[PATCH 1/2] rtems: Add "Generated from ..." comments
Wed Oct 7 10:14:47 UTC 2020
Improve file header comment.
Update #3993.
 cpukit/include/rtems.h | 17 +++++++++++++----
 1 file changed, 13 insertions(+), 4 deletions(-)
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index cda2bd5b24..9b0765efda 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -35,14 +35,21 @@
- * This file was automatically generated.  Do not edit it manually.
- * Please have a look at
+ * Do not manually edit this file.  It is part of the RTEMS quality process
+ * and was automatically generated.
- * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
- * for information how to maintain and re-generate this file.
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
+/* Generated from spec:/rtems/if/header */
 #ifndef _RTEMS_H
 #define _RTEMS_H
@@ -79,6 +86,8 @@
 extern "C" {
 #endif
+/* Generated from spec:/rtems/if/group */
  * @defgroup RTEMSAPIClassic Classic
2.26.2
