[PATCH v4] cpukit/librcxx: Add a C++ thread interface with attributes
chrisj at rtems.org chrisj at rtems.org
Sat Oct 3 06:23:07 UTC 2020
 cpukit/include/rtems/c++/error            |  65 +++
 cpukit/include/rtems/c++/thread           | 469 ++++++++++++++++++++++
 cpukit/librtemscxx/error.cc               |  76 ++++
 cpukit/librtemscxx/thread.cc              | 416 +++++++++++++++++++
 spec/build/cpukit/grp.yml                 |   2 +
 spec/build/cpukit/librtemscxx.yml         |  21 +
 spec/build/testsuites/libtests/grp.yml    |   2 +
 spec/build/testsuites/libtests/rcxx01.yml |  22 +
 testsuites/libtests/rcxx01/init.c         |  69 ++++
 testsuites/libtests/rcxx01/rcxx01.doc     |  16 +
 testsuites/libtests/rcxx01/rcxx01.scn     |  13 +
 testsuites/libtests/rcxx01/thread.cc      |  90 +++++
 12 files changed, 1261 insertions(+)
 create mode 100644 cpukit/include/rtems/c++/error
 create mode 100644 cpukit/include/rtems/c++/thread
 create mode 100644 cpukit/librtemscxx/error.cc
 create mode 100644 cpukit/librtemscxx/thread.cc
 create mode 100644 spec/build/cpukit/librtemscxx.yml
 create mode 100644 spec/build/testsuites/libtests/rcxx01.yml
 create mode 100644 testsuites/libtests/rcxx01/init.c
 create mode 100644 testsuites/libtests/rcxx01/rcxx01.doc
 create mode 100644 testsuites/libtests/rcxx01/rcxx01.scn
 create mode 100644 testsuites/libtests/rcxx01/thread.cc
diff --git a/cpukit/include/rtems/c++/error b/cpukit/include/rtems/c++/error
new file mode 100644
index 0000000000..8b9d875e0f
--- /dev/null
+++ b/cpukit/include/rtems/c++/error
@@ -0,0 +1,65 @@
+/* -*- C++ -*-
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Chris Johns (http://contemporary.software)
+ * are met:
+ * @file
+ * @ingroup RTEMSC++
+ * RTEMS Error exception.
+#if !defined(RTEMS_CXX_ERROR)
+#define RTEMS_CXX_ERROR
+#include <stdexcept>
+#include <string>
+#include <rtems.h>
+namespace rtems
+  class runtime_error :
+    public std::runtime_error
+    const rtems_status_code sc;
+  public:
+    runtime_error (const rtems_status_code sc);
+    runtime_error (const rtems_status_code sc, const std::string& what);
+    runtime_error (const rtems_status_code sc, const char* what);
+    ~runtime_error ();
+   * Throw a rtems::runtime_error exception if the RTEMS status code is
+   * not RTEMS_SUCCESSFUL.
+  void runtime_error_check (const rtems_status_code sc);
+  void runtime_error_check (const rtems_status_code sc, const std::string& what);
+  void runtime_error_check (const rtems_status_code sc, const char* what);
+#endif
diff --git a/cpukit/include/rtems/c++/thread b/cpukit/include/rtems/c++/thread
index 0000000000..c3f18ab3cf
--- /dev/null
+++ b/cpukit/include/rtems/c++/thread
@@ -0,0 +1,469 @@
+/* -*- C++ -*-
+ * are met:
+ * @file
+ * The C++ standard thread support with thread attribute control.
+ * The code requires the `-std=c++17` option to access `std::invoke()`.
+#if !defined(RTEMS_CXX_THREAD)
+#define RTEMS_CXX_THREAD
+#include <functional>
+#include <iostream>
+#include <string>
+#include <thread>
+#include <utility>
+namespace rtems
+  namespace thread
+     * @brief Manage the attributes of a thread.
+    class attributes
+    public:
+       * The schedular modes.
+      enum sched_mode {
+        sched_inherit,    /**< Inhert the scheduler */
+        sched_explicit    /**< Explicitly set the scheduler */
+       * The schedular policies.
+      enum sched_policy {
+        sched_other,      /**< Other scheduler policy */
+        sched_fifo,       /**< FIFO scheduler policy */
+        sched_roundrobin, /**< Roundrobin scheduler policy */
+        sched_sporadic    /**< Sporadic scheduler policy */
+       * Construct a thread attributes object with the current settings of the
+       * executing thread. The stack size is set to the configured minimum
+       * stack size.
+      attributes ();
+       * Copy construct the thread attributes.
+       * @param attr The attributes to copy.
+      attributes (const attributes& attr);
+       * Set the name of the thread. The thread is a classic API thread and
+       * the name is only 4 characters.
+       * @param name The name as a string.
+      void set_name (const std::string& name);
+      void set_name (const char* name);
+       * Get the name of the thread.
+       * @retval const std::string& The name of the thread.
+      const std::string& get_name () const;
+       * Set the priority of the thread.
+       * @param priority The POSIX API priority of the thread.
+      void set_priority (int priority);
+       * Get the POSIX API priority of the thread.
+       * @retval int The POSIX API thread priority.
+      int get_priority () const;
+       * Set the stack size. If the size is less than the configured minimum
+       * the minimum value is used.
+       * @param size The stack size in bytes.
+      void set_stack_size (size_t size);
+       * Get the stack size.
+       * @retval size_t The stack size in bytes.
+      size_t get_stack_size () const;
+       * Set the scheduler name. If not set no scheduler is set.
+       * @parrm scheduler The name of the scheduler.
+      void set_scheduler (const std::string& scheduler);
+      void set_scheduler (const char* scheduler);
+       * Get scheduler name.
+      const std::string& get_scheduler ();
+       * Get the attrobutes' scheduler mode for the thread.
+       * @return sched_mode The attributes; scheduler mode
+      sched_mode get_scheduler_mode () const;
+       * Set the scheduler policy for the thread. This call sets the
+       * schedular mode to @ref sched_explicit.
+       * @param policy The scheduler policy.
+      void set_scheduler_policy (sched_policy policyr);
+       * Get the scheduler policy for the thread.
+      sched_policy get_scheduler_policy () const;
+       * Commit any changes to the executing thread. @note only the priority
+       * and modes of a thread can be changed. The name and stack size are
+       * ignored.
+      void commit ();
+       * Update the attribute values from the executing thread. The attributes
+       * are updated from the current thread when constructed and the values
+       * returned are those held since then. If another thread changes the
+       * attributes of the current thread those changes will not be seen until
+       * this method is called. Except for the name and stack size any local
+       * changes made will lost then the update call is made.
+      void update ();
+       * Copy operator.
+      attributes& operator= (const attributes& attr);
+       * The comparision operator does not check the name or stack size
+       * of a thread.
+      bool operator== (const attributes& attr) const;
+    private:
+      std::string  name;        /**< Name of the thread */
+      int          priority;    /**< POSIX API priority */
+      size_t       stack_size;  /**< Stack size in bytes */
+      std::string  scheduler;   /**< Name of the scheduler */
+      sched_mode   mode;        /**< Scheduler's mode */
+      sched_policy policy;      /**< Scheduler's policy */
+      /* affinity, cpu set size is? */
+     * @brief Create a thread with thread attributes.
+     * Create a thread optionally with thread attributes. The usage of this
+     * class follows the C++ standard for std::thread. The standard support
+     * for creating a thread does not let you control the attributes of a
+     * thread and control is important in embedded real-time
+     * applications. This class lets you control a thread attributes and use
+     * the extensive an excellent thread support the C++ standard provides.
+     * There is no indication attribute support for threads will be added to
+     * the C++ standard and what it will look like. The support provided here
+     * is designed to make as little impact on a code base as possible. While
+     * the attributes supported are specific to RTEMS they are common to all
+     * embedded operating systems.
+     * The support provided here is specific to GCC due to the use of some
+     * non-standard interfaces to get the indices of the template argument
+     * pack in new thread's context. A standards only solution would be
+     * preferred.
+    class thread
+      friend void* thread_generic_entry (void* arg);
+       * Base state class to interface to derived template of the thread
+       * state from the generic entry point for the thread.
+      struct state_base
+        virtual ~state_base ();
+        virtual const attributes get_attributes () = 0;
+        virtual void run () = 0;
+       * The state is passed to the new thread context as a unique
+       * pointer. This handles the hand over and clean up.
+      using state_ptr = std::unique_ptr<state_base>;
+    public:
+       * Template check to see if the first argument of a thread is a set of
+       * attributes.
+      template <typename A, class DecayA = typename std::decay<A>::type>
+      using enable_if_attributes = typename std::enable_if
+        <std::is_same<DecayA, attributes>::value>::type;
+       * We need our own id type so the thread class can access the pthread
+       * handle to initialise it.
+      class id {
+      public:
+        id () noexcept : id_ (0) { }
+        explicit id (pthread_t id_) : id_ (id_) { }
+      private:
+        pthread_t id_;
+        friend class thread;
+        friend bool operator== (thread::id l, thread::id r) noexcept;
+        template<class CharT, class Traits>
+	friend std::basic_ostream<CharT, Traits>&
+	operator<< (std::basic_ostream<CharT, Traits>& out, thread::id id_);
+       * The default thread constructions.
+      thread () noexcept = default;
+       * The std::thread equivilant constructor. The attributes will be the
+       * same as the executing thread with a default thread name and the
+       * configured minimum stack size.
+      template<typename F, typename... Args>
+      explicit thread (F&& func, Args&&... args);
+       * Create a thread with the provided attributes. The entry point and
+       * optional arguments are the same as std::thread.
+      template <typename A, typename F, typename ...Args,
+                class = enable_if_attributes<A>>
+      explicit thread (A&& attr, F&& func, Args&&... args);
+       * Move the thread id to this instance.
+      thread& operator= (thread&& thread_);
+      void swap(thread& thread_) noexcept;
+      bool joinable() const noexcept;
+       * Constrain use. These are not available.
+      thread (thread&) = delete;
+      thread (const thread&) = delete;
+      thread (const thread&&) = delete;
+      thread& operator= (const thread&) = delete;
+      std::thread::id get_id() const noexcept;
+    private:
+      id id_;
+       * Invoke the thread's entry point with the parameter pack in the new
+       * thread's context. This object holds the parameters copied onto the
+       * new thread's stack making them available to entry point routine.
+      template<typename Parms>
+      struct invoker {
+        Parms p;
+        template<size_t Index>
+        static std::__tuple_element_t<Index, Parms>&& declval ();
+        template<size_t... Ind>
+        auto invoke (std::_Index_tuple<Ind...>)
+          noexcept (noexcept (std::invoke (declval<Ind>()...)))
+          -> decltype (std::invoke (declval<Ind> ()...)) {
+          return std::invoke (std::get<Ind> (std::move (p))...);
+        using indices =
+          typename std::_Build_index_tuple<std::tuple_size<Parms>::value>::__type;
+        void run () {
+          invoke (indices ());
+       * The state holds the invoker with the parameters. The generic entry
+       * point calls the virtual methods to get the attributes and to run the
+       * new thread in the new thread's context..
+      template<typename Invoker>
+      struct state : state_base {
+        const attributes attr;
+        Invoker          i;
+        state (const attributes& attr, Invoker&& i)
+          : attr (attr),
+            i (std::forward<Invoker> (i)) {
+        const attributes get_attributes () override {
+          return attr;
+        void run () override {
+          i.run ();
+       * Make the state. This dynamic memory is managed by the unique pointer
+       * and is passed to the generic thread entry point.
+      static state_ptr
+      make_state (const attributes& attr, Invoker&& i) {
+        using state_impl = state<Invoker>;
+        return state_ptr{ new state_impl (attr, std::forward<Invoker> (i)) };
+       * Decay the parameters so they can be correctly packed into the
+       * parameter tuple.
+      template<typename... T>
+      using decayed_tuple = std::tuple<typename std::decay<T>::type...>;
+       * Make the invoker with the parameters.
+      static invoker<decayed_tuple<F, Args...>>
+      make_invoker (F&& func, Args&&... args)
+        return {
+          decayed_tuple<F, Args...> {
+            std::forward<F> (func), std::forward<Args> (args)...
+       * Create and start the thread.
+      void start_thread (state_ptr s);
+    template <class T>
+    inline typename std::decay<T>::type
+    decay_copy (T&& t) {
+      return std::forward<T> (t);
+    thread::thread (F&& func, Args&&... args)
+      : id_ (0)  {
+      attributes attr;
+      start_thread (
+        make_state (attr,
+                    make_invoker (decay_copy (std::forward<F> (func)),
+                                  decay_copy (std::forward<Args> (args))...))
+    template<typename A, typename F, typename... Args,
+             class = thread::enable_if_attributes<A>>
+    thread::thread (A&& attr, F&& func, Args&&... args)
+      : id_ (0) {
+      start_thread (
+        make_state (attr,
+    inline std::thread::id thread::get_id() const noexcept {
+      return std::thread::id (id_.id_);
+    inline bool
+    operator== (thread::id l, thread::id r) noexcept {
+      return l.id_ == r.id_;
+    inline bool
+    operator!= (thread::id l, thread::id r) noexcept {
+      return !(l == r);
+    template<class C, class T>
+    inline std::basic_ostream<C, T>&
+    operator<< (std::basic_ostream<C, T>& out, thread::id id_) {
+      return out << std::thread::id (id_.id_);
+#endif
diff --git a/cpukit/librtemscxx/error.cc b/cpukit/librtemscxx/error.cc
index 0000000000..c7b749803f
--- /dev/null
+++ b/cpukit/librtemscxx/error.cc
@@ -0,0 +1,76 @@
+ * are met:
+#include <rtems/c++/error>
+namespace rtems
+  runtime_error::runtime_error (const rtems_status_code sc)
+    : std::runtime_error (::rtems_status_text (sc)),
+      sc (sc)
+  runtime_error::runtime_error (const rtems_status_code sc,
+                                const std::string&      what)
+    : std::runtime_error (what + ": " + ::rtems_status_text (sc)),
+      sc (sc)
+                                const char*             what)
+    : std::runtime_error (std::string (what) + ": " + ::rtems_status_text (sc)),
+      sc (sc)
+  runtime_error::~runtime_error()
+  void
+  runtime_error_check (const rtems_status_code sc)
+    if (sc != RTEMS_SUCCESSFUL)
+      throw runtime_error (sc);
+  void
+  runtime_error_check (const rtems_status_code sc, const std::string& what)
+      throw runtime_error (sc, what);
+  void
+  runtime_error_check (const rtems_status_code sc, const char* what)
diff --git a/cpukit/librtemscxx/thread.cc b/cpukit/librtemscxx/thread.cc
index 0000000000..79375a713c
--- /dev/null
+++ b/cpukit/librtemscxx/thread.cc
@@ -0,0 +1,416 @@
+ * are met:
+#if !defined(_GNU_SOURCE)
+#define _GNU_SOURCE
+#endif
+#include <system_error>
+#include <rtems/c++/thread>
+#include <pthread.h>
+#include <rtems.h>
+#if HAVE_GET_SCHEDULER_NAME
+extern "C" bool get_scheduler_name (rtems_id sid, char* name);
+#endif
+bool get_scheduler_name (rtems_id sid, char* name)
+  name[0] = 'N';
+  name[1] = 'O';
+  name[2] = 'P';
+  name[3] = '\0';
+  return true;
+#endif
+namespace rtems
+  namespace thread
+    void
+    system_error_check (int ec, const char* what)
+      if (ec != 0)
+        throw std::system_error (ec, std::system_category(), what);
+    attributes::attributes ()
+      : priority (-1),
+        stack_size (RTEMS_MINIMUM_STACK_SIZE),
+        mode (sched_inherit),
+        policy (sched_fifo)
+      update ();
+    attributes::attributes (const attributes& attr)
+      : name (attr.name),
+        priority (attr.priority),
+        stack_size (attr.stack_size),
+        scheduler (attr.scheduler),
+        mode (attr.mode),
+        policy (attr.policy)
+    void
+    attributes::set_name (const std::string& name_)
+      name = name_;
+    void
+    attributes::set_name (const char* name_)
+      name = name_;
+    attributes::get_name () const
+      return name;
+    void
+    attributes::set_priority (int priority_)
+      priority = priority_;
+    int
+    attributes::get_priority () const
+      return priority;
+    void
+    attributes::set_stack_size(size_t size)
+      stack_size = size;
+    size_t
+    attributes::get_stack_size () const
+      return stack_size;
+    void
+    attributes::set_scheduler (const std::string& scheduler_)
+      scheduler = scheduler_;
+    void
+    attributes::set_scheduler (const char* scheduler_)
+    attributes::get_scheduler ()
+      return scheduler;
+    attributes::sched_mode
+    attributes::get_scheduler_mode () const
+      return mode;
+    void
+    attributes::set_scheduler_policy (sched_policy policy_)
+      mode = sched_explicit;
+      policy = policy_;
+    attributes::sched_policy
+    attributes::get_scheduler_policy () const
+      return policy;
+    void
+    attributes::commit ()
+      pthread_t pid = ::pthread_self ();
+      system_error_check (::pthread_setname_np (pid, name.c_str ()),
+                          "getting name");
+      int                spolicy;
+      struct sched_param sched_param;
+      system_error_check (::pthread_getschedparam (::pthread_self (),
+                                                   &spolicy,
+                                                   &sched_param),
+                          "getting scheduler parameters");
+      switch (policy) {
+      case sched_other:
+        spolicy = SCHED_OTHER;
+        break;
+      case sched_fifo:
+        spolicy = SCHED_FIFO;
+        break;
+      case sched_roundrobin:
+        spolicy = SCHED_RR;
+        break;
+      case sched_sporadic:
+        spolicy = SCHED_SPORADIC;
+        break;
+      default:
+        system_error_check (EINVAL, "get scheduler policy");
+        break;
+      sched_param.sched_priority = priority;
+      system_error_check (::pthread_setschedparam (::pthread_self (),
+                                                   spolicy,
+                                                   &sched_param),
+      if (!scheduler.empty ()) {
+        char sname[4] = { ' ', ' ', ' ', ' ' };
+        for (size_t c = 0; c < sizeof (sname); ++c) {
+          if (c >= scheduler.length ())
+            break;
+          sname[c] = scheduler[c];
+        rtems_name scheduler_name = rtems_build_name (sname[0],
+                                                      sname[1],
+                                                      sname[2],
+                                                      sname[3]);
+        rtems_id scheduler_id;
+        runtime_error_check (::rtems_scheduler_ident (scheduler_name,
+                                                      &scheduler_id),
+                             "get scheduler id");
+        // runtime_error_check (::rtems_task_set_scheduler (RTEMS_SELF,
+        //                                                  scheduler_id,
+        //                                                  1),
+        //                      "set scheduler id");
+    void
+    attributes::update ()
+      char buf[32];
+      system_error_check (::pthread_getname_np (::pthread_self (),
+                                                buf,
+                                                sizeof (buf)),
+                          "getting name");
+      name = buf;
+      int                spolicy;
+                                                   &spolicy,
+                                                   &sched_param),
+      switch (spolicy) {
+      case SCHED_OTHER:
+        policy = sched_other;
+        break;
+      case SCHED_FIFO:
+        policy = sched_fifo;
+        break;
+      case SCHED_RR:
+        policy = sched_roundrobin;
+        break;
+      case SCHED_SPORADIC:
+        policy = sched_sporadic;
+        break;
+      default:
+        break;
+      priority = sched_param.sched_priority;
+      pthread_attr_t attr;
+      system_error_check (::pthread_getattr_np (::pthread_self (), &attr),
+                          "getting thread attributes");
+      system_error_check (::pthread_attr_getstacksize (&attr, &stack_size),
+                          "getting stack size");
+      int inheritsched = 0;
+      system_error_check (::pthread_attr_getinheritsched (&attr, &inheritsched),
+                          "getting inherited sheduler mode");
+      switch (inheritsched) {
+      case PTHREAD_INHERIT_SCHED:
+        mode = sched_inherit;
+        break;
+      case PTHREAD_EXPLICIT_SCHED:
+        break;
+      default:
+        system_error_check (EINVAL, "get scheduler mode");
+        break;
+      runtime_error_check (::rtems_task_get_scheduler (RTEMS_SELF, &scheduler_id));
+      char name[5];
+      if (!get_scheduler_name (scheduler_id, &name[0]))
+        system_error_check (ENOENT, "get scheduler name");
+      scheduler = name;
+#endif
+    attributes&
+    attributes::operator= (const attributes& attr)
+      name = attr.name;
+      priority = attr.priority;
+      stack_size = attr.stack_size;
+      mode = attr.mode;
+      policy = attr.policy;
+      return *this;
+    bool
+    attributes::operator== (const attributes& attr) const
+      return
+        name == attr.name &&
+        priority == attr.priority &&
+        stack_size == attr.stack_size &&
+        mode == attr.mode &&
+        policy == attr.policy;
+    void*
+    thread_generic_entry (void* arg)
+      thread::state_ptr s{ static_cast<thread::state_base*> (arg) };
+      try {
+        s->run ();
+      } catch (...) {
+        std::terminate ();
+      return nullptr;
+    thread&
+    thread::operator= (thread&& thread_)
+      if (joinable ())
+      swap(thread_);
+      return *this;
+    void
+    thread::swap(thread& thread_) noexcept
+      std::swap(id_, thread_.id_);
+    bool
+    thread::joinable() const noexcept
+      return !(id_ == id());
+    thread::state_base::~state_base () = default;
+    void
+    thread::start_thread (thread::state_ptr s)
+      const attributes attr = s->get_attributes ();
+      pthread_attr_t pattr;
+      system_error_check (::pthread_attr_init (&pattr),
+                          "attribute init");
+      system_error_check (::pthread_attr_setdetachstate (&pattr,
+                                                         PTHREAD_CREATE_DETACHED),
+                          "set detached state");
+      struct sched_param param;
+      param.sched_priority = attr.get_priority ();
+      system_error_check (::pthread_attr_setschedparam (&pattr, &param),
+                          "set ");
+      int spolicy;
+      switch (attr.get_scheduler_policy ()) {
+      case attributes::sched_other:
+        break;
+      case attributes::sched_roundrobin:
+        break;
+      case attributes::sched_sporadic:
+        break;
+      default:
+        break;
+      system_error_check (::pthread_attr_setschedpolicy (&pattr, spolicy),
+                          "set scheduler policy");
+      if (attr.get_scheduler_mode () == attributes::sched_inherit)
+        ::pthread_attr_setinheritsched (&pattr, PTHREAD_INHERIT_SCHED);
+      else
+        ::pthread_attr_setinheritsched (&pattr, PTHREAD_EXPLICIT_SCHED);
+      system_error_check (::pthread_attr_setstacksize(&pattr,
+                                                      attr.get_stack_size ()),
+                          "set stack size");
+       * Hold the new thread in the state's run handler until the rest
+       * of the thread is set up after the create call.
+      system_error_check (::pthread_create (&id_.id_,
+                                            &pattr,
+                                            thread_generic_entry,
+                                            s.get ()),
+                          "create thread");
+      system_error_check (::pthread_setname_np (id_.id_,
+                                                attr.get_name ().c_str ()),
+                          "setting thread name");
+      ::pthread_attr_destroy (&pattr);
+      s.release ();
diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
index 3a285d03fc..91fa2d9625 100644
--- a/spec/build/cpukit/grp.yml
+++ b/spec/build/cpukit/grp.yml
@@ -27,6 +27,8 @@ links:
   uid: libpppd
 - role: build-dependency
   uid: librtemscpu
+- role: build-dependency
+  uid: librtemscxx
   uid: librtemsdfltcfg
diff --git a/spec/build/cpukit/librtemscxx.yml b/spec/build/cpukit/librtemscxx.yml
index 0000000000..769e5a7498
--- /dev/null
+++ b/spec/build/cpukit/librtemscxx.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: library
+cflags: []
+copyrights:
+- Copyright (C) 2020 Chris Johns (http://contemporary.software)
+cppflags: []
+cxxflags: [-std=c++17]
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - cpukit/include/rtems/c++/error
+  - cpukit/include/rtems/c++/thread
+install-path: ${BSP_LIBDIR}
+links: []
+source:
+- cpukit/librtemscxx/error.cc
+- cpukit/librtemscxx/thread.cc
+target: rtemscxx
+type: build
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index 2b1f2727cf..b9ca014b0d 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -214,6 +214,8 @@ links:
   uid: pwdgrp02
   uid: rbheap01
+  uid: rcxx01
   uid: read
diff --git a/spec/build/testsuites/libtests/rcxx01.yml b/spec/build/testsuites/libtests/rcxx01.yml
index 0000000000..6d69feeb83
--- /dev/null
+++ b/spec/build/testsuites/libtests/rcxx01.yml
@@ -0,0 +1,22 @@
+build-type: test-program
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+features: c cxx cxxprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/rcxx01/init.c
+- testsuites/libtests/rcxx01/thread.cc
+stlib: []
+target: testsuites/libtests/rcxx01.exe
+type: build
+use-after: []
+use-before:
+- rtemsdefaultconfig
+- rtemscxx
diff --git a/testsuites/libtests/rcxx01/init.c b/testsuites/libtests/rcxx01/init.c
index 0000000000..b3dfa9f0c1
--- /dev/null
+++ b/testsuites/libtests/rcxx01/init.c
@@ -0,0 +1,69 @@
+ * Copyright (c) 2020 Chris Johns (http://contemporary.software)
+ * All rights reserved.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <sys/ioctl.h>
+#include <unistd.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "RCXX 1";
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+void rcxx_run_test(void);
+rtems_task Init(
+  rtems_task_argument ignored
+  TEST_BEGIN();
+  rcxx_run_test();
+  TEST_END();
+  rtems_test_exit( 0 );
+/* configuration information */
+#include <rtems/serial_mouse.h>
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
+#define CONFIGURE_MEMORY_OVERHEAD           (2024)
+#define CONFIGURE_MAXIMUM_TASKS  1
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (10U * 1024U)
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#include <rtems/confdefs.h>
+/* end of file */
diff --git a/testsuites/libtests/rcxx01/rcxx01.doc b/testsuites/libtests/rcxx01/rcxx01.doc
index 0000000000..3fd41b029b
--- /dev/null
+++ b/testsuites/libtests/rcxx01/rcxx01.doc
@@ -0,0 +1,16 @@
+# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>
+This file describes the directives and concepts tested by this test set.
+test set name: rcxx01
+directives:
+  rtems::thread::thread
+  rtems::thread::attributes
+concepts:
++ Create a thread using the default method, ie like std::thread.
+* Create a thread with changed attributes.
diff --git a/testsuites/libtests/rcxx01/rcxx01.scn b/testsuites/libtests/rcxx01/rcxx01.scn
index 0000000000..37bf2d3f7a
--- /dev/null
+++ b/testsuites/libtests/rcxx01/rcxx01.scn
@@ -0,0 +1,13 @@
+*** BEGIN OF TEST RCXX 1 ***
+*** TEST VERSION: 5.0.0.7ba04a62227286dcd3da20ea7319d9c64b8f5fd1
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD:
+*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB ceb811fa19ddcfdd449a8da8f1107e6e592727b6, Newlib d14714c69)
+Thread: start: default
+ 1 D
+Thread: start: attr
+ 2 R
+Thread: end: default
+Thread: end: attr
+*** END OF TEST RCXX 1 ***
diff --git a/testsuites/libtests/rcxx01/thread.cc b/testsuites/libtests/rcxx01/thread.cc
index 0000000000..7cb64cea5a
--- /dev/null
+++ b/testsuites/libtests/rcxx01/thread.cc
@@ -0,0 +1,90 @@
+#include <chrono>
+#include <thread>
+#include <mutex>
+using namespace std::chrono_literals;
+extern "C" void rcxx_run_test(void);
+struct test_thread
+  test_thread();
+  void start();
+  bool running();
+  void body(const char* title, int i, char c);
+  rtems::thread::thread thread_default;
+  rtems::thread::thread thread_attr;
+  std::mutex mutex;
+  bool finished;
+test_thread::test_thread()
+  : finished(false)
+void test_thread::start()
+  thread_default = rtems::thread::thread(&test_thread::body, this,
+                                         "default",  1, 'D');
+  rtems::thread::attributes attr;
+  attr.set_name("RTHREAD");
+  attr.set_priority(5);
+  attr.set_stack_size(32 * 1024);
+  thread_attr = rtems::thread::thread(attr, &test_thread::body, this,
+                                      "attr", 2, 'R');
+void test_thread::body(const char* title, int i, char c)
+  std::cout << "Thread: start: " << title << std::endl
+            << ' ' << i << ' ' << c << std::endl;
+  size_t count = 5;
+  while (count--) {
+    std::this_thread::sleep_for(1s);
+  std::cout << "Thread: end: " << title << std::endl;
+  std::lock_guard<std::mutex> lock(mutex);
+  finished = true;
+bool test_thread::running()
+  return finished == false;
+  try {
+    test_thread tt;
+    tt.start();
+    while (tt.running())
+  } catch (...) {
+    std::cout << "Thread: ouch" << std::endl;
+    throw;
2.24.1
