[PATCH v1] tester: Prevent crash with json output
Mon Oct 5 22:02:43 UTC 2020
On Mon, Oct 5, 2020 at 4:57 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/10/20 7:41 am, Kinsey Moore wrote:
> > This fixes an issue with json report output that causes a crash due to
> > the incorrect object member being accessed for test-too-long. This also
> > changes treatment of fatal errors to match how they are displayed in the
> > tester log output and changes "fatal error" to "fatal-error" to better
> > match the naming of all the other failure types.
> >  tester/rt/report.py | 2 +-
> >  tester/rt/test.py   | 9 ++++++---
> >  2 files changed, 7 insertions(+), 4 deletions(-)
> OK to push. Thanks.
I'm OK to push this but should it also have a  ticket and go to 5?
I'm sure that's the question Kinsey wants to hear. :)
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/1444f9f6/attachment.html>
