I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Oct 6 13:56:17 UTC 2020
Is it possible that the application was only started on the first core instead of all cores? Is it possible to check the execution state of the other cores?
Kinsey
Sent: Tuesday, October 6, 2020 08:11
To: smallphd at aliyun.com
Cc: Gedare Bloom <gedare at rtems.org>; devel <devel at rtems.org>; Kinsey Moore <kinsey.moore at oarcorp.com>
Subject: Re: Re: I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
Maybe Kinsey has an idea.
On Tue, Oct 6, 2020 at 1:29 AM smallphd at aliyun.com<mailto:smallphd at aliyun.com> <smallphd at aliyun.com<mailto:smallphd at aliyun.com>> wrote:
The board is Ultra96 board with JTAG boot.
And yes, there is a bspsmp.c in rtems-5.1\bsps\arm\xilinx-zynqmp\start\
________________________________
Date: 2020-10-06 00:16
To: smallphd at aliyun.com<mailto:smallphd at aliyun.com>
CC: devel<mailto:devel at rtems.org>
Subject: Re: I can not run rtems 5.1 smp correctly on bsp xilinx-zynqmp
It should, I believe. The bsp has bspsmp.c file.
How did you configure (../rtems/configure)?
What board/target do you run it on?
On Mon, Oct 5, 2020 at 2:24 AM smallphd at aliyun.com<mailto:smallphd at aliyun.com> <smallphd at aliyun.com<mailto:smallphd at aliyun.com>> wrote:
> Hi, all
> I compile rtems 5.1 with bsp xilinx-zynqmp. The single core mode is ok.
> But I can not use 2 or 3 or 4 cores of this bsp.
> After analysing the source code, I found there is no code to address smp condition. Does rtems 5.1 indeed not support smp mode for xilinx-zynqmp bsp?
> devel mailing list
> devel at rtems.org<mailto:devel at rtems.org>
devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201006/01722e05/attachment-0001.html>
