[PATCH v4] cpukit/librcxx: Add a C++ thread interface with attributes
Joel Sherrill
joel at rtems.org
Sat Oct 3 12:21:31 UTC 2020
Will this show up in documentation somewhere?
It does seem like we should say something about C++ threads and this.
What about C11 threads?
Test doesn't appear to cover much.
More interspersed
On Sat, Oct 3, 2020, 1:23 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> cpukit/include/rtems/c++/error | 65 +++
> cpukit/include/rtems/c++/thread | 469 ++++++++++++++++++++++
> cpukit/librtemscxx/error.cc | 76 ++++
> cpukit/librtemscxx/thread.cc | 416 +++++++++++++++++++
> spec/build/cpukit/grp.yml | 2 +
> spec/build/cpukit/librtemscxx.yml | 21 +
> spec/build/testsuites/libtests/grp.yml | 2 +
> spec/build/testsuites/libtests/rcxx01.yml | 22 +
> testsuites/libtests/rcxx01/init.c | 69 ++++
> testsuites/libtests/rcxx01/rcxx01.doc | 16 +
> testsuites/libtests/rcxx01/rcxx01.scn | 13 +
> testsuites/libtests/rcxx01/thread.cc | 90 +++++
> 12 files changed, 1261 insertions(+)
> create mode 100644 cpukit/include/rtems/c++/error
> create mode 100644 cpukit/include/rtems/c++/thread
> create mode 100644 cpukit/librtemscxx/error.cc
> create mode 100644 cpukit/librtemscxx/thread.cc
> create mode 100644 spec/build/cpukit/librtemscxx.yml
> create mode 100644 spec/build/testsuites/libtests/rcxx01.yml
> create mode 100644 testsuites/libtests/rcxx01/init.c
> create mode 100644 testsuites/libtests/rcxx01/rcxx01.doc
> create mode 100644 testsuites/libtests/rcxx01/rcxx01.scn
> create mode 100644 testsuites/libtests/rcxx01/thread.cc
> diff --git a/cpukit/include/rtems/c++/error
> b/cpukit/include/rtems/c++/error
> new file mode 100644
> index 0000000000..8b9d875e0f
> --- /dev/null
> +++ b/cpukit/include/rtems/c++/error
> @@ -0,0 +1,65 @@
> +/* -*- C++ -*-
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2020 Chris Johns (http://contemporary.software)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * @file
> + * @ingroup RTEMSC++
> + * RTEMS Error exception.
> +#if !defined(RTEMS_CXX_ERROR)
> +#define RTEMS_CXX_ERROR
> +#include <stdexcept>
> +#include <string>
> +#include <rtems.h>
> +namespace rtems
> + class runtime_error :
> + public std::runtime_error
> + const rtems_status_code sc;
> + public:
> + runtime_error (const rtems_status_code sc);
> + runtime_error (const rtems_status_code sc, const std::string& what);
> + runtime_error (const rtems_status_code sc, const char* what);
> + ~runtime_error ();
> + * Throw a rtems::runtime_error exception if the RTEMS status code is
> + * not RTEMS_SUCCESSFUL.
> + void runtime_error_check (const rtems_status_code sc);
> + void runtime_error_check (const rtems_status_code sc, const
> std::string& what);
> + void runtime_error_check (const rtems_status_code sc, const char* what);
> +#endif
> diff --git a/cpukit/include/rtems/c++/thread
> b/cpukit/include/rtems/c++/thread
> index 0000000000..c3f18ab3cf
> --- /dev/null
> +++ b/cpukit/include/rtems/c++/thread
> @@ -0,0 +1,469 @@
> +/* -*- C++ -*-
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> + * @file
> + * The C++ standard thread support with thread attribute control.
> + * The code requires the `-std=c++17` option to access `std::invoke()`.
> +#if !defined(RTEMS_CXX_THREAD)
> +#define RTEMS_CXX_THREAD
> +#include <functional>
> +#include <iostream>
> +#include <string>
> +#include <thread>
> +#include <utility>
> +namespace rtems
> + namespace thread
> + * @brief Manage the attributes of a thread.
> + class attributes
> + public:
> + * The schedular modes.
> + enum sched_mode {
> + sched_inherit, /**< Inhert the scheduler */
> + sched_explicit /**< Explicitly set the scheduler */
> + * The schedular policies.
> + enum sched_policy {
> + sched_other, /**< Other scheduler policy */
> + sched_fifo, /**< FIFO scheduler policy */
> + sched_roundrobin, /**< Roundrobin scheduler policy */
> + sched_sporadic /**< Sporadic scheduler policy */
> + * Construct a thread attributes object with the current settings
> of the
> + * executing thread. The stack size is set to the configured minimum
> + * stack size.
> + attributes ();
> + * Copy construct the thread attributes.
> + * @param attr The attributes to copy.
> + attributes (const attributes& attr);
> + * Set the name of the thread. The thread is a classic API thread
> and
> + * the name is only 4 characters.
The thread appears to be a POSIX thread.
> + * @param name The name as a string.
> + void set_name (const std::string& name);
> and
> + void set_name (const char* name);
> + * Get the name of the thread.
> + * @retval const std::string& The name of the thread.
> + const std::string& get_name () const;
> + * Set the priority of the thread.
> + * @param priority The POSIX API priority of the thread.
> + void set_priority (int priority);
> + * Get the POSIX API priority of the thread.
> + * @retval int The POSIX API thread priority.
> + int get_priority () const;
> + * Set the stack size. If the size is less than the configured
> minimum
> + * the minimum value is used.
> + * @param size The stack size in bytes.
> + void set_stack_size (size_t size);
> + * Get the stack size.
> + * @retval size_t The stack size in bytes.
> + size_t get_stack_size () const;
> + * Set the scheduler name. If not set no scheduler is set.
> + * @parrm scheduler The name of the scheduler.
> + void set_scheduler (const std::string& scheduler);
> + void set_scheduler (const char* scheduler);
> + * Get scheduler name.
> + const std::string& get_scheduler ();
> + * Get the attrobutes' scheduler mode for the thread.
> + * @return sched_mode The attributes; scheduler mode
> + sched_mode get_scheduler_mode () const;
> + * Set the scheduler policy for the thread. This call sets the
> + * schedular mode to @ref sched_explicit.
> + * @param policy The scheduler policy.
> + void set_scheduler_policy (sched_policy policyr);
> + * Get the scheduler policy for the thread.
> + sched_policy get_scheduler_policy () const;
> + * Commit any changes to the executing thread. @note only the
> priority
> + * and modes of a thread can be changedTheeeeee name and stack size
> are
+ * ignored.
Is there a line break missing before the note?
> + void commit ();
> + * Update the attribute values from the executing thread. The
> attributes
> + * are updated from the current thread when constructed and the
> values
> + * returned are those held since then. If another thread changes the
> + * attributes of the current thread those changes will not be seen
> until
> + * this method is called. Except for the name and stack size any
> local
> + * changes made will lost then the update call is made.
> + void update ();
> + * Copy operator.
> + attributes& operator= (const attributes& attr);
> + * The comparision operator does not check the name or stack size
> + * of a thread.
> + bool operator== (const attributes& attr) const;
> + private:
> + std::string name; /**< Name of the thread */
> + int priority; /**< POSIX API priority */
> + size_t stack_size; /**< Stack size in bytes */
> + std::string scheduler; /**< Name of the scheduler */
> + sched_mode mode; /**< Scheduler's mode */
> + sched_policy policy; /**< Scheduler's policy */
> + /* affinity, cpu set size is? */
> + * @brief Create a thread with thread attributes.
> + * Create a thread optionally with thread attributes. The usage of
> this
> + * class follows the C++ standard for std::thread. The standard
> support
> + * for creating a thread does not let you control the attributes of a
> + * thread and control is important in embedded real-time
> + * applications. This class lets you control a thread attributes and
> use
> + * the extensive an excellent thread support the C++ standard
> provides.
> + * There is no indication attribute support for threads will be added
> to
> + * the C++ standard and what it will look like. The support provided
> here
> + * is designed to make as little impact on a code base as possible.
> While
> + * the attributes supported are specific to RTEMS they are common to
> all
> + * embedded operating systems.
> + * The support provided here is specific to GCC due to the use of some
> + * non-standard interfaces to get the indices of the template argument
> + * pack in new thread's context. A standards only solution would be
> + * preferred.
Since we have clang on some targets, any idea what it does and if this will
work? Should it disable itself for not GCC?
+ class thread
> + friend void* thread_generic_entry (void* arg);
> + * Base state class to interface to derived template of the thread
> + * state from the generic entry point for the thread.
> + struct state_base
> + virtual ~state_base ();
> + virtual const attributes get_attributes () = 0;
> + virtual void run () = 0;
> + * The state is passed to the new thread context as a unique
> + * pointer. This handles the hand over and clean up.
> + using state_ptr = std::unique_ptr<state_base>;
> + public:
> + * Template check to see if the first argument of a thread is a set
> of
> + * attributes.
> + template <typename A, class DecayA = typename std::decay<A>::type>
> + using enable_if_attributes = typename std::enable_if
> + <std::is_same<DecayA, attributes>::value>::type;
> + * We need our own id type so the thread class can access the
> pthread
> + * handle to initialise it.
> + class id {
> + public:
> + id () noexcept : id_ (0) { }
> + explicit id (pthread_t id_) : id_ (id_) { }
> + private:
> + pthread_t id_;
> + friend class thread;
> + friend bool operator== (thread::id l, thread::id r) noexcept;
> + template<class CharT, class Traits>
> + friend std::basic_ostream<CharT, Traits>&
> + operator<< (std::basic_ostream<CharT, Traits>& out, thread::id
> id_);
> + * The default thread constructions.
> + thread () noexcept = default;
> + * The std::thread equivilant constructor. The attributes will be
> the
Equivalent
+ * same as the executing thread with a default thread name and the
> + * configured minimum stack size.
> + template<typename F, typename... Args>
> + explicit thread (F&& func, Args&&... args);
> + * Create a thread with the provided attributes. The entry point and
> + * optional arguments are the same as std::thread.
> + template <typename A, typename F, typename ...Args,
> + class = enable_if_attributes<A>>
> + explicit thread (A&& attr, F&& func, Args&&... args);
> + * Move the thread id to this instance.
> + thread& operator= (thread&& thread_);
> + void swap(thread& thread_) noexcept;
> + bool joinable() const noexcept;
> + * Constrain use. These are not available.
> + thread (thread&) = delete;
> + thread (const thread&) = delete;
> + thread (const thread&&) = delete;
> + thread& operator= (const thread&) = delete;
> + std::thread::id get_id() const noexcept;
> + private:
> + id id_;
> + * Invoke the thread's entry point with the parameter pack in the
> new
> + * thread's context. This object holds the parameters copied onto
> the
> + * new thread's stack making them available to entry point routine.
> + template<typename Parms>
> + struct invoker {
> + Parms p;
> + template<size_t Index>
> + static std::__tuple_element_t<Index, Parms>&& declval ();
> + template<size_t... Ind>
> + auto invoke (std::_Index_tuple<Ind...>)
> + noexcept (noexcept (std::invoke (declval<Ind>()...)))
> + -> decltype (std::invoke (declval<Ind> ()...)) {
> + return std::invoke (std::get<Ind> (std::move (p))...);
> + using indices =
> + typename
> std::_Build_index_tuple<std::tuple_size<Parms>::value>::__type;
> + void run () {
> + invoke (indices ());
> + * The state holds the invoker with the parameters. The generic
> entry
> + * point calls the virtual methods to get the attributes and to run
> the
> + * new thread in the new thread's context..
> + template<typename Invoker>
> + struct state : state_base {
> + const attributes attr;
> + Invoker i;
> + state (const attributes& attr, Invoker&& i)
> + : attr (attr),
> + i (std::forward<Invoker> (i)) {
> + const attributes get_attributes () override {
> + return attr;
> + void run () override {
> + i.run ();
> + * Make the state. This dynamic memory is managed by the unique
> pointer
> + * and is passed to the generic thread entry point.
> + static state_ptr
> + make_state (const attributes& attr, Invoker&& i) {
> + using state_impl = state<Invoker>;
> + return state_ptr{ new state_impl (attr, std::forward<Invoker>
> (i)) };
> + * Decay the parameters so they can be correctly packed into the
> + * parameter tuple.
> + template<typename... T>
> + using decayed_tuple = std::tuple<typename std::decay<T>::type...>;
> + * Make the invoker with the parameters.
> + static invoker<decayed_tuple<F, Args...>>
> + make_invoker (F&& func, Args&&... args)
> + return {
> + decayed_tuple<F, Args...> {
> + std::forward<F> (func), std::forward<Args> (args)...
> + * Create and start the thread.
> + void start_thread (state_ptr s);
> + template <class T>
> + inline typename std::decay<T>::type
> + decay_copy (T&& t) {
> + return std::forward<T> (t);
> + thread::thread (F&& func, Args&&... args)
> + : id_ (0) {
> + attributes attr;
> + start_thread (
> + make_state (attr,
> + make_invoker (decay_copy (std::forward<F> (func)),
> + decay_copy (std::forward<Args>
> (args))...))
> + template<typename A, typename F, typename... Args,
> + class = thread::enable_if_attributes<A>>
> + thread::thread (A&& attr, F&& func, Args&&... args)
> + : id_ (0) {
> + start_thread (
> + make_state (attr,
> (args))...))
> + inline std::thread::id thread::get_id() const noexcept {
> + return std::thread::id (id_.id_);
> + inline bool
> + operator== (thread::id l, thread::id r) noexcept {
> + return l.id_ == r.id_;
> + inline bool
> + operator!= (thread::id l, thread::id r) noexcept {
> + return !(l == r);
> + template<class C, class T>
> + inline std::basic_ostream<C, T>&
> + operator<< (std::basic_ostream<C, T>& out, thread::id id_) {
> + return out << std::thread::id (id_.id_);
> +#endif
> diff --git a/cpukit/librtemscxx/error.cc b/cpukit/librtemscxx/error.cc
> index 0000000000..c7b749803f
> --- /dev/null
> +++ b/cpukit/librtemscxx/error.cc
> @@ -0,0 +1,76 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <rtems/c++/error>
> +namespace rtems
> + runtime_error::runtime_error (const rtems_status_code sc)
> + : std::runtime_error (::rtems_status_text (sc)),
> + sc (sc)
> + runtime_error::runtime_error (const rtems_status_code sc,
> + const std::string& what)
> + : std::runtime_error (what + ": " + ::rtems_status_text (sc)),
> + sc (sc)
> + const char* what)
> + : std::runtime_error (std::string (what) + ": " + ::rtems_status_text
> (sc)),
> + sc (sc)
> + runtime_error::~runtime_error()
> + void
> + runtime_error_check (const rtems_status_code sc)
> + if (sc != RTEMS_SUCCESSFUL)
> + throw runtime_error (sc);
> + void
> + runtime_error_check (const rtems_status_code sc, const std::string&
> what)
> + throw runtime_error (sc, what);
> + void
> + runtime_error_check (const rtems_status_code sc, const char* what)
> diff --git a/cpukit/librtemscxx/thread.cc b/cpukit/librtemscxx/thread.cc
> index 0000000000..79375a713c
> --- /dev/null
> +++ b/cpukit/librtemscxx/thread.cc
> @@ -0,0 +1,416 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#if !defined(_GNU_SOURCE)
> +#define _GNU_SOURCE
> +#endif
> +#include <system_error>
> +#include <rtems/c++/thread>
> +#include <pthread.h>
> +#include <rtems.h>
> +#if HAVE_GET_SCHEDULER_NAME
> +extern "C" bool get_scheduler_name (rtems_id sid, char* name);
> +#endif
> +bool get_scheduler_name (rtems_id sid, char* name)
> + name[0] = 'N';
> + name[1] = 'O';
> + name[2] = 'P';
> + name[3] = '\0';
> + return true;
> +#endif
> +namespace rtems
> + namespace thread
> + void
> + system_error_check (int ec, const char* what)
> + if (ec != 0)
> + throw std::system_error (ec, std::system_category(), what);
> + attributes::attributes ()
> + : priority (-1),
> + stack_size (RTEMS_MINIMUM_STACK_SIZE),
> + mode (sched_inherit),
> + policy (sched_fifo)
> + update ();
> + attributes::attributes (const attributes& attr)
> + : name (attr.name),
> + priority (attr.priority),
> + stack_size (attr.stack_size),
> + scheduler (attr.scheduler),
> + mode (attr.mode),
> + policy (attr.policy)
> + void
> + attributes::set_name (const std::string& name_)
> + name = name_;
> + void
> + attributes::set_name (const char* name_)
> + name = name_;
> + attributes::get_name () const
> + return name;
> + void
> + attributes::set_priority (int priority_)
> + priority = priority_;
> + int
> + attributes::get_priority () const
> + return priority;
> + void
> + attributes::set_stack_size(size_t size)
> + stack_size = size;
> + size_t
> + attributes::get_stack_size () const
> + return stack_size;
> + void
> + attributes::set_scheduler (const std::string& scheduler_)
> + scheduler = scheduler_;
> + void
> + attributes::set_scheduler (const char* scheduler_)
> + attributes::get_scheduler ()
> + return scheduler;
> + attributes::sched_mode
> + attributes::get_scheduler_mode () const
> + return mode;
> + void
> + attributes::set_scheduler_policy (sched_policy policy_)
> + mode = sched_explicit;
> + policy = policy_;
> + attributes::sched_policy
> + attributes::get_scheduler_policy () const
> + return policy;
> + void
> + attributes::commit ()
> + pthread_t pid = ::pthread_self ();
> + system_error_check (::pthread_setname_np (pid, name.c_str ()),
> + "getting name");
> + int spolicy;
> + struct sched_param sched_param;
> + system_error_check (::pthread_getschedparam (::pthread_self (),
> + &spolicy,
> + &sched_param),
> + "getting scheduler parameters");
> + switch (policy) {
> + case sched_other:
> + spolicy = SCHED_OTHER;
> + break;
> + case sched_fifo:
> + spolicy = SCHED_FIFO;
> + break;
> + case sched_roundrobin:
> + spolicy = SCHED_RR;
> + break;
> + case sched_sporadic:
> + spolicy = SCHED_SPORADIC;
> + break;
> + default:
> + system_error_check (EINVAL, "get scheduler policy");
> + break;
> + sched_param.sched_priority = priority;
> + system_error_check (::pthread_setschedparam (::pthread_self (),
> + spolicy,
> + &sched_param),
> + if (!scheduler.empty ()) {
> + char sname[4] = { ' ', ' ', ' ', ' ' };
> + for (size_t c = 0; c < sizeof (sname); ++c) {
> + if (c >= scheduler.length ())
> + break;
> + sname[c] = scheduler[c];
> + rtems_name scheduler_name = rtems_build_name (sname[0],
> + sname[1],
> + sname[2],
> + sname[3]);
> + rtems_id scheduler_id;
> + runtime_error_check (::rtems_scheduler_ident (scheduler_name,
> + &scheduler_id),
> + "get scheduler id");
> + // runtime_error_check (::rtems_task_set_scheduler (RTEMS_SELF,
> + // scheduler_id,
> + // 1),
> + // "set scheduler id");
> + void
> + attributes::update ()
> + char buf[32];
> + system_error_check (::pthread_getname_np (::pthread_self (),
> + buf,
> + sizeof (buf)),
> + "getting name");
> + name = buf;
> + int spolicy;
> + &spolicy,
> + &sched_param),
> + switch (spolicy) {
> + case SCHED_OTHER:
> + policy = sched_other;
> + break;
> + case SCHED_FIFO:
> + policy = sched_fifo;
> + break;
> + case SCHED_RR:
> + policy = sched_roundrobin;
> + break;
> + case SCHED_SPORADIC:
> + policy = sched_sporadic;
> + break;
> + default:
> + break;
> + priority = sched_param.sched_priority;
> + pthread_attr_t attr;
> + system_error_check (::pthread_getattr_np (::pthread_self (), &attr),
> + "getting thread attributes");
> + system_error_check (::pthread_attr_getstacksize (&attr,
> &stack_size),
> + "getting stack size");
> + int inheritsched = 0;
> + system_error_check (::pthread_attr_getinheritsched (&attr,
> &inheritsched),
> + "getting inherited sheduler mode");
> + switch (inheritsched) {
> + case PTHREAD_INHERIT_SCHED:
> + mode = sched_inherit;
> + break;
> + case PTHREAD_EXPLICIT_SCHED:
> + break;
> + default:
> + system_error_check (EINVAL, "get scheduler mode");
> + break;
> + runtime_error_check (::rtems_task_get_scheduler (RTEMS_SELF,
> &scheduler_id));
> + char name[5];
> + if (!get_scheduler_name (scheduler_id, &name[0]))
> + system_error_check (ENOENT, "get scheduler name");
> + scheduler = name;
> +#endif
> + attributes&
> + attributes::operator= (const attributes& attr)
> + name = attr.name;
> + priority = attr.priority;
> + stack_size = attr.stack_size;
> + mode = attr.mode;
> + policy = attr.policy;
> + return *this;
> + bool
> + attributes::operator== (const attributes& attr) const
> + return
> + name == attr.name &&
> + priority == attr.priority &&
> + stack_size == attr.stack_size &&
> + mode == attr.mode &&
> + policy == attr.policy;
> + void*
> + thread_generic_entry (void* arg)
> + thread::state_ptr s{ static_cast<thread::state_base*> (arg) };
> + try {
> + s->run ();
> + } catch (...) {
> + std::terminate ();
> + return nullptr;
> + thread&
> + thread::operator= (thread&& thread_)
> + if (joinable ())
> + swap(thread_);
> + return *this;
> + void
> + thread::swap(thread& thread_) noexcept
> + std::swap(id_, thread_.id_);
> + bool
> + thread::joinable() const noexcept
> + return !(id_ == id());
> + thread::state_base::~state_base () = default;
> + void
> + thread::start_thread (thread::state_ptr s)
> + const attributes attr = s->get_attributes ();
> + pthread_attr_t pattr;
> + system_error_check (::pthread_attr_init (&pattr),
> + "attribute init");
> + system_error_check (::pthread_attr_setdetachstate (&pattr,
> PTHREAD_CREATE_DETACHED),
> + "set detached state");
> + struct sched_param param;
> + param.sched_priority = attr.get_priority ();
> + system_error_check (::pthread_attr_setschedparam (&pattr, ¶m),
> + "set ");
> + int spolicy;
> + switch (attr.get_scheduler_policy ()) {
> + case attributes::sched_other:
> + break;
> + case attributes::sched_roundrobin:
> + break;
> + case attributes::sched_sporadic:
> + break;
> + default:
> + break;
> + system_error_check (::pthread_attr_setschedpolicy (&pattr, spolicy),
> + "set scheduler policy");
> + if (attr.get_scheduler_mode () == attributes::sched_inherit)
> + ::pthread_attr_setinheritsched (&pattr, PTHREAD_INHERIT_SCHED);
> + else
> + ::pthread_attr_setinheritsched (&pattr, PTHREAD_EXPLICIT_SCHED);
> + system_error_check (::pthread_attr_setstacksize(&pattr,
> + attr.get_stack_size
> + "set stack size");
> + * Hold the new thread in the state's run handler until the rest
> + * of the thread is set up after the create call.
> + system_error_check (::pthread_create (&id_.id_,
> + &pattr,
> + thread_generic_entry,
> + s.get ()),
> + "create thread");
> + system_error_check (::pthread_setname_np (id_.id_,
> + attr.get_name ().c_str
> + "setting thread name");
> + ::pthread_attr_destroy (&pattr);
> + s.release ();
> diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
> index 3a285d03fc..91fa2d9625 100644
> --- a/spec/build/cpukit/grp.yml
> +++ b/spec/build/cpukit/grp.yml
> @@ -27,6 +27,8 @@ links:
> uid: libpppd
> - role: build-dependency
> uid: librtemscpu
> +- role: build-dependency
> + uid: librtemscxx
> uid: librtemsdfltcfg
> diff --git a/spec/build/cpukit/librtemscxx.yml
> b/spec/build/cpukit/librtemscxx.yml
> index 0000000000..769e5a7498
> --- /dev/null
> +++ b/spec/build/cpukit/librtemscxx.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: library
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 Chris Johns (http://contemporary.software)
> +cppflags: []
> +cxxflags: [-std=c++17]
> +enabled-by: true
> +includes: []
> +install:
> +- destination: ${BSP_INCLUDEDIR}
> + source:
> + - cpukit/include/rtems/c++/error
> + - cpukit/include/rtems/c++/thread
> +install-path: ${BSP_LIBDIR}
> +links: []
> +source:
> +- cpukit/librtemscxx/error.cc
> +- cpukit/librtemscxx/thread.cc
> +target: rtemscxx
> +type: build
> diff --git a/spec/build/testsuites/libtests/grp.yml
> b/spec/build/testsuites/libtests/grp.yml
> index 2b1f2727cf..b9ca014b0d 100644
> --- a/spec/build/testsuites/libtests/grp.yml
> +++ b/spec/build/testsuites/libtests/grp.yml
> @@ -214,6 +214,8 @@ links:
> uid: pwdgrp02
> uid: rbheap01
> + uid: rcxx01
> uid: read
> diff --git a/spec/build/testsuites/libtests/rcxx01.yml
> b/spec/build/testsuites/libtests/rcxx01.yml
> index 0000000000..6d69feeb83
> --- /dev/null
> +++ b/spec/build/testsuites/libtests/rcxx01.yml
> @@ -0,0 +1,22 @@
> +build-type: test-program
> +cflags: []
> +copyrights:
> +cppflags: []
> +enabled-by: true
> +features: c cxx cxxprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/libtests/rcxx01/init.c
> +- testsuites/libtests/rcxx01/thread.cc
> +stlib: []
> +target: testsuites/libtests/rcxx01.exe
> +type: build
> +use-after: []
> +use-before:
> +- rtemsdefaultconfig
> +- rtemscxx
> diff --git a/testsuites/libtests/rcxx01/init.c
> b/testsuites/libtests/rcxx01/init.c
> index 0000000000..b3dfa9f0c1
> --- /dev/null
> +++ b/testsuites/libtests/rcxx01/init.c
> @@ -0,0 +1,69 @@
> + * Copyright (c) 2020 Chris Johns (http://contemporary.software)
> + * All rights reserved.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <bsp.h>
> +#include <stdlib.h>
> +#include <stdio.h>
> +#include <sys/types.h>
> +#include <sys/stat.h>
> +#include <fcntl.h>
> +#include <sys/ioctl.h>
> +#include <unistd.h>
> +#include "tmacros.h"
> +const char rtems_test_name[] = "RCXX 1";
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument argument);
> +void rcxx_run_test(void);
> +rtems_task Init(
> + rtems_task_argument ignored
> + TEST_BEGIN();
> + rcxx_run_test();
> + TEST_END();
> + rtems_test_exit( 0 );
> +/* configuration information */
> +#include <rtems/serial_mouse.h>
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
> +#define CONFIGURE_MEMORY_OVERHEAD (2024)
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_STACK_SIZE (10U * 1024U)
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +#include <rtems/confdefs.h>
> +/* end of file */
> diff --git a/testsuites/libtests/rcxx01/rcxx01.doc
> b/testsuites/libtests/rcxx01/rcxx01.doc
> index 0000000000..3fd41b029b
> --- /dev/null
> +++ b/testsuites/libtests/rcxx01/rcxx01.doc
> @@ -0,0 +1,16 @@
> +# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>
> +This file describes the directives and concepts tested by this test set.
> +test set name: rcxx01
> +directives:
> + rtems::thread::thread
> + rtems::thread::attributes
> +concepts:
> ++ Create a thread using the default method, ie like std::thread.
> +* Create a thread with changed attributes.
> diff --git a/testsuites/libtests/rcxx01/rcxx01.scn
> b/testsuites/libtests/rcxx01/rcxx01.scn
> index 0000000000..37bf2d3f7a
> --- /dev/null
> +++ b/testsuites/libtests/rcxx01/rcxx01.scn
> @@ -0,0 +1,13 @@
> +*** BEGIN OF TEST RCXX 1 ***
> +*** TEST VERSION: 5.0.0.7ba04a62227286dcd3da20ea7319d9c64b8f5fd1
> +*** TEST STATE: EXPECTED-PASS
> +*** TEST BUILD:
> +*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
> ceb811fa19ddcfdd449a8da8f1107e6e592727b6, Newlib d14714c69)
> +Thread: start: default
> + 1 D
> +Thread: start: attr
> + 2 R
> +Thread: end: default
> +Thread: end: attr
> +*** END OF TEST RCXX 1 ***
> diff --git a/testsuites/libtests/rcxx01/thread.cc
> b/testsuites/libtests/rcxx01/thread.cc
> index 0000000000..7cb64cea5a
> --- /dev/null
> +++ b/testsuites/libtests/rcxx01/thread.cc
> @@ -0,0 +1,90 @@
> +#include <chrono>
> +#include <thread>
> +#include <mutex>
> +using namespace std::chrono_literals;
> +extern "C" void rcxx_run_test(void);
> +struct test_thread
> + test_thread();
> + void start();
> + bool running();
> + void body(const char* title, int i, char c);
> + rtems::thread::thread thread_default;
> + rtems::thread::thread thread_attr;
> + std::mutex mutex;
> + bool finished;
> +test_thread::test_thread()
> + : finished(false)
> +void test_thread::start()
> + thread_default = rtems::thread::thread(&test_thread::body, this,
> + "default", 1, 'D');
> + rtems::thread::attributes attr;
> + attr.set_name("RTHREAD");
> + attr.set_priority(5);
> + attr.set_stack_size(32 * 1024);
> + thread_attr = rtems::thread::thread(attr, &test_thread::body, this,
> + "attr", 2, 'R');
> +void test_thread::body(const char* title, int i, char c)
> + std::cout << "Thread: start: " << title << std::endl
> + << ' ' << i << ' ' << c << std::endl;
> + size_t count = 5;
> + while (count--) {
> + std::this_thread::sleep_for(1s);
> + std::cout << "Thread: end: " << title << std::endl;
> + std::lock_guard<std::mutex> lock(mutex);
> + finished = true;
> +bool test_thread::running()
> + return finished == false;
> + try {
> + test_thread tt;
> + tt.start();
> + while (tt.running())
> + } catch (...) {
> + std::cout << "Thread: ouch" << std::endl;
> + throw;
> 2.24.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201003/86b05c29/attachment-0001.html>
