[PATCH 0/1] c-user: Generate I/O Manager documentation
Fri Oct 2 11:09:16 UTC 2020
On 29/09/2020 16:59, Sebastian Huber wrote:
> This is the first generated documentation of a manager. For the PDF
> output please have a look at:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
> Please review the layout.  I changed the layout to use definition lists
> instead of tables.  The benefit of definition lists is that the layout
> of longer text paragraphs is much nicer compared to tables (at least for
> the PDF output).
A new layout variant is available. This one has the description followed
by the notes after the calling sequence:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user-5.pdf
It also has the IO Manager directives in the order present in the
current manual.
