[PATCH v3 03/10] bsps: Break out AArch32 portions of GPT driver
Mon Oct 5 12:28:18 UTC 2020
On 05/10/2020 14:22, Joel Sherrill wrote:
> On Mon, Oct 5, 2020 at 1:59 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 04/10/2020 06:18, Kinsey Moore wrote:
>     > diff --git a/bsps/arm/imx/start/bspstart.c
>     b/bsps/arm/imx/start/bspstart.c
>     > index 5fb07bf60a..ff4b204790 100644
>     > --- a/bsps/arm/imx/start/bspstart.c
>     > +++ b/bsps/arm/imx/start/bspstart.c
>     > @@ -18,6 +18,7 @@
>     >   #include <bsp/fdt.h>
>     >   #include <bsp/irq-generic.h>
>     >   #include <bsp/linker-symbols.h>
>     > +#include <dev/clock/arm-generic-timer.h>
>     >   #include <libfdt.h>
>     > @@ -58,7 +59,7 @@ uint32_t bsp_fdt_map_intr(const uint32_t
>     *intr, size_t icells)
>     >     return intr[1] + MAGIC_IRQ_OFFSET;
>     > -void arm_generic_timer_get_config(
>     > +void aarch_generic_timer_get_config(
>     Why did the function name change? The header file name starts also
>     with
>     arm and not aarch.
> ARM uses the terms aarch32 and aarch64 so it does make sense to
> refer bits and bobs as aarch.
I am not really fond of using aarch32 for existing stuff which already
had an arm prefix. I would use "arm" for shared stuff and the 32-bit
ARM. I would use "aarch64" for the 64-bit stuff.
