[PATCH v1] tester: Prevent crash with json output
Kinsey Moore kinsey.moore at oarcorp.com
Mon Oct 5 22:35:29 UTC 2020
Sent: Monday, October 5, 2020 17:03
To: Chris Johns <chrisj at rtems.org>
Cc: Kinsey Moore <kinsey.moore at oarcorp.com>; rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: [PATCH v1] tester: Prevent crash with json output
On Mon, Oct 5, 2020 at 4:57 PM Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
On 6/10/20 7:41 am, Kinsey Moore wrote:
> This fixes an issue with json report output that causes a crash due to
> the incorrect object member being accessed for test-too-long. This also
> changes treatment of fatal errors to match how they are displayed in the
> tester log output and changes "fatal error" to "fatal-error" to better
> match the naming of all the other failure types.
>  tester/rt/report.py | 2 +-
>  tester/rt/test.py   | 9 ++++++---
>  2 files changed, 7 insertions(+), 4 deletions(-)
OK to push. Thanks.
I'm OK to push this but should it also have a  ticket and go to 5?
I'm sure that's the question Kinsey wants to hear. :)
This was necessary due to a change that didn’t go into 5, so it really shouldn’t go into 5, either
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201005/f79764fa/attachment.html>
