[PATCH] rtems: Improve RTEMS_NO_RETURN attribute
Sebastian Huber
Tue Oct 6 15:40:56 UTC 2020
On 06/10/2020 17:34, Joel Sherrill wrote:
> On Tue, Oct 6, 2020 at 9:46 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 06/10/2020 16:37, Joel Sherrill wrote:
> > How does it break the API? It looks like a change of annotation.
> > Shouldn't be a big deal unless I am misunderstanding something.
> Please have a look at:
> https://lists.rtems.org/pipermail/devel/2020-October/062577.html
> Looks like basically the same code. What does this break? Why the concern?
The C11/C++11 attribute syntax is less flexible compared to the GNU
attributes. For example:
echo "_Noreturn void ok(void);" > test.c
echo "void error(void) _Noreturn;" >> test.c
gcc test.c
test.c: In function ‘error’:
test.c:2:1: error: ‘_Noreturn’ in empty declaration
test.c:2:18: warning: empty declaration
test.c:2:1: error: expected ‘{’ at end of input
