BSP Build Sweep (7 Oct 2020)
Joel Sherrill
joel at rtems.org
Wed Oct 7 13:54:09 UTC 2020
Hi
Results from the sweep that just finished. It is clear that since this
takes ~42 hours to run that it tends to have failures which were fixed in
the almost 2 days it takes for this to finish.
Total: 1744 all-bsps-log.txt
Passed: 1657
Failed: 87
Failed autoconf: 60
Failed waf: 27
Failed (NOSMP): 67
I attached the complete summary log and the failed log. It looks like the
sweep should ignore the risv*_clang BSPs in autoconf, x86_64 failures that
Sebastian says should be fixed, and raspberry pi failures which are because
Pi doesn't support SMP. That still leaves 43 failures to account for.
About half of those appear to be a build failure in griscv BSPs (#4128).
Others are scattered across arm.
I'm going to hold off starting another sweep until later in the day to give
anyone a chance to quickly poke at them.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201007/eb34ec44/attachment-0001.html>
FAILED (2) autoconf build of arm lm3s3749 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm lm3s3749 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm lm3s3749 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm lpc2362 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm lpc2362 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm lpc2362 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of arm lpc2362 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of arm lpc23xx_tli800 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm lpc23xx_tli800 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm lpc32xx_mzx_stage_1 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm lpc32xx_mzx_stage_1 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of arm raspberrypi (SMP/NOMP/NODEBUG/NOPROFILE)
FAILED (1) waf build of arm raspberrypi (SMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv griscv (SMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv griscv (SMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv griscv (SMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv griscv (SMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv griscv (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv griscv (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv griscv (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv griscv (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32i (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv grv32i (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32i (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv grv32i (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32im (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv grv32im (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32im (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv grv32im (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imac (SMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imac (SMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imac (SMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imac (SMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imac (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imac (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imac (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imac (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imafdc (SMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imafdc (SMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imafdc (SMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imafdc (SMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imafdc (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imafdc (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv grv32imafdc (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (1) waf build of riscv grv32imafdc (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32i_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32i_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32i_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32i_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32iac_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32iac_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32iac_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32iac_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32im_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32im_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32im_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32im_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imac_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imac_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imac_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imac_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imafc_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imafc_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imafc_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imafc_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imafd_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imafd_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imafd_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imafd_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imafdc_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imafdc_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv32imafdc_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv32imafdc_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv64imafdc_clang (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv64imafdc_clang (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (2) autoconf build of riscv rv64imafdc_clang (NOSMP/NOMP/NODEBUG/PROFILE)
FAILED (2) autoconf build of riscv rv64imafdc_clang (NOSMP/NOMP/NODEBUG/NOPROFILE)
FAILED (2) autoconf build of x86_64 amd64 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (1) waf build of x86_64 amd64 (NOSMP/NOMP/DEBUG/PROFILE)
FAILED (2) autoconf build of x86_64 amd64 (NOSMP/NOMP/DEBUG/NOPROFILE)
FAILED (1) waf build of x86_64 amd64 (NOSMP/NOMP/DEBUG/NOPROFILE)
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201007/eb34ec44/attachment-0001.obj>
