[PATCH] Entangle the C Program Heap initialization
Thu Oct 1 15:51:21 UTC 2020
On Thu, Oct 1, 2020 at 9:45 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Oct 1, 2020 at 10:07 AM Gedare Bloom <gedare at rtems.org> wrote:
>> This looks ok to me. I suppose eliminating the dependency requires the
>> function pointer indirection. The only thing I don't see is why
>> redefinition of the _Workspace_Malloc_initializer is allowed in both
>> wkspacemallocinitdefault.c and in confdefs/wkspace.h. I would think
>> that will cause an error for multiple definitions.
> I think Entangle is the wrong work. Disentangle or possibly decouple.
> Does minimum actually reflect what you think is the smallest possible
> configuration now? That as always the test's purpose -- to have a single
> executable that was the smallest we thought we could produce. It seems
> with all your changes that it needs a review for tweaks to the configuration.
Should open a ticket to review this. Certainly after all the static
initialization/construct stuff it should be possible to go smaller.
> --joel
> --joel
>> On Wed, Sep 30, 2020 at 5:03 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
>> > _Workspace_Area.  Introduce _Workspace_Malloc_initializer to have this
>> > dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
>> > application configuration.
>> >  cpukit/Makefile.am                          |  3 +
>> >  cpukit/include/rtems/confdefs/wkspace.h     |  3 +
>> >  cpukit/include/rtems/malloc.h               |  2 +-
>> >  cpukit/include/rtems/score/wkspacedata.h    | 26 +++++++
>> >  cpukit/libcsupport/src/malloc_initialize.c  | 78 +++++++++------------
>> >  cpukit/libcsupport/src/mallocheap.c         | 56 +++++++++++++++
>> >  cpukit/score/src/wkspacemallocinitdefault.c | 44 ++++++++++++
>> >  cpukit/score/src/wkspacemallocinitunified.c | 47 +++++++++++++
>> >  spec/build/cpukit/librtemscpu.yml           |  3 +
>> >  9 files changed, 217 insertions(+), 45 deletions(-)
>> >  create mode 100644 cpukit/libcsupport/src/mallocheap.c
>> >  create mode 100644 cpukit/score/src/wkspacemallocinitdefault.c
>> >  create mode 100644 cpukit/score/src/wkspacemallocinitunified.c
>> > diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
>> > index 2c35354e66..1f9124e175 100644
>> > --- a/cpukit/Makefile.am
>> > +++ b/cpukit/Makefile.am
>> > @@ -176,6 +176,7 @@ librtemscpu_a_SOURCES += libcsupport/src/mallocdirtydefault.c
>> >  librtemscpu_a_SOURCES += libcsupport/src/mallocextenddefault.c
>> >  librtemscpu_a_SOURCES += libcsupport/src/mallocfreespace.c
>> >  librtemscpu_a_SOURCES += libcsupport/src/mallocgetheapptr.c
>> > +librtemscpu_a_SOURCES += libcsupport/src/mallocheap.c
>> >  librtemscpu_a_SOURCES += libcsupport/src/mallocinfo.c
>> >  librtemscpu_a_SOURCES += libcsupport/src/malloc_initialize.c
>> >  librtemscpu_a_SOURCES += libcsupport/src/_malloc_r.c
>> > @@ -1025,6 +1026,8 @@ librtemscpu_a_SOURCES += score/src/interr.c
>> >  librtemscpu_a_SOURCES += score/src/isr.c
>> >  librtemscpu_a_SOURCES += score/src/wkspace.c
>> >  librtemscpu_a_SOURCES += score/src/wkspaceisunifieddefault.c
>> > +librtemscpu_a_SOURCES += score/src/wkspacemallocinitdefault.c
>> > +librtemscpu_a_SOURCES += score/src/wkspacemallocinitunified.c
>> >  librtemscpu_a_SOURCES += score/src/wkstringduplicate.c
>> >  librtemscpu_a_SOURCES += score/src/iobase64.c
>> >  librtemscpu_a_SOURCES += score/src/ioprintf.c
>> > diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
>> > index 89d7c21b2a..d40194cbec 100644
>> > --- a/cpukit/include/rtems/confdefs/wkspace.h
>> > +++ b/cpukit/include/rtems/confdefs/wkspace.h
>> > @@ -126,6 +126,9 @@ const uintptr_t _Workspace_Size = CONFIGURE_EXECUTIVE_RAM_SIZE;
>> >  #ifdef CONFIGURE_UNIFIED_WORK_AREAS
>> >    const bool _Workspace_Is_unified = true;
>> > +  struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
>> > +    _Workspace_Malloc_initialize_unified;
>> >  #endif
>> >  uint32_t rtems_minimum_stack_size = CONFIGURE_MINIMUM_TASK_STACK_SIZE;
>> > diff --git a/cpukit/include/rtems/malloc.h b/cpukit/include/rtems/malloc.h
>> > index 34bdbcb91e..13e94ac38a 100644
>> > --- a/cpukit/include/rtems/malloc.h
>> > +++ b/cpukit/include/rtems/malloc.h
>> > @@ -43,7 +43,7 @@ extern "C" {
>> >  extern Heap_Control *RTEMS_Malloc_Heap;
>> > -void RTEMS_Malloc_Initialize(
>> > +Heap_Control *RTEMS_Malloc_Initialize(
>> >    const Memory_Information              *mem,
>> >    Heap_Initialization_or_extend_handler  extend
>> > diff --git a/cpukit/include/rtems/score/wkspacedata.h b/cpukit/include/rtems/score/wkspacedata.h
>> > index 613a320dfe..fd6fd1c1cb 100644
>> > --- a/cpukit/include/rtems/score/wkspacedata.h
>> > +++ b/cpukit/include/rtems/score/wkspacedata.h
>> > @@ -43,6 +43,8 @@
>> >  extern "C" {
>> >  #endif
>> > +struct Heap_Control;
>> >   * @addtogroup RTEMSScoreWorkspace
>> > @@ -65,6 +67,30 @@ extern const uintptr_t _Workspace_Size;
>> >  extern const bool _Workspace_Is_unified;
>> > + * @brief Initializes the C Program Heap separated from the RTEMS Workspace.
>> > + * @return Returns the heap control used for the C Program Heap.
>> > +struct Heap_Control *_Workspace_Malloc_initialize_separate( void );
>> > + * @brief Initializes the C Program Heap so that it is unified with the RTEMS
>> > + * Workspace.
>> > +struct Heap_Control *_Workspace_Malloc_initialize_unified( void );
>> > + * @brief This constant provides the C Program Heap initialization handler.
>> > + * This constant is defined by the application configuration option
>> > + * #CONFIGURE_UNIFIED_WORK_AREAS via <rtems/confdefs.h> or a default
>> > + * configuration.
>> > +extern struct Heap_Control *( * const _Workspace_Malloc_initializer )( void );
>> >  #ifdef __cplusplus
>> > diff --git a/cpukit/libcsupport/src/malloc_initialize.c b/cpukit/libcsupport/src/malloc_initialize.c
>> > index 0203e22411..fb0999df01 100644
>> > --- a/cpukit/libcsupport/src/malloc_initialize.c
>> > +++ b/cpukit/libcsupport/src/malloc_initialize.c
>> > @@ -19,73 +19,63 @@
>> >  #include <rtems/malloc.h>
>> >  #include <rtems/score/wkspace.h>
>> > -#include <rtems/sysinit.h>
>> >  #include "malloc_p.h"
>> > -Heap_Control *RTEMS_Malloc_Heap;
>> > -static void _Malloc_Initialize( void )
>> > -  RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
>> > -RTEMS_SYSINIT_ITEM(
>> > -  _Malloc_Initialize,
>> > -  RTEMS_SYSINIT_MALLOC,
>> > -  RTEMS_SYSINIT_ORDER_MIDDLE
>> >  #ifdef RTEMS_NEWLIB
>> >  static Heap_Control _Malloc_Heap;
>> > -  if ( rtems_configuration_get_unified_work_area() ) {
>> > -    RTEMS_Malloc_Heap = &_Workspace_Area;
>> > -  } else {
>> > -    Heap_Control                          *heap;
>> > -    Heap_Initialization_or_extend_handler  init_or_extend;
>> > -    uintptr_t                              page_size;
>> > -    size_t                                 i;
>> > +  Heap_Control                          *heap;
>> > +  Heap_Initialization_or_extend_handler  init_or_extend;
>> > +  uintptr_t                              page_size;
>> > +  size_t                                 i;
>> > -    heap = &_Malloc_Heap;
>> > -    RTEMS_Malloc_Heap = heap;
>> > -    init_or_extend = _Heap_Initialize;
>> > -    page_size = CPU_HEAP_ALIGNMENT;
>> > +  heap = &_Malloc_Heap;
>> > +  RTEMS_Malloc_Heap = heap;
>> > +  init_or_extend = _Heap_Initialize;
>> > +  page_size = CPU_HEAP_ALIGNMENT;
>> > -    for (i = 0; i < _Memory_Get_count( mem ); ++i) {
>> > -      Memory_Area *area;
>> > -      uintptr_t    space_available;
>> > +  for (i = 0; i < _Memory_Get_count( mem ); ++i) {
>> > +    Memory_Area *area;
>> > +    uintptr_t    space_available;
>> > -      area = _Memory_Get_area( mem, i );
>> > -      space_available = ( *init_or_extend )(
>> > -        heap,
>> > -        _Memory_Get_free_begin( area ),
>> > -        _Memory_Get_free_size( area ),
>> > -        page_size
>> > +    area = _Memory_Get_area( mem, i );
>> > +    space_available = ( *init_or_extend )(
>> > +      heap,
>> > +      _Memory_Get_free_begin( area ),
>> > +      _Memory_Get_free_size( area ),
>> > +      page_size
>> > -      if ( space_available > 0 ) {
>> > -        _Memory_Consume( area, _Memory_Get_free_size( area ) );
>> > -        init_or_extend = extend;
>> > +    if ( space_available > 0 ) {
>> > +      _Memory_Consume( area, _Memory_Get_free_size( area ) );
>> > +      init_or_extend = extend;
>> > -    if ( init_or_extend == _Heap_Initialize ) {
>> > -      _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
>> > +  if ( init_or_extend == _Heap_Initialize ) {
>> > +    _Internal_error( INTERNAL_ERROR_NO_MEMORY_FOR_HEAP );
>> > +  return heap;
>> >  #else
>> >    /* FIXME: Dummy function */
>> > +  return NULL;
>> >  #endif
>> > +Heap_Control *_Workspace_Malloc_initialize_separate( void )
>> > +  return RTEMS_Malloc_Initialize( _Memory_Get(), _Heap_Extend );
>> > diff --git a/cpukit/libcsupport/src/mallocheap.c b/cpukit/libcsupport/src/mallocheap.c
>> > new file mode 100644
>> > index 0000000000..006362f209
>> > --- /dev/null
>> > +++ b/cpukit/libcsupport/src/mallocheap.c
>> > @@ -0,0 +1,56 @@
>> > +/* SPDX-License-Identifier: BSD-2-Clause */
>> > + * @file
>> > + * @ingroup MallocSupport
>> > + * @brief This source file provides the C Program Heap control along with the
>> > + *   system initialization handler.
>> > + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
>> > + * Redistribution and use in source and binary forms, with or without
>> > + * modification, are permitted provided that the following conditions
>> > + * are met:
>> > + * 1. Redistributions of source code must retain the above copyright
>> > + *    notice, this list of conditions and the following disclaimer.
>> > + * 2. Redistributions in binary form must reproduce the above copyright
>> > + *    notice, this list of conditions and the following disclaimer in the
>> > + *    documentation and/or other materials provided with the distribution.
>> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> > + * POSSIBILITY OF SUCH DAMAGE.
>> > +#ifdef HAVE_CONFIG_H
>> > +#include "config.h"
>> > +#endif
>> > +#include <rtems/malloc.h>
>> > +#include <rtems/sysinit.h>
>> > +#include <rtems/score/wkspacedata.h>
>> > +Heap_Control *RTEMS_Malloc_Heap;
>> > +static void _Malloc_Initialize( void )
>> > +  RTEMS_Malloc_Heap = ( *_Workspace_Malloc_initializer )();
>> > +RTEMS_SYSINIT_ITEM(
>> > +  _Malloc_Initialize,
>> > +  RTEMS_SYSINIT_MALLOC,
>> > +  RTEMS_SYSINIT_ORDER_MIDDLE
>> > diff --git a/cpukit/score/src/wkspacemallocinitdefault.c b/cpukit/score/src/wkspacemallocinitdefault.c
>> > index 0000000000..586c3eef7c
>> > --- /dev/null
>> > +++ b/cpukit/score/src/wkspacemallocinitdefault.c
>> > @@ -0,0 +1,44 @@
>> > + * @file
>> > + * @ingroup RTEMSScoreWorkspace
>> > + * @brief This source file provides the default definition of
>> > + * _Workspace_Malloc_initializer.
>> > + * are met:
>> > +#endif
>> > +struct Heap_Control *( * const _Workspace_Malloc_initializer )( void ) =
>> > +  _Workspace_Malloc_initialize_separate;
>> > diff --git a/cpukit/score/src/wkspacemallocinitunified.c b/cpukit/score/src/wkspacemallocinitunified.c
>> > index 0000000000..d90956c051
>> > --- /dev/null
>> > +++ b/cpukit/score/src/wkspacemallocinitunified.c
>> > @@ -0,0 +1,47 @@
>> > + * @file
>> > + * @brief This source file provides the implementation of
>> > + *   _Workspace_Malloc_initialize_unified().
>> > + * are met:
>> > +#endif
>> > +#include <rtems/score/wkspace.h>
>> > +  return &_Workspace_Area;
>> > diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
>> > index 21dc239b1b..2322e33996 100644
>> > --- a/spec/build/cpukit/librtemscpu.yml
>> > +++ b/spec/build/cpukit/librtemscpu.yml
>> > @@ -669,6 +669,7 @@ source:
>> >  - cpukit/libcsupport/src/mallocextenddefault.c
>> >  - cpukit/libcsupport/src/mallocfreespace.c
>> >  - cpukit/libcsupport/src/mallocgetheapptr.c
>> > +- cpukit/libcsupport/src/mallocheap.c
>> >  - cpukit/libcsupport/src/mallocinfo.c
>> >  - cpukit/libcsupport/src/malloc_initialize.c
>> >  - cpukit/libcsupport/src/_malloc_r.c
>> > @@ -1575,6 +1576,8 @@ source:
>> >  - cpukit/score/src/watchdogtimeslicedefault.c
>> >  - cpukit/score/src/wkspace.c
>> >  - cpukit/score/src/wkspaceisunifieddefault.c
>> > +- cpukit/score/src/wkspacemallocinitdefault.c
>> > +- cpukit/score/src/wkspacemallocinitunified.c
>> >  - cpukit/score/src/wkstringduplicate.c
>> >  target: rtemscpu
>> >  type: build
>> > 2.26.2
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
