[PATCH 0/1] c-user: Generate I/O Manager documentation
Sebastian Huber
Thu Oct 1 04:51:09 UTC 2020
On 01/10/2020 06:19, Chris Johns wrote:
> On 30/9/20 6:04 pm, Sebastian Huber wrote:
>> On 29/09/2020 16:59, Sebastian Huber wrote:
>>> This is the first generated documentation of a manager. For the PDF
>>> output please have a look at:
>>> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
>>> Please review the layout. I changed the layout to use definition lists
>>> instead of tables. The benefit of definition lists is that the layout
>>> of longer text paragraphs is much nicer compared to tables (at least for
>>> the PDF output).
>>> Sebastian Huber (1):
>>> c-user/io/directives.rst | 550 ++++++++++++++++++-------------------
>>> c-user/io/introduction.rst | 37 ++-
>>> 2 files changed, 295 insertions(+), 292 deletions(-)
>> The vertical spacing of the definition lists was a bit odd.
> Sorry, I commented in my other post then saw this. Please ignore my vertical
> spacing comments there.
>> In the Latex
>> enumitem package documentation there is a note that nested definition lists with
>> the "nextline" style are not supported.
> OK.
>> I changed the formatting to use the .. rubric directive.
> Does this change what we need to install to build a PDF?
No, the rubric directive is a standard Sphinx feature:
https://www.sphinx-doc.org/en/master/usage/restructuredtext/directives.html#directive-rubric
"This directive creates a paragraph heading that is not used to create a
table of contents node."
I think this matches quite well with our use case here.
>> Please have a look at this PDF:
>> https://ftp.rtems.org/pub/rtems/people/sebh/c-user-2.pdf
>> Only the IO Manager and Event Manager chapters use the new formatting.
> The vertical spacing is much better but the headings are currently bold and that
> has gone. I am not sure that is a major issue.
If we keep the rubric directive, then I think this should be fixed by a
style definition if possible.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
