I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
Joel Sherrill
joel at rtems.org
Tue Oct 6 13:10:57 UTC 2020
Maybe Kinsey has an idea.
On Tue, Oct 6, 2020 at 1:29 AM smallphd at aliyun.com <smallphd at aliyun.com>
wrote:
> The board is Ultra96 board with JTAG boot.
> And yes, there is a bspsmp.c in rtems-5.1\bsps\arm\xilinx-zynqmp\start\
> *From:* Gedare Bloom <gedare at rtems.org>
> *Date:* 2020-10-06 00:16
> *To:* smallphd at aliyun.com
> *CC:* devel <devel at rtems.org>
> *Subject:* Re: I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
> It should, I believe. The bsp has bspsmp.c file.
> How did you configure (../rtems/configure)?
> What board/target do you run it on?
> On Mon, Oct 5, 2020 at 2:24 AM smallphd at aliyun.com <smallphd at aliyun.com>
> wrote:
> > Hi, all
> > I compile rtems 5.1 with bsp xilinx-zynqmp. The single core mode is ok.
> > But I can not use 2 or 3 or 4 cores of this bsp.
> > After analysing the source code, I found there is no code to address smp
> condition. Does rtems 5.1 indeed not support smp mode for xilinx-zynqmp bsp?
> > ________________________________
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201006/ac08d6a5/attachment.html>
