[PATCH 1/2] librtemsc++: Add join() and detach() to the thread
Gedare Bloom
gedare at rtems.org
Thu Oct 8 16:28:45 UTC 2020
On Thu, Oct 8, 2020 at 2:19 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Do not start threads detached
> cpukit/include/rtems/thread.hpp | 4 ++++
> cpukit/librtemscxx/thread.cpp | 22 ++++++++++++++++++----
> 2 files changed, 22 insertions(+), 4 deletions(-)
> diff --git a/cpukit/include/rtems/thread.hpp b/cpukit/include/rtems/thread.hpp
> index e90e664dfa..2c4899dc0b 100644
> --- a/cpukit/include/rtems/thread.hpp
> +++ b/cpukit/include/rtems/thread.hpp
> @@ -321,6 +321,10 @@ namespace rtems
> bool joinable() const noexcept;
> + void join() noexcept;
> + void detach() noexcept;
> * Constrain use. These are not available.
> diff --git a/cpukit/librtemscxx/thread.cpp b/cpukit/librtemscxx/thread.cpp
> index 11bf3df230..ae13201bd4 100644
> --- a/cpukit/librtemscxx/thread.cpp
> +++ b/cpukit/librtemscxx/thread.cpp
> @@ -346,6 +346,24 @@ namespace rtems
> return !(id_ == id());
> + void
> + thread::join() noexcept
> + if (!joinable())
explicit { for 1-liners is preferred
> + system_error_check (ENOMEM, "join");
In general, this file is not entirely adhering to RTEMS coding style.
What coding style is it? Sorry I missed this in the first patch(es)
adding the cxx iface
> + system_error_check (::pthread_join (id_.id_, nullptr), "join");
prefer to not have a space before the ( for function calls so that
function-like macros appear consistently
> + id_ = id();
> + void
> + thread::detach() noexcept
> + if (!joinable())
> + system_error_check (EINVAL, "detach");
> + system_error_check (::pthread_detach (id_.id_), "detach");
> + id_ = id();
> thread::state_base::~state_base () = default;
> void
> @@ -358,10 +376,6 @@ namespace rtems
> system_error_check (::pthread_attr_init (&pattr),
> "attribute init");
> - system_error_check (::pthread_attr_setdetachstate (&pattr,
> - PTHREAD_CREATE_DETACHED),
> - "set detached state");
> struct sched_param param;
> param.sched_priority = attr.get_priority ();
> system_error_check (::pthread_attr_setschedparam (&pattr, ¶m),
> 2.24.1
> devel mailing list
> devel at rtems.org
