[PATCH 0/1] c-user: Generate I/O Manager documentation
Fri Oct 2 06:00:07 UTC 2020
On 02/10/2020 01:29, Chris Johns wrote:
> On 2/10/20 2:32 am, Joel Sherrill wrote:
>> On Thu, Oct 1, 2020 at 10:53 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
>> wrote:
>>      This one has calling sequence, parameters, description:
>>      https://ftp.rtems.org/pub/rtems/people/sebh/c-user-4.pdf
>> This is preferable. We should try to follow the POSIX ordering.
> This looks OK.
>> It looks like the ordering of the methods has changed. It was generally
>> very carefully chosen. Why would close be the first service listed?
>> The order generally reflects the usage -- open before close, create
>> before delete. etc.
>> The order shouldn't change.
> Yes I agree but I suspect the order will need to stored somewhere.
I can add a hand crafted order to the specification. I was just a bit
easier to sort alphabetically.
