[PATCH] Entangle the C Program Heap initialization
Thu Oct 1 15:07:37 UTC 2020
This looks ok to me. I suppose eliminating the dependency requires the
function pointer indirection. The only thing I don't see is why
redefinition of the _Workspace_Malloc_initializer is allowed in both
wkspacemallocinitdefault.c and in confdefs/wkspace.h. I would think
that will cause an error for multiple definitions.
On Wed, Sep 30, 2020 at 5:03 AM Sebastian Huber
> Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
> _Workspace_Area.  Introduce _Workspace_Malloc_initializer to have this
> dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
> application configuration.
>  cpukit/Makefile.am                          |  3 +
>  cpukit/include/rtems/confdefs/wkspace.h     |  3 +
>  cpukit/include/rtems/malloc.h               |  2 +-
>  cpukit/include/rtems/score/wkspacedata.h    | 26 +++++++
>  cpukit/libcsupport/src/malloc_initialize.c  | 78 +++++++++------------
>  cpukit/libcsupport/src/mallocheap.c         | 56 +++++++++++++++
>  cpukit/score/src/wkspacemallocinitdefault.c | 44 ++++++++++++
>  cpukit/score/src/wkspacemallocinitunified.c | 47 +++++++++++++
>  spec/build/cpukit/librtemscpu.yml           |  3 +
>  9 files changed, 217 insertions(+), 45 deletions(-)
>  create mode 100644 cpukit/libcsupport/src/mallocheap.c
>  create mode 100644 cpukit/score/src/wkspacemallocinitdefault.c
>  create mode 100644 cpukit/score/src/wkspacemallocinitunified.c
> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> index 2c35354e66..1f9124e175 100644
> --- a/cpukit/Makefile.am
> +++ b/cpukit/Makefile.am
> @@ -176,6 +176,7 @@ librtemscpu_a_SOURCES += libcsupport/src/mallocdirtydefault.c
>  librtemscpu_a_SOURCES += libcsupport/src/mallocextenddefault.c
>  librtemscpu_a_SOURCES += libcsupport/src/mallocfreespace.c
>  librtemscpu_a_SOURCES += libcsupport/src/mallocgetheapptr.c
> +librtemscpu_a_SOURCES += libcsupport/src/mallocheap.c
>  librtemscpu_a_SOURCES += libcsupport/src/mallocinfo.c
>  librtemscpu_a_SOURCES += libcsupport/src/malloc_initialize.c
>  librtemscpu_a_SOURCES += libcsupport/src/_malloc_r.c
> @@ -1025,6 +1026,8 @@ librtemscpu_a_SOURCES += score/src/interr.c
>  librtemscpu_a_SOURCES += score/src/isr.c
>  librtemscpu_a_SOURCES += score/src/wkspace.c
>  librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
> +librtemscpu_a_SOURCES += score/src/wkspacemallocinitdefault.c
> +librtemscpu_a_SOURCES += score/src/wkspacemallocinitunified.c
>  librtemscpu_a_SOURCES += score/src/wkstringduplicate.c
>  librtemscpu_a_SOURCES += score/src/iobase64.c
>  librtemscpu_a_SOURCES += score/src/ioprintf.c
> diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
> index 89d7c21b2a..d40194cbec 100644
> --- a/cpukit/include/rtems/confdefs/wkspace.h
> +++ b/cpukit/include/rtems/confdefs/wkspace.h
> @@ -126,6 +126,9 @@ const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
>  #ifdef CONFIGURE_UNIFIED_WORK_AREAS
>    const bool _Workspace_Is_unified = true;
> +  struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
> +    _Workspace_Malloc_initialize_unified;
>  #endif
>  uint32_t rtems_minimum_stack_size = CONFIGURE_MINIMUM_TASK_STACK_SIZE;
> diff --git a/cpukit/include/rtems/malloc.h b/cpukit/include/rtems/malloc.h
> index 34bdbcb91e..13e94ac38a 100644
> --- a/cpukit/include/rtems/malloc.h
> +++ b/cpukit/include/rtems/malloc.h
> @@ -43,7 +43,7 @@ extern "C" {
>  extern Heap_Control *RTEMS_Malloc_Heap;
> -void RTEMS_Malloc_Initialize(
> +Heap_Control *RTEMS_Malloc_Initialize(
>    const Memory_Information              *mem,
>    Heap_Initialization_or_extend_handler  extend
> diff --git a/cpukit/include/rtems/score/wkspacedata.h b/cpukit/include/rtems/score/wkspacedata.h
> index 613a320dfe..fd6fd1c1cb 100644
> --- a/cpukit/include/rtems/score/wkspacedata.h
> +++ b/cpukit/include/rtems/score/wkspacedata.h
> @@ -43,6 +43,8 @@
>  extern "C" {
>  #endif
> +struct Heap_Control;
>   * @addtogroup RTEMSScoreWorkspace
> @@ -65,6 +67,30 @@ extern const uintptr_t _Workspace_Size;
>  extern const bool _Workspace_Is_unified;
> + * @brief Initializes the C Program Heap separated from the RTEMS Workspace.
> + * @return Returns the heap control used for the C Program Heap.
> +struct Heap_Control *_Workspace_Malloc_initialize_separate( void );
> + * @brief Initializes the C Program Heap so that it is unified with the RTEMS
> + * Workspace.
> +struct Heap_Control *_Workspace_Malloc_initialize_unified( void );
> + * @brief This constant provides the C Program Heap initialization handler.
> + * This constant is defined by the application configuration option
> + * #CONFIGURE_UNIFIED_WORK_AREAS via <rtems/confdefs.h> or a default
> + * configuration.
> +extern struct Heap_Control *( * const _Workspace_Malloc_initializer )( void );
>  #ifdef __cplusplus
> diff --git a/cpukit/libcsupport/src/malloc_initialize.c b/cpukit/libcsupport/src/malloc_initialize.c
> index 0203e22411..fb0999df01 100644
> --- a/cpukit/libcsupport/src/malloc_initialize.c
> +++ b/cpukit/libcsupport/src/malloc_initialize.c
> @@ -19,73 +19,63 @@
>  #include <rtems/malloc.h>
>  #include <rtems/score/wkspace.h>
> -#include <rtems/sysinit.h>
>  #include "malloc_p.h"
> -Heap_Control *RTEMS_Malloc_Heap;
> -static void _Malloc_Initialize( void )
> -  RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
> -RTEMS_SYSINIT_ITEM(
> -  _Malloc_Initialize,
> -  RTEMS_SYSINIT_MALLOC,
> -  RTEMS_SYSINIT_ORDER_MIDDLE
>  #ifdef RTEMS_NEWLIB
>  static Heap_Control _Malloc_Heap;
> -  if ( rtems_configuration_get_unified_work_area() ) {
> -    RTEMS_Malloc_Heap = &_Workspace_Area;
> -  } else {
> -    Heap_Control                          *heap;
> -    Heap_Initialization_or_extend_handler  init_or_extend;
> -    uintptr_t                              page_size;
> -    size_t                                 i;
> +  Heap_Control                          *heap;
> +  Heap_Initialization_or_extend_handler  init_or_extend;
> +  uintptr_t                              page_size;
> +  size_t                                 i;
> -    heap = &_Malloc_Heap;
> -    RTEMS_Malloc_Heap = heap;
> -    init_or_extend = _Heap_Initialize;
> -    page_size = CPU_HEAP_ALIGNMENT;
> +  heap = &_Malloc_Heap;
> +  RTEMS_Malloc_Heap = heap;
> +  init_or_extend = _Heap_Initialize;
> +  page_size = CPU_HEAP_ALIGNMENT;
> -    for (i = 0; i < _Memory_Get_count( mem ); ++i) {
> -      Memory_Area *area;
> -      uintptr_t    space_available;
> +  for (i = 0; i < _Memory_Get_count( mem ); ++i) {
> +    Memory_Area *area;
> +    uintptr_t    space_available;
> -      area = _Memory_Get_area( mem, i );
> -      space_available = ( *init_or_extend )(
> -        heap,
> -        _Memory_Get_free_begin( area ),
> -        _Memory_Get_free_size( area ),
> -        page_size
> +    area = _Memory_Get_area( mem, i );
> +    space_available = ( *init_or_extend )(
> +      heap,
> +      _Memory_Get_free_begin( area ),
> +      _Memory_Get_free_size( area ),
> +      page_size
> -      if ( space_available > 0 ) {
> -        _Memory_Consume( area, _Memory_Get_free_size( area ) );
> -        init_or_extend = extend;
> +    if ( space_available > 0 ) {
> +      _Memory_Consume( area, _Memory_Get_free_size( area ) );
> +      init_or_extend = extend;
> -    if ( init_or_extend == _Heap_Initialize ) {
> -      _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
> +  if ( init_or_extend == _Heap_Initialize ) {
> +    _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
> +  return heap;
>  #else
>    /* FIXME: Dummy function */
> +  return NULL;
>  #endif
> +Heap_Control *_Workspace_Malloc_initialize_separate( void )
> +  return RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
> diff --git a/cpukit/libcsupport/src/mallocheap.c b/cpukit/libcsupport/src/mallocheap.c
> new file mode 100644
> index 0000000000..006362f209
> --- /dev/null
> +++ b/cpukit/libcsupport/src/mallocheap.c
> @@ -0,0 +1,56 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup MallocSupport
> + * @brief This source file provides the C Program Heap control along with the
> + *   system initialization handler.
> + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/malloc.h>
> +#include <rtems/sysinit.h>
> +#include <rtems/score/wkspacedata.h>
> +Heap_Control *RTEMS_Malloc_Heap;
> +static void _Malloc_Initialize( void )
> +  RTEMS_Malloc_Heap = ( *_Workspace_Malloc_initializer )();
> +RTEMS_SYSINIT_ITEM(
> +  _Malloc_Initialize,
> +  RTEMS_SYSINIT_MALLOC,
> +  RTEMS_SYSINIT_ORDER_MIDDLE
> diff --git a/cpukit/score/src/wkspacemallocinitdefault.c b/cpukit/score/src/wkspacemallocinitdefault.c
> index 0000000000..586c3eef7c
> --- /dev/null
> +++ b/cpukit/score/src/wkspacemallocinitdefault.c
> @@ -0,0 +1,44 @@
> + * @file
> + * @ingroup RTEMSScoreWorkspace
> + * @brief This source file provides the default definition of
> + * _Workspace_Malloc_initializer.
> + * are met:
> +#endif
> +struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
> +  _Workspace_Malloc_initialize_separate;
> diff --git a/cpukit/score/src/wkspacemallocinitunified.c b/cpukit/score/src/wkspacemallocinitunified.c
> index 0000000000..d90956c051
> --- /dev/null
> +++ b/cpukit/score/src/wkspacemallocinitunified.c
> @@ -0,0 +1,47 @@
> + * @file
> + * @brief This source file provides the implementation of
> + *   _Workspace_Malloc_initialize_unified().
> + * are met:
> +#endif
> +#include <rtems/score/wkspace.h>
> +  return &_Workspace_Area;
> diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
> index 21dc239b1b..2322e33996 100644
> --- a/spec/build/cpukit/librtemscpu.yml
> +++ b/spec/build/cpukit/librtemscpu.yml
> @@ -669,6 +669,7 @@ source:
>  - cpukit/libcsupport/src/mallocextenddefault.c
>  - cpukit/libcsupport/src/mallocfreespace.c
>  - cpukit/libcsupport/src/mallocgetheapptr.c
> +- cpukit/libcsupport/src/mallocheap.c
>  - cpukit/libcsupport/src/mallocinfo.c
>  - cpukit/libcsupport/src/malloc_initialize.c
>  - cpukit/libcsupport/src/_malloc_r.c
> @@ -1575,6 +1576,8 @@ source:
>  - cpukit/score/src/watchdogtimeslicedefault.c
>  - cpukit/score/src/wkspace.c
>  - cpukit/score/src/wkspaceisunifieddefault.c
> +- cpukit/score/src/wkspacemallocinitdefault.c
> +- cpukit/score/src/wkspacemallocinitunified.c
>  - cpukit/score/src/wkstringduplicate.c
>  target: rtemscpu
>  type: build
> 2.26.2
> devel mailing list
> devel at rtems.org
