[PATCH 2/2] testsuite/rcxx01: Add examples for use in the User manual
chrisj at rtems.org
chrisj at rtems.org
Thu Oct 8 08:19:34 UTC 2020
spec/build/testsuites/libtests/rcxx01.yml | 3 +
testsuites/libtests/rcxx01/init.c | 2 +-
testsuites/libtests/rcxx01/thread.cpp | 21 +++-
testsuites/libtests/rcxx01/user-example-1.cpp | 49 ++++++++
testsuites/libtests/rcxx01/user-example-2.cpp | 68 +++++++++++
testsuites/libtests/rcxx01/user-example-3.cpp | 113 ++++++++++++++++++
6 files changed, 251 insertions(+), 5 deletions(-)
create mode 100644 testsuites/libtests/rcxx01/user-example-1.cpp
create mode 100644 testsuites/libtests/rcxx01/user-example-2.cpp
create mode 100644 testsuites/libtests/rcxx01/user-example-3.cpp
diff --git a/spec/build/testsuites/libtests/rcxx01.yml b/spec/build/testsuites/libtests/rcxx01.yml
index 864ad4d9d6..49bd9cff66 100644
--- a/spec/build/testsuites/libtests/rcxx01.yml
+++ b/spec/build/testsuites/libtests/rcxx01.yml
@@ -13,6 +13,9 @@ links: []
source:
- testsuites/libtests/rcxx01/init.c
- testsuites/libtests/rcxx01/thread.cpp
+- testsuites/libtests/rcxx01/user-example-1.cpp
+- testsuites/libtests/rcxx01/user-example-2.cpp
+- testsuites/libtests/rcxx01/user-example-3.cpp
stlib: []
target: testsuites/libtests/rcxx01.exe
type: build
diff --git a/testsuites/libtests/rcxx01/init.c b/testsuites/libtests/rcxx01/init.c
index 87d3155c7f..bea71d14c7 100644
--- a/testsuites/libtests/rcxx01/init.c
+++ b/testsuites/libtests/rcxx01/init.c
@@ -72,7 +72,7 @@ rtems_task Init(
#define CONFIGURE_MEMORY_OVERHEAD (2024)
#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 5
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/libtests/rcxx01/thread.cpp b/testsuites/libtests/rcxx01/thread.cpp
index 05a9de8c48..f977a340a9 100644
--- a/testsuites/libtests/rcxx01/thread.cpp
+++ b/testsuites/libtests/rcxx01/thread.cpp
@@ -36,6 +36,10 @@ using namespace std::chrono_literals;
extern "C" void rcxx_run_test(void);
+void example_1();
+void example_2();
+void example_3();
struct test_thread
test_thread();
@@ -96,13 +100,22 @@ bool test_thread::running()
return finished == false;
+void test_1()
+ test_thread tt;
+ tt.start();
+ while (tt.running())
+ std::this_thread::sleep_for(1s);
try {
- test_thread tt;
- tt.start();
- while (tt.running())
- std::this_thread::sleep_for(1s);
+ test_1();
+ /* From the user manual */
+ example_1();
+ example_2();
+ example_3();
} catch (...) {
std::cout << "Thread: ouch" << std::endl;
throw;
diff --git a/testsuites/libtests/rcxx01/user-example-1.cpp b/testsuites/libtests/rcxx01/user-example-1.cpp
new file mode 100644
index 0000000000..dfc0992193
--- /dev/null
+++ b/testsuites/libtests/rcxx01/user-example-1.cpp
@@ -0,0 +1,49 @@
+ * Copyright (C) 2020 Chris Johns (http://contemporary.software)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <chrono>
+#include <iostream>
+#include <rtems/thread.hpp>
+static void wait_for(size_t seconds)
+ while (seconds--) {
+ std::this_thread::sleep_for(std::chrono::seconds(1));
+ std::cout << "Seconds: " << seconds << std::endl;
+void example_1()
+ std::cout << "Start example 1" << std::endl;
+ rtems::thread::thread t(wait_for, 5);
+ t.join();
+ std::cout << "End example 1" << std::endl;
diff --git a/testsuites/libtests/rcxx01/user-example-2.cpp b/testsuites/libtests/rcxx01/user-example-2.cpp
index 0000000000..05090fc73c
--- /dev/null
+++ b/testsuites/libtests/rcxx01/user-example-2.cpp
@@ -0,0 +1,68 @@
+ * are met:
+#include <chrono>
+static void wait_for(std::string me, size_t seconds, size_t announce)
+ size_t count = 0;
+ while (count < seconds) {
+ if ((count % announce) == 0)
+ std::cout << me << ": " << count << std::endl;
+ count++;
+void example_2()
+ std::cout << "Start example 2" << std::endl;
+ rtems::thread::attributes attr;
+ attr.set_stack_size(16 * 1024);
+ attr.set_priority(100);
+ attr.set_name("T1");
+ rtems::thread::thread t1(attr, wait_for, "T1", 10, 1);
+ attr.set_priority(101);
+ attr.set_name("T2");
+ rtems::thread::thread t2(attr, wait_for, "T2", 10, 2);
+ attr.set_priority(attr.get_priority());
+ attr.set_name("T3");
+ rtems::thread::thread t3(attr, wait_for, "T3", 15, 3);
+ t1.join();
+ t2.join();
+ t3.join();
+ std::cout << "End example 2" << std::endl;
diff --git a/testsuites/libtests/rcxx01/user-example-3.cpp b/testsuites/libtests/rcxx01/user-example-3.cpp
index 0000000000..bdc6328bb3
--- /dev/null
+++ b/testsuites/libtests/rcxx01/user-example-3.cpp
@@ -0,0 +1,113 @@
+ * are met:
+#include <atomic>
+#include <chrono>
+#include <mutex>
+class ticker
+ public:
+ ticker(const size_t life_time);
+ void run();
+ bool finished();
+ size_t seconds();
+ private:
+ void timer();
+ rtems::thread::thread tocker;
+ std::mutex lock;
+ std::atomic<bool> done;
+ bool running;
+ const size_t life_time;
+ std::atomic<size_t> the_seconds;
+ticker::ticker(const size_t life_time)
+ : done(false),
+ running(false),
+ life_time(life_time),
+ the_seconds(0)
+void ticker::run()
+ std::lock_guard<std::mutex> guard(lock);
+ if (!running) {
+ attr.set_name("CLCK");
+ attr.set_stack_size(8 * 1024);
+ attr.set_priority(10);
+ running = true;
+ tocker = rtems::thread::thread(attr, &ticker::timer, this);
+bool ticker::finished()
+ return done.load();
+size_t ticker::seconds()
+ return the_seconds.load();
+void ticker::timer()
+ while (the_seconds.load() < life_time) {
+ the_seconds++;
+ done = true;
+ running = false;
+void example_3()
+ std::cout << "Start example 3" << std::endl;
+ ticker my_ticker(10);
+ my_ticker.run();
+ while (!my_ticker.finished()) {
+ std::this_thread::sleep_for(std::chrono::seconds(2));
+ std::cout << "Ticker is " << my_ticker.seconds() << std::endl;
+ std::cout << "End example 3" << std::endl;
2.24.1
