEMS_POSIX_API is defined, then all POSIX APIs supported by RTEMS
> are enabled. If you always define it, then this is no longer true.
> It is now not defined. It's meaning has been perverted a sinus confusing.
If you use --enable-posix it is defined. Also if you use
"RTEMS_POSIX_API = True" in the config.ini of the new build system it is
defined.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.hubere at embedded-brains.de
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
