I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
Gedare Bloom
gedare at rtems.org
Mon Oct 5 16:16:29 UTC 2020
It should, I believe. The bsp has bspsmp.c file.
How did you configure (../rtems/configure)?
What board/target do you run it on?
On Mon, Oct 5, 2020 at 2:24 AM smallphd at aliyun.com <smallphd at aliyun.com> wrote:
> Hi, all
> I compile rtems 5.1 with bsp xilinx-zynqmp. The single core mode is ok.
> But I can not use 2 or 3 or 4 cores of this bsp.
> After analysing the source code, I found there is no code to address smp condition. Does rtems 5.1 indeed not support smp mode for xilinx-zynqmp bsp?
> ________________________________
> devel mailing list
> devel at rtems.org
