[PATCH v3 03/10] bsps: Break out AArch32 portions of GPT driver
Mon Oct 5 15:21:41 UTC 2020
On Mon, Oct 5, 2020 at 6:28 AM Sebastian Huber
> On 05/10/2020 14:22, Joel Sherrill wrote:
> > On Mon, Oct 5, 2020 at 1:59 AM Sebastian Huber
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     On 04/10/2020 06:18, Kinsey Moore wrote:
> >     > diff --git a/bsps/arm/imx/start/bspstart.c
> >     b/bsps/arm/imx/start/bspstart.c
> >     > index 5fb07bf60a..ff4b204790 100644
> >     > --- a/bsps/arm/imx/start/bspstart.c
> >     > +++ b/bsps/arm/imx/start/bspstart.c
> >     > @@ -18,6 +18,7 @@
> >     >   #include <bsp/fdt.h>
> >     >   #include <bsp/irq-generic.h>
> >     >   #include <bsp/linker-symbols.h>
> >     > +#include <dev/clock/arm-generic-timer.h>
> >     >   #include <libfdt.h>
> >     > @@ -58,7 +59,7 @@ uint32_t bsp_fdt_map_intr(const uint32_t
> >     *intr, size_t icells)
> >     >     return intr[1] + MAGIC_IRQ_OFFSET;
> >     > -void arm_generic_timer_get_config(
> >     > +void aarch_generic_timer_get_config(
> >     Why did the function name change? The header file name starts also
> >     with
> >     arm and not aarch.
> > ARM uses the terms aarch32 and aarch64 so it does make sense to
> > refer bits and bobs as aarch.
> I am not really fond of using aarch32 for existing stuff which already
> had an arm prefix. I would use "arm" for shared stuff and the 32-bit
> ARM. I would use "aarch64" for the 64-bit stuff.
I agree. Just because Arm is having a mid-life crisis doesn't mean we
have to kowtow to it.
> devel mailing list
> devel at rtems.org
