rtems waf, examples, and RTEMS_POSIX_API
Sebastian Huber
Mon Nov 30 19:06:10 UTC 2020
On 30/11/2020 20:00, Joel Sherrill wrote:
> Applications can use something like:
> #if __RTEMS_MAJOR__ >= 5
> POSIX threads are always enabled ...
> #endif
> This is a change to our public API that was completely unnecessary.
> We do not require changes to application code when it can be avoided.
If you enable the POSIX API, then you don't have to change anything in
your application. You can use now more of the POSIX API without having
to enable it explicitly. It is up to you if you want to rely on this or not.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.hubere at embedded-brains.de
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
