[PATCH v3] c-user: Generate I/O Manager documentation
Tue Oct 6 22:07:39 UTC 2020
On 7/10/20 4:40 am, Sebastian Huber wrote:
> On 06/10/2020 19:33, Sebastian Huber wrote:
>> On 06/10/2020 19:04, Sebastian Huber wrote:
>>> On 06/10/2020 17:06, Gedare Bloom wrote:
>>>> I just have one minor complaint now. In the HTML, I don't like that
>>>> "RETURN VALUES:"
>>>> appears to be about the same size/level/style as each of the list
>>>> elements below it. If you can make them more distinctive that would be
>>>> great. The PDF list isn't as bad because of the whitespace for the
>>>> list grouping.
>>> I think this can be done via the CSS:
>>> build/c-user/html/partition/directives.html:<p class="rubric">RETURN VALUES:</p>
>>> I don't know off hand how this works.
>> Another approach is to format the values as ``value``. This changes the font
>> in the output. Additionally, in the HTML output the font colour is greenish.
> It looks good from my point of view. The formatting is now consistent with the
> formatting in the text.
> Generated PDF:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user-7.pdf
> Generated HTML:
> https://ftp.rtems.org/pub/rtems/people/sebh/c-user/html/index.html
Looks good.
