[PATCH] Entangle the C Program Heap initialization
Thu Oct 1 15:44:44 UTC 2020
On Thu, Oct 1, 2020 at 10:07 AM Gedare Bloom <gedare at rtems.org> wrote:
> This looks ok to me. I suppose eliminating the dependency requires the
> function pointer indirection. The only thing I don't see is why
> redefinition of the _Workspace_Malloc_initializer is allowed in both
> wkspacemallocinitdefault.c and in confdefs/wkspace.h. I would think
> that will cause an error for multiple definitions.
I think Entangle is the wrong work. Disentangle or possibly decouple.
Does minimum actually reflect what you think is the smallest possible
configuration now? That as always the test's purpose -- to have a single
executable that was the smallest we thought we could produce. It seems
with all your changes that it needs a review for tweaks to the
configuration.
--joel
--joel
> On Wed, Sep 30, 2020 at 5:03 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
> > _Workspace_Area.  Introduce _Workspace_Malloc_initializer to have this
> > dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
> > application configuration.
> >  cpukit/Makefile.am                          |  3 +
> >  cpukit/include/rtems/confdefs/wkspace.h     |  3 +
> >  cpukit/include/rtems/malloc.h               |  2 +-
> >  cpukit/include/rtems/score/wkspacedata.h    | 26 +++++++
> >  cpukit/libcsupport/src/malloc_initialize.c  | 78 +++++++++------------
> >  cpukit/libcsupport/src/mallocheap.c         | 56 +++++++++++++++
> >  cpukit/score/src/wkspacemallocinitdefault.c | 44 ++++++++++++
> >  cpukit/score/src/wkspacemallocinitunified.c | 47 +++++++++++++
> >  spec/build/cpukit/librtemscpu.yml           |  3 +
> >  9 files changed, 217 insertions(+), 45 deletions(-)
> >  create mode 100644 cpukit/libcsupport/src/mallocheap.c
> >  create mode 100644 cpukit/score/src/wkspacemallocinitdefault.c
> >  create mode 100644 cpukit/score/src/wkspacemallocinitunified.c
> > diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> > index 2c35354e66..1f9124e175 100644
> > --- a/cpukit/Makefile.am
> > +++ b/cpukit/Makefile.am
> > @@ -176,6 +176,7 @@ librtemscpu_a_SOURCES +=
> libcsupport/src/mallocdirtydefault.c
> >  librtemscpu_a_SOURCES += libcsupport/src/mallocextenddefault.c
> >  librtemscpu_a_SOURCES += libcsupport/src/mallocfreespace.c
> >  librtemscpu_a_SOURCES += libcsupport/src/mallocgetheapptr.c
> > +librtemscpu_a_SOURCES += libcsupport/src/mallocheap.c
> >  librtemscpu_a_SOURCES += libcsupport/src/mallocinfo.c
> >  librtemscpu_a_SOURCES += libcsupport/src/malloc_initialize.c
> >  librtemscpu_a_SOURCES += libcsupport/src/_malloc_r.c
> > @@ -1025,6 +1026,8 @@ librtemscpu_a_SOURCES += score/src/interr.c
> >  librtemscpu_a_SOURCES += score/src/isr.c
> >  librtemscpu_a_SOURCES += score/src/wkspace.c
> >  librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
> > +librtemscpu_a_SOURCES += score/src/wkspacemallocinitdefault.c
> > +librtemscpu_a_SOURCES += score/src/wkspacemallocinitunified.c
> >  librtemscpu_a_SOURCES += score/src/wkstringduplicate.c
> >  librtemscpu_a_SOURCES += score/src/iobase64.c
> >  librtemscpu_a_SOURCES += score/src/ioprintf.c
> > diff --git a/cpukit/include/rtems/confdefs/wkspace.h
> b/cpukit/include/rtems/confdefs/wkspace.h
> > index 89d7c21b2a..d40194cbec 100644
> > --- a/cpukit/include/rtems/confdefs/wkspace.h
> > +++ b/cpukit/include/rtems/confdefs/wkspace.h
> > @@ -126,6 +126,9 @@ const uintptr_t _Workspace_Size =
> CONFIGURE_EXECUTIVE_RAM_SIZE;
> >  #ifdef CONFIGURE_UNIFIED_WORK_AREAS
> >    const bool _Workspace_Is_unified = true;
> > +  struct Heap_Control *( * const _Workspace_Malloc_initializer )( void
> > +    _Workspace_Malloc_initialize_unified;
> >  #endif
> >  uint32_t rtems_minimum_stack_size = CONFIGURE_MINIMUM_TASK_STACK_SIZE;
> > diff --git a/cpukit/include/rtems/malloc.h
> b/cpukit/include/rtems/malloc.h
> > index 34bdbcb91e..13e94ac38a 100644
> > --- a/cpukit/include/rtems/malloc.h
> > +++ b/cpukit/include/rtems/malloc.h
> > @@ -43,7 +43,7 @@ extern "C" {
> >  extern Heap_Control *RTEMS_Malloc_Heap;
> > -void RTEMS_Malloc_Initialize(
> > +Heap_Control *RTEMS_Malloc_Initialize(
> >    const Memory_Information              *mem,
> >    Heap_Initialization_or_extend_handler  extend
> > diff --git a/cpukit/include/rtems/score/wkspacedata.h
> b/cpukit/include/rtems/score/wkspacedata.h
> > index 613a320dfe..fd6fd1c1cb 100644
> > --- a/cpukit/include/rtems/score/wkspacedata.h
> > +++ b/cpukit/include/rtems/score/wkspacedata.h
> > @@ -43,6 +43,8 @@
> >  extern "C" {
> >  #endif
> > +struct Heap_Control;
> >   * @addtogroup RTEMSScoreWorkspace
> > @@ -65,6 +67,30 @@ extern const uintptr_t _Workspace_Size;
> >  extern const bool _Workspace_Is_unified;
> > + * @brief Initializes the C Program Heap separated from the RTEMS
> Workspace.
> > + * @return Returns the heap control used for the C Program Heap.
> > +struct Heap_Control *_Workspace_Malloc_initialize_separate( void );
> > + * @brief Initializes the C Program Heap so that it is unified with the
> RTEMS
> > + * Workspace.
> > +struct Heap_Control *_Workspace_Malloc_initialize_unified( void );
> > + * @brief This constant provides the C Program Heap initialization
> handler.
> > + * This constant is defined by the application configuration option
> > + * #CONFIGURE_UNIFIED_WORK_AREAS via <rtems/confdefs.h> or a default
> > + * configuration.
> > +extern struct Heap_Control *( * const _Workspace_Malloc_initializer )(
> void );
> >  #ifdef __cplusplus
> > diff --git a/cpukit/libcsupport/src/malloc_initialize.c
> b/cpukit/libcsupport/src/malloc_initialize.c
> > index 0203e22411..fb0999df01 100644
> > --- a/cpukit/libcsupport/src/malloc_initialize.c
> > +++ b/cpukit/libcsupport/src/malloc_initialize.c
> > @@ -19,73 +19,63 @@
> >  #include <rtems/malloc.h>
> >  #include <rtems/score/wkspace.h>
> > -#include <rtems/sysinit.h>
> >  #include "malloc_p.h"
> > -Heap_Control *RTEMS_Malloc_Heap;
> > -static void _Malloc_Initialize( void )
> > -  RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
> > -RTEMS_SYSINIT_ITEM(
> > -  _Malloc_Initialize,
> > -  RTEMS_SYSINIT_MALLOC,
> > -  RTEMS_SYSINIT_ORDER_MIDDLE
> >  #ifdef RTEMS_NEWLIB
> >  static Heap_Control _Malloc_Heap;
> > -  if ( rtems_configuration_get_unified_work_area() ) {
> > -    RTEMS_Malloc_Heap = &_Workspace_Area;
> > -  } else {
> > -    Heap_Control                          *heap;
> > -    Heap_Initialization_or_extend_handler  init_or_extend;
> > -    uintptr_t                              page_size;
> > -    size_t                                 i;
> > +  Heap_Control                          *heap;
> > +  Heap_Initialization_or_extend_handler  init_or_extend;
> > +  uintptr_t                              page_size;
> > +  size_t                                 i;
> > -    heap = &_Malloc_Heap;
> > -    RTEMS_Malloc_Heap = heap;
> > -    init_or_extend = _Heap_Initialize;
> > -    page_size = CPU_HEAP_ALIGNMENT;
> > +  heap = &_Malloc_Heap;
> > +  RTEMS_Malloc_Heap = heap;
> > +  init_or_extend = _Heap_Initialize;
> > +  page_size = CPU_HEAP_ALIGNMENT;
> > -    for (i = 0; i < _Memory_Get_count( mem ); ++i) {
> > -      Memory_Area *area;
> > -      uintptr_t    space_available;
> > +  for (i = 0; i < _Memory_Get_count( mem ); ++i) {
> > +    Memory_Area *area;
> > +    uintptr_t    space_available;
> > -      area = _Memory_Get_area( mem, i );
> > -      space_available = ( *init_or_extend )(
> > -        heap,
> > -        _Memory_Get_free_begin( area ),
> > -        _Memory_Get_free_size( area ),
> > -        page_size
> > +    area = _Memory_Get_area( mem, i );
> > +    space_available = ( *init_or_extend )(
> > +      heap,
> > +      _Memory_Get_free_begin( area ),
> > +      _Memory_Get_free_size( area ),
> > +      page_size
> > -      if ( space_available > 0 ) {
> > -        _Memory_Consume( area, _Memory_Get_free_size( area ) );
> > -        init_or_extend = extend;
> > +    if ( space_available > 0 ) {
> > +      _Memory_Consume( area, _Memory_Get_free_size( area ) );
> > +      init_or_extend = extend;
> > -    if ( init_or_extend == _Heap_Initialize ) {
> > -      _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
> > +  if ( init_or_extend == _Heap_Initialize ) {
> > +    _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
> > +  return heap;
> >  #else
> >    /* FIXME: Dummy function */
> > +  return NULL;
> >  #endif
> > +Heap_Control *_Workspace_Malloc_initialize_separate( void )
> > +  return RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
> > diff --git a/cpukit/libcsupport/src/mallocheap.c
> b/cpukit/libcsupport/src/mallocheap.c
> > new file mode 100644
> > index 0000000000..006362f209
> > --- /dev/null
> > +++ b/cpukit/libcsupport/src/mallocheap.c
> > @@ -0,0 +1,56 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @file
> > + * @ingroup MallocSupport
> > + * @brief This source file provides the C Program Heap control along
> with the
> > + *   system initialization handler.
> > + * Copyright (C) 2020 embedded brains GmbH (
> http://www.embedded-brains.de)
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifdef HAVE_CONFIG_H
> > +#include "config.h"
> > +#endif
> > +#include <rtems/malloc.h>
> > +#include <rtems/sysinit.h>
> > +#include <rtems/score/wkspacedata.h>
> > +Heap_Control *RTEMS_Malloc_Heap;
> > +static void _Malloc_Initialize( void )
> > +  RTEMS_Malloc_Heap = ( *_Workspace_Malloc_initializer )();
> > +RTEMS_SYSINIT_ITEM(
> > +  _Malloc_Initialize,
> > +  RTEMS_SYSINIT_MALLOC,
> > +  RTEMS_SYSINIT_ORDER_MIDDLE
> > diff --git a/cpukit/score/src/wkspacemallocinitdefault.c
> b/cpukit/score/src/wkspacemallocinitdefault.c
> > index 0000000000..586c3eef7c
> > --- /dev/null
> > +++ b/cpukit/score/src/wkspacemallocinitdefault.c
> > @@ -0,0 +1,44 @@
> > + * @file
> > + * @ingroup RTEMSScoreWorkspace
> > + * @brief This source file provides the default definition of
> > + * _Workspace_Malloc_initializer.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#endif
> > +struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
> > +  _Workspace_Malloc_initialize_separate;
> > diff --git a/cpukit/score/src/wkspacemallocinitunified.c
> b/cpukit/score/src/wkspacemallocinitunified.c
> > index 0000000000..d90956c051
> > --- /dev/null
> > +++ b/cpukit/score/src/wkspacemallocinitunified.c
> > @@ -0,0 +1,47 @@
> > + * @file
> > + * @brief This source file provides the implementation of
> > + *   _Workspace_Malloc_initialize_unified().
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#endif
> > +#include <rtems/score/wkspace.h>
> > +  return &_Workspace_Area;
> > diff --git a/spec/build/cpukit/librtemscpu.yml
> b/spec/build/cpukit/librtemscpu.yml
> > index 21dc239b1b..2322e33996 100644
> > --- a/spec/build/cpukit/librtemscpu.yml
> > +++ b/spec/build/cpukit/librtemscpu.yml
> > @@ -669,6 +669,7 @@ source:
> >  - cpukit/libcsupport/src/mallocextenddefault.c
> >  - cpukit/libcsupport/src/mallocfreespace.c
> >  - cpukit/libcsupport/src/mallocgetheapptr.c
> > +- cpukit/libcsupport/src/mallocheap.c
> >  - cpukit/libcsupport/src/mallocinfo.c
> >  - cpukit/libcsupport/src/malloc_initialize.c
> >  - cpukit/libcsupport/src/_malloc_r.c
> > @@ -1575,6 +1576,8 @@ source:
> >  - cpukit/score/src/watchdogtimeslicedefault.c
> >  - cpukit/score/src/wkspace.c
> >  - cpukit/score/src/wkspaceisunifieddefault.c
> > +- cpukit/score/src/wkspacemallocinitdefault.c
> > +- cpukit/score/src/wkspacemallocinitunified.c
> >  - cpukit/score/src/wkstringduplicate.c
> >  target: rtemscpu
> >  type: build
> > 2.26.2
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201001/4e5c2eff/attachment-0001.html>
