[PATCH 0/1] c-user: Generate I/O Manager documentation
Chris Johns
chrisj at rtems.org
Thu Oct 1 04:19:00 UTC 2020
On 30/9/20 6:04 pm, Sebastian Huber wrote:
> On 29/09/2020 16:59, Sebastian Huber wrote:
>> This is the first generated documentation of a manager. For the PDF
>> output please have a look at:
>> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
>> Please review the layout. I changed the layout to use definition lists
>> instead of tables. The benefit of definition lists is that the layout
>> of longer text paragraphs is much nicer compared to tables (at least for
>> the PDF output).
>> Sebastian Huber (1):
>> c-user/io/directives.rst | 550 ++++++++++++++++++-------------------
>> c-user/io/introduction.rst | 37 ++-
>> 2 files changed, 295 insertions(+), 292 deletions(-)
> The vertical spacing of the definition lists was a bit odd.
Sorry, I commented in my other post then saw this. Please ignore my vertical
spacing comments there.
> In the Latex
> enumitem package documentation there is a note that nested definition lists with
> the "nextline" style are not supported.
OK.
> I changed the formatting to use the .. rubric directive.
Does this change what we need to install to build a PDF?
> Please have a look at this PDF:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user-2.pdf
> Only the IO Manager and Event Manager chapters use the new formatting.
The vertical spacing is much better but the headings are currently bold and that
has gone. I am not sure that is a major issue.
