[PATCH v3] c-user: Generate I/O Manager documentation
Tue Oct 6 17:40:21 UTC 2020
On 06/10/2020 19:33, Sebastian Huber wrote:
> On 06/10/2020 19:04, Sebastian Huber wrote:
>> On 06/10/2020 17:06, Gedare Bloom wrote:
>>> I just have one minor complaint now. In the HTML, I don't like that
>>> "RETURN VALUES:"
>>> appears to be about the same size/level/style as each of the list
>>> elements below it. If you can make them more distinctive that would be
>>> great. The PDF list isn't as bad because of the whitespace for the
>>> list grouping.
>> I think this can be done via the CSS:
>> build/c-user/html/partition/directives.html:<p class="rubric">RETURN
>> VALUES:</p>
>> I don't know off hand how this works.
> Another approach is to format the values as ``value``. This changes
> the font in the output. Additionally, in the HTML output the font
> colour is greenish.
It looks good from my point of view. The formatting is now consistent
with the formatting in the text.
Generated PDF:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user-7.pdf
Generated HTML:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user/html/index.html
