[PATCH v5] cpukit/librcxx: Add a C++ thread interface with attributes
chrisj at rtems.org
chrisj at rtems.org
Tue Oct 6 01:44:09 UTC 2020
cpukit/include/rtems/c++/error | 69 ++++
cpukit/include/rtems/c++/thread | 476 ++++++++++++++++++++++
cpukit/librtemscxx/error.cc | 76 ++++
cpukit/librtemscxx/thread.cc | 416 +++++++++++++++++++
spec/build/cpukit/grp.yml | 2 +
spec/build/cpukit/librtemscxx.yml | 21 +
spec/build/testsuites/libtests/grp.yml | 2 +
spec/build/testsuites/libtests/rcxx01.yml | 22 +
testsuites/libtests/rcxx01/init.c | 89 ++++
testsuites/libtests/rcxx01/rcxx01.doc | 16 +
testsuites/libtests/rcxx01/rcxx01.scn | 13 +
testsuites/libtests/rcxx01/thread.cc | 110 +++++
12 files changed, 1312 insertions(+)
create mode 100644 cpukit/include/rtems/c++/error
create mode 100644 cpukit/include/rtems/c++/thread
create mode 100644 cpukit/librtemscxx/error.cc
create mode 100644 cpukit/librtemscxx/thread.cc
create mode 100644 spec/build/cpukit/librtemscxx.yml
create mode 100644 spec/build/testsuites/libtests/rcxx01.yml
create mode 100644 testsuites/libtests/rcxx01/init.c
create mode 100644 testsuites/libtests/rcxx01/rcxx01.doc
create mode 100644 testsuites/libtests/rcxx01/rcxx01.scn
create mode 100644 testsuites/libtests/rcxx01/thread.cc
diff --git a/cpukit/include/rtems/c++/error b/cpukit/include/rtems/c++/error
new file mode 100644
index 0000000000..6b973f68e6
--- /dev/null
+++ b/cpukit/include/rtems/c++/error
@@ -0,0 +1,69 @@
+/* -*- C++ -*- */
+ * @file
+ * @ingroup RTEMSC++
+ * @brief RTEMS Error exception.
+ * Provide an error exception for RTEMS errors.
+ * Copyright (C) 2020 Chris Johns (http://contemporary.software)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if !defined(RTEMS_CXX_ERROR)
+#define RTEMS_CXX_ERROR
+#include <stdexcept>
+#include <string>
+#include <rtems.h>
+namespace rtems
+ class runtime_error :
+ public std::runtime_error
+ const rtems_status_code sc;
+ public:
+ runtime_error (const rtems_status_code sc);
+ runtime_error (const rtems_status_code sc, const std::string& what);
+ runtime_error (const rtems_status_code sc, const char* what);
+ ~runtime_error ();
+ * Throw a rtems::runtime_error exception if the RTEMS status code is
+ * not RTEMS_SUCCESSFUL.
+ void runtime_error_check (const rtems_status_code sc);
+ void runtime_error_check (const rtems_status_code sc, const std::string& what);
+ void runtime_error_check (const rtems_status_code sc, const char* what);
+#endif
diff --git a/cpukit/include/rtems/c++/thread b/cpukit/include/rtems/c++/thread
index 0000000000..5815a86252
--- /dev/null
+++ b/cpukit/include/rtems/c++/thread
@@ -0,0 +1,476 @@
+/* -*- C++ -*- */
+ * @file
+ * @brief C++ standard thread support with thread attribute control.
+ * Provide a way to create a thread in C++ with attributes that let
+ * you control the real-time embedded parameters need to run
+ * threads on RTEMS.
+ * The code requires the `-std=c++17` option to access `std::invoke()`.
+ * are met:
+#if !defined(RTEMS_CXX_THREAD)
+#define RTEMS_CXX_THREAD
+#include <functional>
+#include <iostream>
+#include <string>
+#include <thread>
+#include <utility>
+namespace rtems
+ namespace thread
+ * @brief Manage the attributes of a thread.
+ class attributes
+ public:
+ * The scheduler modes.
+ enum sched_mode {
+ sched_inherit, /**< Inherit the scheduler */
+ sched_explicit /**< Explicitly set the scheduler */
+ * The scheduler policies.
+ enum sched_policy {
+ sched_other, /**< Other scheduler policy */
+ sched_fifo, /**< FIFO scheduler policy */
+ sched_roundrobin, /**< Round robin scheduler policy */
+ sched_sporadic /**< Sporadic scheduler policy */
+ * Construct a thread attributes object with the current settings of the
+ * executing thread. The stack size is set to the configured minimum
+ * stack size.
+ attributes ();
+ * Copy construct the thread attributes.
+ * @param attr The attributes to copy.
+ attributes (const attributes& attr);
+ * Set the name of the thread. The thread is a classic API thread and
+ * the name is only 4 characters.
+ * @param name The name as a string.
+ void set_name (const std::string& name);
+ void set_name (const char* name);
+ * Get the name of the thread.
+ * @retval const std::string& The name of the thread.
+ const std::string& get_name () const;
+ * Set the priority of the thread.
+ * @param priority The POSIX API priority of the thread.
+ void set_priority (int priority);
+ * Get the POSIX API priority of the thread.
+ * @retval int The POSIX API thread priority.
+ int get_priority () const;
+ * Set the stack size. If the size is less than the configured minimum
+ * the minimum value is used.
+ * @param size The stack size in bytes.
+ void set_stack_size (size_t size);
+ * Get the stack size.
+ * @retval size_t The stack size in bytes.
+ size_t get_stack_size () const;
+ * Set the scheduler name. If not set no scheduler is set.
+ * @parrm scheduler The name of the scheduler.
+ void set_scheduler (const std::string& scheduler);
+ void set_scheduler (const char* scheduler);
+ * Get scheduler name.
+ const std::string& get_scheduler ();
+ * Get the attributes' scheduler mode for the thread.
+ * @return sched_mode The attributes; scheduler mode
+ sched_mode get_scheduler_mode () const;
+ * Set the scheduler policy for the thread. This call sets the
+ * scheduler mode to @ref sched_explicit.
+ * @param policy The scheduler policy.
+ void set_scheduler_policy (sched_policy policy);
+ * Get the scheduler policy for the thread.
+ sched_policy get_scheduler_policy () const;
+ * Commit any changes to the executing thread.
+ * @note only the priority and modes of a thread can be changed. The
+ * name and stack size are ignored.
+ void commit ();
+ * Update the attribute values from the executing thread. The attributes
+ * are updated from the current thread when constructed and the values
+ * returned are those held since then. If another thread changes the
+ * attributes of the current thread those changes will not be seen until
+ * this method is called. Except for the name and stack size any local
+ * changes made will lost then the update call is made.
+ void update ();
+ * Copy operator.
+ attributes& operator= (const attributes& attr);
+ * The comparison operator does not check the name or stack size
+ * of a thread.
+ bool operator== (const attributes& attr) const;
+ private:
+ std::string name; /**< Name of the thread */
+ int priority; /**< POSIX API priority */
+ size_t stack_size; /**< Stack size in bytes */
+ std::string scheduler; /**< Name of the scheduler */
+ sched_mode mode; /**< Scheduler's mode */
+ sched_policy policy; /**< Scheduler's policy */
+ /* affinity, cpu set size is? */
+ * @brief Create a thread with thread attributes.
+ * Create a thread optionally with thread attributes. The usage of this
+ * class follows the C++ standard for std::thread. The standard support
+ * for creating a thread does not let you control the attributes of a
+ * thread and control is important in embedded real-time
+ * applications. This class lets you control a thread attributes and use
+ * the extensive an excellent thread support the C++ standard provides.
+ * There is no indication attribute support for threads will be added to
+ * the C++ standard and what it will look like. The support provided here
+ * is designed to make as little impact on a code base as possible. While
+ * the attributes supported are specific to RTEMS they are common to all
+ * embedded operating systems.
+ * The support provided here is specific to GCC due to the use of some
+ * non-standard interfaces to get the indices of the template argument
+ * pack in new thread's context. A standards only solution would be
+ * preferred.
+ class thread
+ friend void* thread_generic_entry (void* arg);
+ * Base state class to interface to derived template of the thread
+ * state from the generic entry point for the thread.
+ struct state_base
+ virtual ~state_base ();
+ virtual const attributes get_attributes () = 0;
+ virtual void run () = 0;
+ * The state is passed to the new thread context as a unique
+ * pointer. This handles the hand over and clean up.
+ using state_ptr = std::unique_ptr<state_base>;
+ public:
+ * Template check to see if the first argument of a thread is a set of
+ * attributes.
+ template <typename A, class DecayA = typename std::decay<A>::type>
+ using enable_if_attributes = typename std::enable_if
+ <std::is_same<DecayA, attributes>::value>::type;
+ * We need our own id type so the thread class can access the pthread
+ * handle to initialise it.
+ class id {
+ public:
+ id () noexcept : id_ (0) { }
+ explicit id (pthread_t id_) : id_ (id_) { }
+ private:
+ pthread_t id_;
+ friend class thread;
+ friend bool operator== (thread::id l, thread::id r) noexcept;
+ template<class CharT, class Traits>
+ friend std::basic_ostream<CharT, Traits>&
+ operator<< (std::basic_ostream<CharT, Traits>& out, thread::id id_);
+ * The default thread constructions.
+ thread () noexcept = default;
+ * The std::thread equivalent constructor. The attributes will be the
+ * same as the executing thread with a default thread name and the
+ * configured minimum stack size.
+ template<typename F, typename... Args>
+ explicit thread (F&& func, Args&&... args);
+ * Create a thread with the provided attributes. The entry point and
+ * optional arguments are the same as std::thread.
+ template <typename A, typename F, typename ...Args,
+ class = enable_if_attributes<A>>
+ explicit thread (A&& attr, F&& func, Args&&... args);
+ * Move the thread id to this instance.
+ thread& operator= (thread&& thread_);
+ void swap(thread& thread_) noexcept;
+ bool joinable() const noexcept;
+ * Constrain use. These are not available.
+ thread (thread&) = delete;
+ thread (const thread&) = delete;
+ thread (const thread&&) = delete;
+ thread& operator= (const thread&) = delete;
+ std::thread::id get_id() const noexcept;
+ private:
+ id id_;
+ * Invoke the thread's entry point with the parameter pack in the new
+ * thread's context. This object holds the parameters copied onto the
+ * new thread's stack making them available to entry point routine.
+ template<typename Parms>
+ struct invoker {
+ Parms p;
+ template<size_t Index>
+ static std::__tuple_element_t<Index, Parms>&& declval ();
+ template<size_t... Ind>
+ auto invoke (std::_Index_tuple<Ind...>)
+ noexcept (noexcept (std::invoke (declval<Ind>()...)))
+ -> decltype (std::invoke (declval<Ind> ()...)) {
+ return std::invoke (std::get<Ind> (std::move (p))...);
+ using indices =
+ typename std::_Build_index_tuple<std::tuple_size<Parms>::value>::__type;
+ void run () {
+ invoke (indices ());
+ * The state holds the invoker with the parameters. The generic entry
+ * point calls the virtual methods to get the attributes and to run the
+ * new thread in the new thread's context.
+ template<typename Invoker>
+ struct state : state_base {
+ const attributes attr;
+ Invoker i;
+ state (const attributes& attr, Invoker&& i)
+ : attr (attr),
+ i (std::forward<Invoker> (i)) {
+ const attributes get_attributes () override {
+ return attr;
+ void run () override {
+ i.run ();
+ * Make the state. This dynamic memory is managed by the unique pointer
+ * and is passed to the generic thread entry point.
+ static state_ptr
+ make_state (const attributes& attr, Invoker&& i) {
+ using state_impl = state<Invoker>;
+ return state_ptr{ new state_impl (attr, std::forward<Invoker> (i)) };
+ * Decay the parameters so they can be correctly packed into the
+ * parameter tuple.
+ template<typename... T>
+ using decayed_tuple = std::tuple<typename std::decay<T>::type...>;
+ * Make the invoker with the parameters.
+ static invoker<decayed_tuple<F, Args...>>
+ make_invoker (F&& func, Args&&... args)
+ return {
+ decayed_tuple<F, Args...> {
+ std::forward<F> (func), std::forward<Args> (args)...
+ * Create and start the thread.
+ void start_thread (state_ptr s);
+ template <class T>
+ inline typename std::decay<T>::type
+ decay_copy (T&& t) {
+ return std::forward<T> (t);
+ thread::thread (F&& func, Args&&... args)
+ : id_ (0) {
+ attributes attr;
+ start_thread (
+ make_state (attr,
+ make_invoker (decay_copy (std::forward<F> (func)),
+ decay_copy (std::forward<Args> (args))...))
+ template<typename A, typename F, typename... Args,
+ class = thread::enable_if_attributes<A>>
+ thread::thread (A&& attr, F&& func, Args&&... args)
+ : id_ (0) {
+ start_thread (
+ make_state (attr,
+ inline std::thread::id thread::get_id() const noexcept {
+ return std::thread::id (id_.id_);
+ inline bool
+ operator== (thread::id l, thread::id r) noexcept {
+ return l.id_ == r.id_;
+ inline bool
+ operator!= (thread::id l, thread::id r) noexcept {
+ return !(l == r);
+ template<class C, class T>
+ inline std::basic_ostream<C, T>&
+ operator<< (std::basic_ostream<C, T>& out, thread::id id_) {
+ return out << std::thread::id (id_.id_);
+#endif
diff --git a/cpukit/librtemscxx/error.cc b/cpukit/librtemscxx/error.cc
index 0000000000..13c1ec019c
--- /dev/null
+++ b/cpukit/librtemscxx/error.cc
@@ -0,0 +1,76 @@
+ * are met:
+#include <rtems/c++/error>
+namespace rtems
+ runtime_error::runtime_error (const rtems_status_code sc)
+ : std::runtime_error (::rtems_status_text (sc)),
+ sc (sc)
+ runtime_error::runtime_error (const rtems_status_code sc,
+ const std::string& what)
+ : std::runtime_error (what + ": " + ::rtems_status_text (sc)),
+ sc (sc)
+ const char* what)
+ : std::runtime_error (std::string (what) + ": " + ::rtems_status_text (sc)),
+ sc (sc)
+ runtime_error::~runtime_error()
+ void
+ runtime_error_check (const rtems_status_code sc)
+ if (sc != RTEMS_SUCCESSFUL)
+ throw runtime_error (sc);
+ void
+ runtime_error_check (const rtems_status_code sc, const std::string& what)
+ throw runtime_error (sc, what);
+ void
+ runtime_error_check (const rtems_status_code sc, const char* what)
diff --git a/cpukit/librtemscxx/thread.cc b/cpukit/librtemscxx/thread.cc
index 0000000000..06c65c28b7
--- /dev/null
+++ b/cpukit/librtemscxx/thread.cc
@@ -0,0 +1,416 @@
+ * are met:
+#if !defined(_GNU_SOURCE)
+#define _GNU_SOURCE
+#endif
+#include <system_error>
+#include <rtems/c++/thread>
+#include <pthread.h>
+#include <rtems.h>
+#if HAVE_GET_SCHEDULER_NAME
+extern "C" bool get_scheduler_name (rtems_id sid, char* name);
+#endif
+bool get_scheduler_name (rtems_id sid, char* name)
+ name[0] = 'N';
+ name[1] = 'O';
+ name[2] = 'P';
+ name[3] = '\0';
+ return true;
+#endif
+namespace rtems
+ namespace thread
+ void
+ system_error_check (int ec, const char* what)
+ if (ec != 0)
+ throw std::system_error (ec, std::system_category(), what);
+ attributes::attributes ()
+ : priority (-1),
+ stack_size (RTEMS_MINIMUM_STACK_SIZE),
+ mode (sched_inherit),
+ policy (sched_fifo)
+ update ();
+ attributes::attributes (const attributes& attr)
+ : name (attr.name),
+ priority (attr.priority),
+ stack_size (attr.stack_size),
+ scheduler (attr.scheduler),
+ mode (attr.mode),
+ policy (attr.policy)
+ void
+ attributes::set_name (const std::string& name_)
+ name = name_;
+ void
+ attributes::set_name (const char* name_)
+ name = name_;
+ attributes::get_name () const
+ return name;
+ void
+ attributes::set_priority (int priority_)
+ priority = priority_;
+ int
+ attributes::get_priority () const
+ return priority;
+ void
+ attributes::set_stack_size(size_t size)
+ stack_size = size;
+ size_t
+ attributes::get_stack_size () const
+ return stack_size;
+ void
+ attributes::set_scheduler (const std::string& scheduler_)
+ scheduler = scheduler_;
+ void
+ attributes::set_scheduler (const char* scheduler_)
+ attributes::get_scheduler ()
+ return scheduler;
+ attributes::sched_mode
+ attributes::get_scheduler_mode () const
+ return mode;
+ void
+ attributes::set_scheduler_policy (sched_policy policy_)
+ mode = sched_explicit;
+ policy = policy_;
+ attributes::sched_policy
+ attributes::get_scheduler_policy () const
+ return policy;
+ void
+ attributes::commit ()
+ pthread_t pid = ::pthread_self ();
+ system_error_check (::pthread_setname_np (pid, name.c_str ()),
+ "getting name");
+ int spolicy;
+ struct sched_param sched_param;
+ system_error_check (::pthread_getschedparam (::pthread_self (),
+ &spolicy,
+ &sched_param),
+ "getting scheduler parameters");
+ switch (policy) {
+ case sched_other:
+ spolicy = SCHED_OTHER;
+ break;
+ case sched_fifo:
+ spolicy = SCHED_FIFO;
+ break;
+ case sched_roundrobin:
+ spolicy = SCHED_RR;
+ break;
+ case sched_sporadic:
+ spolicy = SCHED_SPORADIC;
+ break;
+ default:
+ system_error_check (EINVAL, "get scheduler policy");
+ break;
+ sched_param.sched_priority = priority;
+ system_error_check (::pthread_setschedparam (::pthread_self (),
+ spolicy,
+ &sched_param),
+ if (!scheduler.empty ()) {
+ char sname[4] = { ' ', ' ', ' ', ' ' };
+ for (size_t c = 0; c < sizeof (sname); ++c) {
+ if (c >= scheduler.length ())
+ break;
+ sname[c] = scheduler[c];
+ rtems_name scheduler_name = rtems_build_name (sname[0],
+ sname[1],
+ sname[2],
+ sname[3]);
+ rtems_id scheduler_id;
+ runtime_error_check (::rtems_scheduler_ident (scheduler_name,
+ &scheduler_id),
+ "get scheduler id");
+ // runtime_error_check (::rtems_task_set_scheduler (RTEMS_SELF,
+ // scheduler_id,
+ // 1),
+ // "set scheduler id");
+ void
+ attributes::update ()
+ char buf[32];
+ system_error_check (::pthread_getname_np (::pthread_self (),
+ buf,
+ sizeof (buf)),
+ "getting name");
+ name = buf;
+ int spolicy;
+ &spolicy,
+ &sched_param),
+ switch (spolicy) {
+ case SCHED_OTHER:
+ policy = sched_other;
+ break;
+ case SCHED_FIFO:
+ policy = sched_fifo;
+ break;
+ case SCHED_RR:
+ policy = sched_roundrobin;
+ break;
+ case SCHED_SPORADIC:
+ policy = sched_sporadic;
+ break;
+ default:
+ break;
+ priority = sched_param.sched_priority;
+ pthread_attr_t attr;
+ system_error_check (::pthread_getattr_np (::pthread_self (), &attr),
+ "getting thread attributes");
+ system_error_check (::pthread_attr_getstacksize (&attr, &stack_size),
+ "getting stack size");
+ int inheritsched = 0;
+ system_error_check (::pthread_attr_getinheritsched (&attr, &inheritsched),
+ "getting inherited sheduler mode");
+ switch (inheritsched) {
+ case PTHREAD_INHERIT_SCHED:
+ mode = sched_inherit;
+ break;
+ case PTHREAD_EXPLICIT_SCHED:
+ break;
+ default:
+ system_error_check (EINVAL, "get scheduler mode");
+ break;
+ runtime_error_check (::rtems_task_get_scheduler (RTEMS_SELF, &scheduler_id));
+ char name[5];
+ if (!get_scheduler_name (scheduler_id, &name[0]))
+ system_error_check (ENOENT, "get scheduler name");
+ scheduler = name;
+#endif
+ attributes&
+ attributes::operator= (const attributes& attr)
+ name = attr.name;
+ priority = attr.priority;
+ stack_size = attr.stack_size;
+ mode = attr.mode;
+ policy = attr.policy;
+ return *this;
+ bool
+ attributes::operator== (const attributes& attr) const
+ return
+ name == attr.name &&
+ priority == attr.priority &&
+ stack_size == attr.stack_size &&
+ mode == attr.mode &&
+ policy == attr.policy;
+ void*
+ thread_generic_entry (void* arg)
+ thread::state_ptr s{ static_cast<thread::state_base*> (arg) };
+ try {
+ s->run ();
+ } catch (...) {
+ std::terminate ();
+ return nullptr;
+ thread&
+ thread::operator= (thread&& thread_)
+ if (joinable ())
+ swap(thread_);
+ return *this;
+ void
+ thread::swap(thread& thread_) noexcept
+ std::swap(id_, thread_.id_);
+ bool
+ thread::joinable() const noexcept
+ return !(id_ == id());
+ thread::state_base::~state_base () = default;
+ void
+ thread::start_thread (thread::state_ptr s)
+ const attributes attr = s->get_attributes ();
+ pthread_attr_t pattr;
+ system_error_check (::pthread_attr_init (&pattr),
+ "attribute init");
+ system_error_check (::pthread_attr_setdetachstate (&pattr,
+ PTHREAD_CREATE_DETACHED),
+ "set detached state");
+ struct sched_param param;
+ param.sched_priority = attr.get_priority ();
+ system_error_check (::pthread_attr_setschedparam (&pattr, ¶m),
+ "set ");
+ int spolicy;
+ switch (attr.get_scheduler_policy ()) {
+ case attributes::sched_other:
+ break;
+ case attributes::sched_roundrobin:
+ break;
+ case attributes::sched_sporadic:
+ break;
+ default:
+ break;
+ system_error_check (::pthread_attr_setschedpolicy (&pattr, spolicy),
+ "set scheduler policy");
+ if (attr.get_scheduler_mode () == attributes::sched_inherit)
+ ::pthread_attr_setinheritsched (&pattr, PTHREAD_INHERIT_SCHED);
+ else
+ ::pthread_attr_setinheritsched (&pattr, PTHREAD_EXPLICIT_SCHED);
+ system_error_check (::pthread_attr_setstacksize(&pattr,
+ attr.get_stack_size ()),
+ "set stack size");
+ * Hold the new thread in the state's run handler until the rest
+ * of the thread is set up after the create call.
+ system_error_check (::pthread_create (&id_.id_,
+ &pattr,
+ thread_generic_entry,
+ s.get ()),
+ "create thread");
+ system_error_check (::pthread_setname_np (id_.id_,
+ attr.get_name ().c_str ()),
+ "setting thread name");
+ ::pthread_attr_destroy (&pattr);
+ s.release ();
diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
index 3a285d03fc..91fa2d9625 100644
--- a/spec/build/cpukit/grp.yml
+++ b/spec/build/cpukit/grp.yml
@@ -27,6 +27,8 @@ links:
uid: libpppd
- role: build-dependency
uid: librtemscpu
+- role: build-dependency
+ uid: librtemscxx
uid: librtemsdfltcfg
diff --git a/spec/build/cpukit/librtemscxx.yml b/spec/build/cpukit/librtemscxx.yml
index 0000000000..769e5a7498
--- /dev/null
+++ b/spec/build/cpukit/librtemscxx.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: library
+cflags: []
+copyrights:
+- Copyright (C) 2020 Chris Johns (http://contemporary.software)
+cppflags: []
+cxxflags: [-std=c++17]
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+ source:
+ - cpukit/include/rtems/c++/error
+ - cpukit/include/rtems/c++/thread
+install-path: ${BSP_LIBDIR}
+links: []
+source:
+- cpukit/librtemscxx/error.cc
+- cpukit/librtemscxx/thread.cc
+target: rtemscxx
+type: build
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index 2b1f2727cf..b9ca014b0d 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -214,6 +214,8 @@ links:
uid: pwdgrp02
uid: rbheap01
+ uid: rcxx01
uid: read
diff --git a/spec/build/testsuites/libtests/rcxx01.yml b/spec/build/testsuites/libtests/rcxx01.yml
index 0000000000..6d69feeb83
--- /dev/null
+++ b/spec/build/testsuites/libtests/rcxx01.yml
@@ -0,0 +1,22 @@
+build-type: test-program
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+features: c cxx cxxprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/rcxx01/init.c
+- testsuites/libtests/rcxx01/thread.cc
+stlib: []
+target: testsuites/libtests/rcxx01.exe
+type: build
+use-after: []
+use-before:
+- rtemsdefaultconfig
+- rtemscxx
diff --git a/testsuites/libtests/rcxx01/init.c b/testsuites/libtests/rcxx01/init.c
index 0000000000..7febd5eb3c
--- /dev/null
+++ b/testsuites/libtests/rcxx01/init.c
@@ -0,0 +1,89 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <sys/ioctl.h>
+#include <unistd.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "RCXX 1";
+/* forward declarations to avoid warnings */
+rtems_task Init(rtems_task_argument argument);
+void rcxx_run_test(void);
+rtems_task Init(
+ rtems_task_argument ignored
+ TEST_BEGIN();
+ rcxx_run_test();
+ TEST_END();
+ rtems_test_exit( 0 );
+/* configuration information */
+#include <rtems/serial_mouse.h>
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
+#define CONFIGURE_MEMORY_OVERHEAD (2024)
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (10U * 1024U)
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#include <rtems/confdefs.h>
+/* end of file */
diff --git a/testsuites/libtests/rcxx01/rcxx01.doc b/testsuites/libtests/rcxx01/rcxx01.doc
index 0000000000..3fd41b029b
--- /dev/null
+++ b/testsuites/libtests/rcxx01/rcxx01.doc
@@ -0,0 +1,16 @@
+# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>
+This file describes the directives and concepts tested by this test set.
+test set name: rcxx01
+directives:
+ rtems::thread::thread
+ rtems::thread::attributes
+concepts:
++ Create a thread using the default method, ie like std::thread.
+* Create a thread with changed attributes.
diff --git a/testsuites/libtests/rcxx01/rcxx01.scn b/testsuites/libtests/rcxx01/rcxx01.scn
index 0000000000..37bf2d3f7a
--- /dev/null
+++ b/testsuites/libtests/rcxx01/rcxx01.scn
@@ -0,0 +1,13 @@
+*** BEGIN OF TEST RCXX 1 ***
+*** TEST VERSION: 5.0.0.7ba04a62227286dcd3da20ea7319d9c64b8f5fd1
+*** TEST STATE: EXPECTED-PASS
+*** TEST BUILD:
+*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB ceb811fa19ddcfdd449a8da8f1107e6e592727b6, Newlib d14714c69)
+Thread: start: default
+ 1 D
+Thread: start: attr
+ 2 R
+Thread: end: default
+Thread: end: attr
+*** END OF TEST RCXX 1 ***
diff --git a/testsuites/libtests/rcxx01/thread.cc b/testsuites/libtests/rcxx01/thread.cc
index 0000000000..5a29f6b779
--- /dev/null
+++ b/testsuites/libtests/rcxx01/thread.cc
@@ -0,0 +1,110 @@
+ * are met:
+#include <chrono>
+#include <thread>
+#include <mutex>
+using namespace std::chrono_literals;
+extern "C" void rcxx_run_test(void);
+struct test_thread
+ test_thread();
+ void start();
+ bool running();
+ void body(const char* title, int i, char c);
+ rtems::thread::thread thread_default;
+ rtems::thread::thread thread_attr;
+ std::mutex mutex;
+ bool finished;
+test_thread::test_thread()
+ : finished(false)
+void test_thread::start()
+ thread_default = rtems::thread::thread(&test_thread::body, this,
+ "default", 1, 'D');
+ rtems::thread::attributes attr;
+ attr.set_name("RTHREAD");
+ attr.set_priority(5);
+ attr.set_stack_size(32 * 1024);
+ thread_attr = rtems::thread::thread(attr, &test_thread::body, this,
+ "attr", 2, 'R');
+void test_thread::body(const char* title, int i, char c)
+ std::cout << "Thread: start: " << title << std::endl
+ << ' ' << i << ' ' << c << std::endl;
+ size_t count = 5;
+ while (count--) {
+ std::this_thread::sleep_for(1s);
+ std::cout << "Thread: end: " << title << std::endl;
+ std::lock_guard<std::mutex> lock(mutex);
+ finished = true;
+bool test_thread::running()
+ return finished == false;
+ try {
+ test_thread tt;
+ tt.start();
+ while (tt.running())
+ } catch (...) {
+ std::cout << "Thread: ouch" << std::endl;
+ throw;
2.24.1
