[PATCH rtems-docs] shell: Document i2c and spi commands.
Gedare Bloom
gedare at rtems.org
Mon Nov 30 23:07:43 UTC 2020
On Mon, Nov 30, 2020 at 12:14 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Gedare,
> thanks for the review.
> On 30/11/2020 18:43, Gedare Bloom wrote:
> > On Mon, Nov 30, 2020 at 7:14 AM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > shell/general_commands.rst | 200
> > 1 file changed, 200 insertions(+)
> > diff --git a/shell/general_commands.rst b/shell/general_commands.rst
> > index c74ae45..a6f7e18 100644
> > --- a/shell/general_commands.rst
> > +++ b/shell/general_commands.rst
> > @@ -44,6 +44,14 @@ The RTEMS shell has the following general
> commands:
> > - rtc_ - RTC driver configuration
> > +- i2cdetect_ - detect I2C devices
> > +- i2cget_ - get data from an EEPROM like I2C device
> > +- i2cset_ - write data to an EEPROM like I2C device
> > +- spi_ - read and write simple data to an SPI bus
> > - exit_ - alias for logoff command
> > Commands
> > @@ -1179,6 +1187,198 @@ CONFIGURATION:
> > \clearpage
> > +.. _i2cdetect:
> > +i2cdetect - detect I2C devices
> > +.. index:: i2cdetect
> > +SYNOPSYS:
> > + .. code-block:: shell
> > + i2cdetect <I2C_BUS>
> > +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CDETECT
> > +.. index:: CONFIGURE_SHELL_COMMAND_I2CDETECT
> > +DESCRIPTION:
> > + Tries to detect I2C devices connected to the I2C bus. To do
> > that, write
> > + requests with the length of 0 are used.
> > + WARNING: This might confuse some I2C devices, so please use it
> > only if you
> > + know what you are doing.
> > What happens for devices that don't know how to respond? is it any kind
> > of undefined behavior?
> That depends on the devices. Basically everything can happen. For example:
> - device is just not detected
> - I2C bus hangs
> - some random undefined behavior
> The command uses the same method that is used by the Linux i2cdetect
> command and therefore I added a similar warning:
> https://linux.die.net/man/8/i2cdetect
> > + The command supports a ``-h`` option to get usage details.
> > + The command works only with I2C bus drivers that use the
> > Linux-Style API.
> > +EXAMPLES:
> > + The following is an example where two I2C devices are detected.
> > One on 0x1a
> > + and one on 0x1f:
> > + SHLL [/] # i2cdetect /dev/i2c1
> > + x0 x1 x2 x3 x4 x5 x6 x7 x8 x9 xA xB xC xD xE xF
> > + 0x -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + 1x -- -- -- -- -- -- -- -- -- -- 1a -- -- -- -- 1f
> > + 2x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + 3x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + 4x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + 5x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + 6x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + 7x -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> > + SHLL [/] #
> > +CONFIGURATION:
> > + This command is included in the default shell command set.
> > When building a
> > If this is unsafe to use when you don't know what you're doing, then
> > maybe it should not be available without explicitly turning it on?
> > (Safe Defaults)
> I can do that if you want. It's more or less a diagnostic command (just
> like the others here). But note that we have a lot of "unsafe if you
> don't know what you are doing" commands. Like dd, mkrfs, mmove, fdisk,
> and even exit can crash some systems ...
> Aren't nearly all shell commands at least a bit unsafe? And we don't
> have a lot of commands that have to be explicitly turned on if
> CONFIGURE_SHELL_COMMANDS_ALL is already set. I found only networking
> commands.
> That seems accurate, you can go ahead with the approach you took then. It
seems to be mostly consistent with the state of practice.
> > + custom command set, define
> > ``CONFIGURE_SHELL_COMMAND_I2CDETECT`` to have
> > + this command included.
> > + This command can be excluded from the shell command set by
> defining
> > + ``CONFIGURE_SHELL_NO_COMMAND_I2CDETECT`` when all shell
> > commands have been
> > + configured.
> > +.. raw:: latex
> > + \clearpage
> > +.. _i2cget:
> > +i2cget - get data from an EEPROM like I2C device
> > +.. index:: i2cget
> > +SYNOPSYS:
> > + i2cget <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> [<NR-BYTES>]
> > +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CGET
> > +.. index:: CONFIGURE_SHELL_COMMAND_I2CGET
> > +DESCRIPTION:
> > + Get one or multiple bytes from an EEPROM like I2C device. If
> > you read
> > + multiple bytes (<NR-BYTES> given and > 1) the read will be done
> > in one
> > Default is 1 byte? Please clarify
> OK.
> > + single request. An auto incrementing register pointer is
> assumed.
> > Linux-Style API.
> > Would it make more sense to include all these under an
> > CONFIGURE_SHELL_COMMAND_I2CLINUX or something?
> I'm quite indifferent regarding that. If you prefer it, I can collect them.
> Beneath CONFIGURE_SHELL_COMMANDS_ALL and
> CONFIGURE_SHELL_COMMANDS_ALL_NETWORKING there don't seem to be a lot of
> groups. So I didn't start a new one ...
> ok, let's not make it more complex than needed. I guess the main advantage
would be code size.
> > I don't use the shell though so take everything I say with a bit of
> > skepticism.
> I'll wait for some more feedback.
> > +EXAMPLES:
> > + The following is an example how to read a one byte register at
> > 0xd from the
> > + I2C device at 0x1f:
> > + SHLL [/] # i2cget /dev/i2c1 0x1f 0x0d
> > Again, my shell ignorance: do the addresses need to be specified as Hex
> > in 0x format?
> I wrote the commands in a way that they should accept hex (0x10),
> decimal (16) or octal (020). I can add this as a comment.
> > + 0xc7
> > + SHLL [/] #
> > +CONFIGURATION:
> > When building a
> > + custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CGET``
> > to have this
> > + command included.
> defining
> > + ``CONFIGURE_SHELL_NO_COMMAND_I2CGET`` when all shell commands
> > have been
> > + configured.
> > +.. raw:: latex
> > + \clearpage
> > +.. _i2cset:
> > +i2cset - write data to an EEPROM like I2C device
> > +.. index:: i2cset
> > +SYNOPSYS:
> > + i2cset <I2C_BUS> <CHIP-ADDRESS> <DATA-ADDRESS> <VALUE>
> > [<VALUE> [...]]
> > +.. index:: CONFIGURE_SHELL_NO_COMMAND_I2CSET
> > +.. index:: CONFIGURE_SHELL_COMMAND_I2CSET
> > +DESCRIPTION:
> > + Write one or multiple bytes to an EEPROM like I2C device. If
> > you write
> > + multiple bytes (multiple <VALUE> given) the write will be done
> > in one single
> > Same for the values, do they need to be in 0x format, or is there
> > already documentation of what formats are accepted?
> No there is no other documentation. Maybe I should add a bit. Do you
> think it would be better to add it here or to the "-h" output?
> I think here is good.
> > + request. An auto incrementing register pointer is assumed.
> > Linux-Style API.
> > +EXAMPLES:
> > + The following is an example how to write one byte of 0x00 to
> > the register at
> > + 0x11 of the I2C device at 0x1f:
> > + SHLL [/] # i2cset /dev/i2c1 0x1f 0x11 0x00
> > + SHLL [/] #
> > +CONFIGURATION:
> > When building a
> > + custom command set, define ``CONFIGURE_SHELL_COMMAND_I2CSET``
> > to have this
> > + command included.
> defining
> > + ``CONFIGURE_SHELL_NO_COMMAND_I2CSET`` when all shell commands
> > have been
> > + configured.
> > +.. raw:: latex
> > + \clearpage
> > +.. _spi:
> > +spi - read and write simple data to an SPI bus
> > +.. index:: spi
> > +SYNOPSYS:
> > + spi [-loh] [-c <cs>] [-s <speed>] [-m <mode>] <SPI_BUS> xx
> > [xx [..]]
> > +.. index:: CONFIGURE_SHELL_NO_COMMAND_SPI
> > +.. index:: CONFIGURE_SHELL_COMMAND_SPI
> > +DESCRIPTION:
> > + Write data to an SPI bus and read the responses.
> > + The command works only with SPI bus drivers that use the
> > Linux-Style API.
> > +EXAMPLES:
> > + The following is an example how to write multiple bytes (0x42
> > 0x43 0x44) to
> > + the bus. The response is three times 0x00 in this case because
> > the bus has
> > + been left open. Chip select 1 will be used.
> > + SHLL [/] # spi /dev/spi1 -c 1 42 0x43 44
> > + received: 00 00 00
> > + SHLL [/] #
> > Provide an example to read?
> Maybe I should have added some values other than 0x00 to the received
> line. SPI can only do both at once (at least for the normal drivers).
> > Why not unify the i2c command the same way as spi? Just curious if there
> > is some rationale.
> Rationale is that I used Linux I2C tools as a rough guide for the
> syntax. For SPI I didn't have a template.
> Beneath that I2C does have explicit read or write modes. So I would have
> to set the direction with a parameter if I unified them. SPI on the
> other hand does always receive and transmit at the same time. So it
> wouldn't be useful to split it up.
I see, nevermind about the unification question then. Thanks, just clear up
some of the default behavior and go ahead.
> Best regards
> Christian
> > +CONFIGURATION:
> > When building a
> > + custom command set, define ``CONFIGURE_SHELL_COMMAND_SPI`` to
> > have this
> > + command included.
> defining
> > + ``CONFIGURE_SHELL_NO_COMMAND_SPI`` when all shell commands have
> > been
> > + configured.
> > +.. raw:: latex
> > + \clearpage
> > .. _exit:
> > exit - exit the shell
> > 2.26.2
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> > <http://lists.rtems.org/mailman/listinfo/devel>
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201130/040e4cfa/attachment-0001.html>
