Failures from Partial BSP Build Sweep
Joel Sherrill
joel at rtems.org
Tue Oct 6 18:55:27 UTC 2020
About 1/2 of the way through and up to the PowerPC.
I know Sebastian committed some fixes so a few of these
may already be fixed. The failures reported are all ARM so far:
FAILED (2) autoconf build of arm lm3s3749 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm lm3s3749 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm lm3s3749 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm lpc2362 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm lpc2362 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm lpc2362 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of arm lpc2362 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of arm lpc23xx_tli800 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm lpc23xx_tli800 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm lpc32xx_mzx_stage_1
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/NODEBUG/NOPROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/NODEBUG/NOPROFILE)
Thanks.
--joel
On Mon, Oct 5, 2020 at 6:57 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Sebastian's fix for testopts seems to have resolved a lot of build
> failures. My build is ~220 BSPs in and this is the current set of failure
> messages:
> Given the timezones, I hope some of those can disappear before I get on in
> the morning. :)
> Full report when the sweep is finished.
> --joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201006/573e02a3/attachment.html>
