[PATCH 2/2] doxygen: Add "Generated from ..." comments
Sebastian Huber
Wed Oct 7 10:14:48 UTC 2020
Improve file header comment.
Update #3994.
cpukit/doxygen/appl-config.h | 343 ++++++++++++++++++++++++++++++++++-
1 file changed, 339 insertions(+), 4 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index eb9bf72abf..fe567b6e0f 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -28,12 +28,17 @@
- * This file was automatically generated. Do not edit it manually.
- * Please have a look at
+ * Do not manually edit this file. It is part of the RTEMS quality process
+ * and was automatically generated.
- * https://docs.rtems.org/branches/master/eng/req/howto.html
+ * If you find something that needs to be fixed or worded better please
+ * post a report to an RTEMS mailing list or raise a bug report:
+ * https://docs.rtems.org/branches/master/user/support/bugs.html
+ * For information on updating and regenerating please refer to:
- * for information how to maintain and re-generate this file.
+ * https://docs.rtems.org/branches/master/eng/req/howto.html
@@ -42,6 +47,8 @@
* @ingroup RTEMSAPI
+/* Generated from spec:/acfg/if/group-bdbuf */
* @defgroup RTEMSApplConfigBlockDeviceCacheConfiguration \
* Block Device Cache Configuration
@@ -54,6 +61,8 @@
+/* Generated from spec:/acfg/if/appl-needs-libblock */
* @brief This configuration option is a boolean feature define.
@@ -71,6 +80,8 @@
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+/* Generated from spec:/acfg/if/bdbuf-buffer-max-size */
* @brief This configuration option is an integer define.
@@ -92,6 +103,8 @@
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
+/* Generated from spec:/acfg/if/bdbuf-buffer-min-size */
@@ -108,6 +121,8 @@
#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE
+/* Generated from spec:/acfg/if/bdbuf-cache-memory-size */
@@ -124,6 +139,8 @@
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
+/* Generated from spec:/acfg/if/bdbuf-max-read-ahead-blocks */
@@ -145,6 +162,8 @@
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
+/* Generated from spec:/acfg/if/bdbuf-max-write-blocks */
@@ -161,6 +180,8 @@
#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
+/* Generated from spec:/acfg/if/bdbuf-read-ahead-task-priority */
@@ -175,6 +196,8 @@
#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
+/* Generated from spec:/acfg/if/bdbuf-task-stack-size */
@@ -202,6 +225,8 @@
#define CONFIGURE_BDBUF_TASK_STACK_SIZE
+/* Generated from spec:/acfg/if/bdbuf-swapout-block-hold */
@@ -218,6 +243,8 @@
#define CONFIGURE_SWAPOUT_BLOCK_HOLD
+/* Generated from spec:/acfg/if/bdbuf-swapout-swap-period */
@@ -234,6 +261,8 @@
#define CONFIGURE_SWAPOUT_SWAP_PERIOD
+/* Generated from spec:/acfg/if/bdbuf-swapout-task-priority */
@@ -248,6 +277,8 @@
#define CONFIGURE_SWAPOUT_TASK_PRIORITY
+/* Generated from spec:/acfg/if/bdbuf-swapout-worker-tasks */
@@ -264,6 +295,8 @@
#define CONFIGURE_SWAPOUT_WORKER_TASKS
+/* Generated from spec:/acfg/if/bdbuf-swapout-worker-taskp-riority */
@@ -281,6 +314,8 @@
+/* Generated from spec:/acfg/if/group-bsp */
* @defgroup RTEMSApplConfigBSPRelatedConfigurationOptions \
* BSP Related Configuration Options
@@ -295,6 +330,8 @@
+/* Generated from spec:/acfg/if/bsp-idle-task-body */
* @brief This configuration option is an initializer define.
@@ -321,6 +358,8 @@
#define BSP_IDLE_TASK_BODY
+/* Generated from spec:/acfg/if/bsp-idle-task-stack-size */
@@ -351,6 +390,8 @@
#define BSP_IDLE_TASK_STACK_SIZE
+/* Generated from spec:/acfg/if/bsp-initial-extension */
@@ -376,6 +417,8 @@
#define BSP_INITIAL_EXTENSION
+/* Generated from spec:/acfg/if/bsp-interrupt-stack-size */
@@ -408,6 +451,8 @@
#define BSP_INTERRUPT_STACK_SIZE
+/* Generated from spec:/acfg/if/bsp-prerequisite-drivers */
@@ -434,6 +479,8 @@
#define CONFIGURE_BSP_PREREQUISITE_DRIVERS
+/* Generated from spec:/acfg/if/disable-bsp-settings */
@@ -458,6 +505,8 @@
#define CONFIGURE_DISABLE_BSP_SETTINGS
+/* Generated from spec:/acfg/if/malloc-bsp-supports-sbrk */
@@ -484,6 +533,8 @@
+/* Generated from spec:/acfg/if/group-classic */
* @defgroup RTEMSApplConfigClassicAPIConfiguration Classic API Configuration
@@ -494,6 +545,8 @@
+/* Generated from spec:/acfg/if/max-barriers */
@@ -529,6 +582,8 @@
#define CONFIGURE_MAXIMUM_BARRIERS
+/* Generated from spec:/acfg/if/max-message-queues */
@@ -565,6 +620,8 @@
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+/* Generated from spec:/acfg/if/max-partitions */
@@ -600,6 +657,8 @@
#define CONFIGURE_MAXIMUM_PARTITIONS
+/* Generated from spec:/acfg/if/max-periods */
@@ -635,6 +694,8 @@
#define CONFIGURE_MAXIMUM_PERIODS
+/* Generated from spec:/acfg/if/max-ports */
@@ -670,6 +731,8 @@
#define CONFIGURE_MAXIMUM_PORTS
+/* Generated from spec:/acfg/if/max-regions */
@@ -705,6 +768,8 @@
#define CONFIGURE_MAXIMUM_REGIONS
+/* Generated from spec:/acfg/if/max-semaphores */
@@ -749,6 +814,8 @@
#define CONFIGURE_MAXIMUM_SEMAPHORES
+/* Generated from spec:/acfg/if/max-tasks */
@@ -803,6 +870,8 @@
#define CONFIGURE_MAXIMUM_TASKS
+/* Generated from spec:/acfg/if/max-thread-local-storage-size */
@@ -840,6 +909,8 @@
#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
+/* Generated from spec:/acfg/if/max-timers */
@@ -875,6 +946,8 @@
#define CONFIGURE_MAXIMUM_TIMERS
+/* Generated from spec:/acfg/if/max-user-extensions */
@@ -903,6 +976,8 @@
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
+/* Generated from spec:/acfg/if/min-tasks-with-user-provided-storage */
@@ -927,6 +1002,8 @@
+/* Generated from spec:/acfg/if/group-classicinit */
* @defgroup RTEMSApplConfigClassicAPIInitializationTaskConfiguration \
* Classic API Initialization Task Configuration
@@ -939,6 +1016,8 @@
+/* Generated from spec:/acfg/if/init-task-arguments */
@@ -954,6 +1033,8 @@
#define CONFIGURE_INIT_TASK_ARGUMENTS
+/* Generated from spec:/acfg/if/init-task-attributes */
@@ -968,6 +1049,8 @@
#define CONFIGURE_INIT_TASK_ATTRIBUTES
+/* Generated from spec:/acfg/if/init-task-entrypoint */
@@ -987,6 +1070,8 @@
#define CONFIGURE_INIT_TASK_ENTRY_POINT
+/* Generated from spec:/acfg/if/init-task-initial-modes */
@@ -1002,6 +1087,8 @@
#define CONFIGURE_INIT_TASK_INITIAL_MODES
+/* Generated from spec:/acfg/if/init-task-name */
@@ -1020,6 +1107,8 @@
#define CONFIGURE_INIT_TASK_NAME
+/* Generated from spec:/acfg/if/init-task-priority */
@@ -1035,6 +1124,8 @@
#define CONFIGURE_INIT_TASK_PRIORITY
+/* Generated from spec:/acfg/if/init-task-stack-size */
@@ -1058,6 +1149,8 @@
#define CONFIGURE_INIT_TASK_STACK_SIZE
+/* Generated from spec:/acfg/if/rtems-init-tasks-table */
@@ -1086,6 +1179,8 @@
+/* Generated from spec:/acfg/if/group-devdrv */
* @defgroup RTEMSApplConfigDeviceDriverConfiguration \
* Device Driver Configuration
@@ -1098,6 +1193,8 @@
+/* Generated from spec:/acfg/if/appl-does-not-need-clock-driver */
@@ -1128,6 +1225,8 @@
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+/* Generated from spec:/acfg/if/appl-extra-drivers */
@@ -1152,6 +1251,8 @@
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
+/* Generated from spec:/acfg/if/appl-needs-ata-driver */
@@ -1172,6 +1273,8 @@
#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-clock-driver */
@@ -1201,6 +1304,8 @@
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-console-driver */
@@ -1233,6 +1338,8 @@
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-framebuffer-driver */
@@ -1254,6 +1361,8 @@
#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-ide-driver */
@@ -1274,6 +1383,8 @@
#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-null-driver */
@@ -1289,6 +1400,8 @@
#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-rtc-driver */
@@ -1310,6 +1423,8 @@
#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-simple-console-driver */
@@ -1346,6 +1461,8 @@
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-simple-task-console-driver */
@@ -1391,6 +1508,8 @@
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-stub-driver */
@@ -1407,6 +1526,8 @@
#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-timer-driver */
@@ -1436,6 +1557,8 @@
#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-watchdog-driver */
@@ -1457,6 +1580,8 @@
#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+/* Generated from spec:/acfg/if/appl-needs-zero-driver */
@@ -1472,6 +1597,8 @@
#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+/* Generated from spec:/acfg/if/appl-prerequisite-drivers */
@@ -1497,6 +1624,8 @@
#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
+/* Generated from spec:/acfg/if/ata-driver-task-priority */
@@ -1515,6 +1644,8 @@
#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
+/* Generated from spec:/acfg/if/max-drivers */
@@ -1586,6 +1717,8 @@
+/* Generated from spec:/acfg/if/group-eventrecord */
* @defgroup RTEMSApplConfigEventRecordingConfiguration \
* Event Recording Configuration
@@ -1597,6 +1730,8 @@
+/* Generated from spec:/acfg/if/record-extensions-enabled */
@@ -1618,6 +1753,8 @@
#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
+/* Generated from spec:/acfg/if/record-fatal-dump-base64 */
@@ -1643,6 +1780,8 @@
#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
+/* Generated from spec:/acfg/if/record-fatal-dump-base64-zlib */
@@ -1667,6 +1806,8 @@
#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
+/* Generated from spec:/acfg/if/record-per-processor-items */
@@ -1702,6 +1843,8 @@
+/* Generated from spec:/acfg/if/group-filesystem */
* @defgroup RTEMSApplConfigFilesystemConfiguration Filesystem Configuration
@@ -1752,6 +1895,8 @@
+/* Generated from spec:/acfg/if/appl-disable-filesystem */
@@ -1770,6 +1915,8 @@
#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+/* Generated from spec:/acfg/if/filesystem-all */
@@ -1796,6 +1943,8 @@
#define CONFIGURE_FILESYSTEM_ALL
+/* Generated from spec:/acfg/if/filesystem-dosfs */
@@ -1813,6 +1962,8 @@
#define CONFIGURE_FILESYSTEM_DOSFS
+/* Generated from spec:/acfg/if/filesystem-ftpfs */
@@ -1826,6 +1977,8 @@
#define CONFIGURE_FILESYSTEM_FTPFS
+/* Generated from spec:/acfg/if/filesystem-imfs */
@@ -1845,6 +1998,8 @@
#define CONFIGURE_FILESYSTEM_IMFS
+/* Generated from spec:/acfg/if/filesystem-jffs2 */
@@ -1858,6 +2013,8 @@
#define CONFIGURE_FILESYSTEM_JFFS2
+/* Generated from spec:/acfg/if/filesystem-nfs */
@@ -1871,6 +2028,8 @@
#define CONFIGURE_FILESYSTEM_NFS
+/* Generated from spec:/acfg/if/filesystem-rfs */
@@ -1888,6 +2047,8 @@
#define CONFIGURE_FILESYSTEM_RFS
+/* Generated from spec:/acfg/if/filesystem-tftpfs */
@@ -1901,6 +2062,8 @@
#define CONFIGURE_FILESYSTEM_TFTPFS
+/* Generated from spec:/acfg/if/imfs-disable-chmod */
@@ -1913,6 +2076,8 @@
#define CONFIGURE_IMFS_DISABLE_CHMOD
+/* Generated from spec:/acfg/if/imfs-disable-chown */
@@ -1925,6 +2090,8 @@
#define CONFIGURE_IMFS_DISABLE_CHOWN
+/* Generated from spec:/acfg/if/imfs-disable-link */
@@ -1937,6 +2104,8 @@
#define CONFIGURE_IMFS_DISABLE_LINK
+/* Generated from spec:/acfg/if/imfs-disable-mknod */
@@ -1949,6 +2118,8 @@
#define CONFIGURE_IMFS_DISABLE_MKNOD
+/* Generated from spec:/acfg/if/imfs-disable-mknod-device */
@@ -1961,6 +2132,8 @@
#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
+/* Generated from spec:/acfg/if/imfs-disable-mknod-file */
@@ -1973,6 +2146,8 @@
#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+/* Generated from spec:/acfg/if/imfs-disable-mount */
@@ -1985,6 +2160,8 @@
#define CONFIGURE_IMFS_DISABLE_MOUNT
+/* Generated from spec:/acfg/if/imfs-disable-readdir */
@@ -1998,6 +2175,8 @@
#define CONFIGURE_IMFS_DISABLE_READDIR
+/* Generated from spec:/acfg/if/imfs-disable-readlink */
@@ -2010,6 +2189,8 @@
#define CONFIGURE_IMFS_DISABLE_READLINK
+/* Generated from spec:/acfg/if/imfs-disable-rename */
@@ -2022,6 +2203,8 @@
#define CONFIGURE_IMFS_DISABLE_RENAME
+/* Generated from spec:/acfg/if/imfs-disable-rmnod */
@@ -2034,6 +2217,8 @@
#define CONFIGURE_IMFS_DISABLE_RMNOD
+/* Generated from spec:/acfg/if/imfs-disable-symlink */
@@ -2046,6 +2231,8 @@
#define CONFIGURE_IMFS_DISABLE_SYMLINK
+/* Generated from spec:/acfg/if/imfs-disable-unmount */
@@ -2058,6 +2245,8 @@
#define CONFIGURE_IMFS_DISABLE_UNMOUNT
+/* Generated from spec:/acfg/if/imfs-disable-utime */
@@ -2070,6 +2259,8 @@
#define CONFIGURE_IMFS_DISABLE_UTIME
+/* Generated from spec:/acfg/if/imfs-enable-mkfifo */
@@ -2082,6 +2273,8 @@
#define CONFIGURE_IMFS_ENABLE_MKFIFO
+/* Generated from spec:/acfg/if/imfs-memfile-bytes-per-block */
@@ -2128,6 +2321,8 @@
#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
+/* Generated from spec:/acfg/if/use-devfs-as-base-filesystem */
@@ -2177,6 +2372,8 @@
#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+/* Generated from spec:/acfg/if/use-miniimfs-as-base-filesystem */
@@ -2213,6 +2410,8 @@
+/* Generated from spec:/acfg/if/group-general */
* @defgroup RTEMSApplConfigGeneralSystemConfiguration \
* General System Configuration
@@ -2224,6 +2423,8 @@
+/* Generated from spec:/acfg/if/dirty-memory */
@@ -2248,6 +2449,8 @@
#define CONFIGURE_DIRTY_MEMORY
+/* Generated from spec:/acfg/if/disable-newlib-reentrancy */
@@ -2266,6 +2469,8 @@
#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+/* Generated from spec:/acfg/if/executive-ram-size */
@@ -2298,6 +2503,8 @@
#define CONFIGURE_EXECUTIVE_RAM_SIZE
+/* Generated from spec:/acfg/if/extra-task-stacks */
@@ -2327,6 +2534,8 @@
#define CONFIGURE_EXTRA_TASK_STACKS
+/* Generated from spec:/acfg/if/initial-extensions */
@@ -2347,6 +2556,8 @@
#define CONFIGURE_INITIAL_EXTENSIONS
+/* Generated from spec:/acfg/if/interrupt-stack-size */
@@ -2393,6 +2604,8 @@
#define CONFIGURE_INTERRUPT_STACK_SIZE
+/* Generated from spec:/acfg/if/malloc-dirty */
@@ -2412,6 +2625,8 @@
#define CONFIGURE_MALLOC_DIRTY
+/* Generated from spec:/acfg/if/max-file-descriptors */
@@ -2442,6 +2657,8 @@
#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
+/* Generated from spec:/acfg/if/max-processors */
@@ -2470,6 +2687,8 @@
#define CONFIGURE_MAXIMUM_PROCESSORS
+/* Generated from spec:/acfg/if/max-thread-name-size */
@@ -2507,6 +2726,8 @@
#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
+/* Generated from spec:/acfg/if/memory-overhead */
@@ -2542,6 +2763,8 @@
#define CONFIGURE_MEMORY_OVERHEAD
+/* Generated from spec:/acfg/if/message-buffer-memory */
@@ -2617,6 +2840,8 @@
#define CONFIGURE_MESSAGE_BUFFER_MEMORY
+/* Generated from spec:/acfg/if/microseconds-per-tick */
@@ -2664,6 +2889,8 @@
#define CONFIGURE_MICROSECONDS_PER_TICK
+/* Generated from spec:/acfg/if/min-task-stack-size */
@@ -2711,6 +2938,8 @@
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
+/* Generated from spec:/acfg/if/stack-checker-enabled */
@@ -2732,6 +2961,8 @@
#define CONFIGURE_STACK_CHECKER_ENABLED
+/* Generated from spec:/acfg/if/ticks-per-time-slice */
@@ -2752,6 +2983,8 @@
#define CONFIGURE_TICKS_PER_TIMESLICE
+/* Generated from spec:/acfg/if/unified-work-areas */
@@ -2777,6 +3010,8 @@
#define CONFIGURE_UNIFIED_WORK_AREAS
+/* Generated from spec:/acfg/if/unlimited-allocation-size */
@@ -2805,6 +3040,8 @@
#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE
+/* Generated from spec:/acfg/if/unlimited-objects */
@@ -2829,6 +3066,8 @@
#define CONFIGURE_UNLIMITED_OBJECTS
+/* Generated from spec:/acfg/if/verbose-system-init */
@@ -2845,6 +3084,8 @@
#define CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
+/* Generated from spec:/acfg/if/zero-workspace-automatically */
@@ -2866,6 +3107,8 @@
+/* Generated from spec:/acfg/if/group-idle */
* @defgroup RTEMSApplConfigIdleTaskConfiguration Idle Task Configuration
@@ -2876,6 +3119,8 @@
+/* Generated from spec:/acfg/if/idle-task-body */
@@ -2901,6 +3146,8 @@
#define CONFIGURE_IDLE_TASK_BODY
+/* Generated from spec:/acfg/if/idle-task-init-appl */
@@ -2940,6 +3187,8 @@
#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+/* Generated from spec:/acfg/if/idle-task-stack-size */
@@ -2970,6 +3219,8 @@
+/* Generated from spec:/acfg/if/group-mpci */
* @defgroup RTEMSApplConfigMultiprocessingConfiguration \
* Multiprocessing Configuration
@@ -2986,6 +3237,8 @@
+/* Generated from spec:/acfg/if/mp-extra-server-stack */
@@ -3018,6 +3271,8 @@
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
+/* Generated from spec:/acfg/if/mp-appl */
@@ -3037,6 +3292,8 @@
#define CONFIGURE_MP_APPLICATION
+/* Generated from spec:/acfg/if/mp-max-global-objects */
@@ -3062,6 +3319,8 @@
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
+/* Generated from spec:/acfg/if/mp-max-nodes */
@@ -3082,6 +3341,8 @@
#define CONFIGURE_MP_MAXIMUM_NODES
+/* Generated from spec:/acfg/if/mp-max-proxies */
@@ -3110,6 +3371,8 @@
#define CONFIGURE_MP_MAXIMUM_PROXIES
+/* Generated from spec:/acfg/if/mp-mpci-table-pointer */
@@ -3135,6 +3398,8 @@
#define CONFIGURE_MP_MPCI_TABLE_POINTER
+/* Generated from spec:/acfg/if/mp-node-number */
@@ -3164,6 +3429,8 @@
+/* Generated from spec:/acfg/if/group-posix */
* @defgroup RTEMSApplConfigPOSIXAPIConfiguration POSIX API Configuration
@@ -3177,6 +3444,8 @@
+/* Generated from spec:/acfg/if/max-posix-keys */
@@ -3212,6 +3481,8 @@
#define CONFIGURE_MAXIMUM_POSIX_KEYS
+/* Generated from spec:/acfg/if/max-posix-key-value-pairs */
@@ -3254,6 +3525,8 @@
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+/* Generated from spec:/acfg/if/max-posix-message-queues */
@@ -3294,6 +3567,8 @@
#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+/* Generated from spec:/acfg/if/max-posix-queued-signals */
@@ -3333,6 +3608,8 @@
#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+/* Generated from spec:/acfg/if/max-posix-semaphores */
@@ -3378,6 +3655,8 @@
#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+/* Generated from spec:/acfg/if/max-posix-shms */
@@ -3417,6 +3696,8 @@
#define CONFIGURE_MAXIMUM_POSIX_SHMS
+/* Generated from spec:/acfg/if/max-posix-threads */
@@ -3464,6 +3745,8 @@
#define CONFIGURE_MAXIMUM_POSIX_THREADS
+/* Generated from spec:/acfg/if/max-posix-timers */
@@ -3508,6 +3791,8 @@
#define CONFIGURE_MAXIMUM_POSIX_TIMERS
+/* Generated from spec:/acfg/if/min-posix-thread-stack-size */
@@ -3535,6 +3820,8 @@
+/* Generated from spec:/acfg/if/group-posixinit */
* @defgroup RTEMSApplConfigPOSIXInitializationThreadConfiguration \
* POSIX Initialization Thread Configuration
@@ -3547,6 +3834,8 @@
+/* Generated from spec:/acfg/if/posix-init-thread-entry-point */
@@ -3566,6 +3855,8 @@
#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+/* Generated from spec:/acfg/if/posix-init-thread-stack-size */
@@ -3589,6 +3880,8 @@
#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+/* Generated from spec:/acfg/if/posix-init-thread-table */
@@ -3617,6 +3910,8 @@
+/* Generated from spec:/acfg/if/group-schedgeneral */
* @defgroup RTEMSApplConfigGeneralSchedulerConfiguration \
* General Scheduler Configuration
@@ -3651,6 +3946,8 @@
+/* Generated from spec:/acfg/if/cbs-max-servers */
@@ -3681,6 +3978,8 @@
#define CONFIGURE_CBS_MAXIMUM_SERVERS
+/* Generated from spec:/acfg/if/max-priority */
@@ -3737,6 +4036,8 @@
#define CONFIGURE_MAXIMUM_PRIORITY
+/* Generated from spec:/acfg/if/scheduler-assignments */
@@ -3772,6 +4073,8 @@
#define CONFIGURE_SCHEDULER_ASSIGNMENTS
+/* Generated from spec:/acfg/if/scheduler-cbs */
@@ -3797,6 +4100,8 @@
#define CONFIGURE_SCHEDULER_CBS
+/* Generated from spec:/acfg/if/scheduler-edf */
@@ -3821,6 +4126,8 @@
#define CONFIGURE_SCHEDULER_EDF
+/* Generated from spec:/acfg/if/scheduler-edf-smp */
@@ -3852,6 +4159,8 @@
#define CONFIGURE_SCHEDULER_EDF_SMP
+/* Generated from spec:/acfg/if/scheduler-name */
@@ -3911,6 +4220,8 @@
#define CONFIGURE_SCHEDULER_NAME
+/* Generated from spec:/acfg/if/scheduler-priority */
@@ -3941,6 +4252,8 @@
#define CONFIGURE_SCHEDULER_PRIORITY
+/* Generated from spec:/acfg/if/scheduler-priority-affinity-smp */
@@ -3972,6 +4285,8 @@
#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+/* Generated from spec:/acfg/if/scheduler-priority-smp */
@@ -4002,6 +4317,8 @@
#define CONFIGURE_SCHEDULER_PRIORITY_SMP
+/* Generated from spec:/acfg/if/scheduler-simple */
@@ -4026,6 +4343,8 @@
#define CONFIGURE_SCHEDULER_SIMPLE
+/* Generated from spec:/acfg/if/scheduler-simple-smp */
@@ -4054,6 +4373,8 @@
#define CONFIGURE_SCHEDULER_SIMPLE_SMP
+/* Generated from spec:/acfg/if/scheduler-strong-apa */
@@ -4077,6 +4398,8 @@
#define CONFIGURE_SCHEDULER_STRONG_APA
+/* Generated from spec:/acfg/if/scheduler-user */
@@ -4119,6 +4442,8 @@
+/* Generated from spec:/acfg/if/group-stackalloc */
* @defgroup RTEMSApplConfigTaskStackAllocatorConfiguration \
* Task Stack Allocator Configuration
@@ -4134,6 +4459,8 @@
+/* Generated from spec:/acfg/if/task-stack-allocator */
@@ -4162,6 +4489,8 @@
#define CONFIGURE_TASK_STACK_ALLOCATOR
+/* Generated from spec:/acfg/if/task-stack-no-workspace */
@@ -4178,6 +4507,8 @@
#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
+/* Generated from spec:/acfg/if/task-stack-allocator-init */
@@ -4207,6 +4538,8 @@
#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+/* Generated from spec:/acfg/if/task-stack-deallocator */
@@ -4235,6 +4568,8 @@
#define CONFIGURE_TASK_STACK_DEALLOCATOR
+/* Generated from spec:/acfg/if/task-stack-from-alloc */
2.26.2
