I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
smallphd at aliyun.com smallphd at aliyun.com
Mon Oct 5 08:24:37 UTC 2020
Hi, all
I compile rtems 5.1 with bsp xilinx-zynqmp. The single core mode is ok.
But I can not use 2 or 3 or 4 cores of this bsp.
After analysing the source code, I found there is no code to address smp condition. Does rtems 5.1 indeed not support smp mode for xilinx-zynqmp bsp?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/b25ff734/attachment-0001.html>
