[PATCH v2] rtems: Generate <rtems/io.h>
Wed Oct 7 17:40:18 UTC 2020
On 07/10/2020 17:26, Gedare Bloom wrote:
> Thinking about the discussion about ordering directives in the docs,
> the generated header reorders directives also. Is it also doing
> generation by alphabetical order?
> Should we consider using the same order as defined for the API
> documentation? I guess this would make the Doxygen consistently
> ordered wrt the docs.
This would make things a lot more complicated. For the Doxygen we have
to take also the C language into account. For example before you use a
type, it must be declared. This is done through automatic dependency
tracking and a topological sorting. Adding a manual order into this
stuff would be difficult.
