[PATCH v2] rtems: Generate <rtems/io.h>
Peter Dufault dufault at hda.com
Thu Oct 8 18:51:07 UTC 2020
I have a minor issue with the ordering. *I haven't looked too much through earlier documents.*
I don't think this has anything to do with Sebastians work, but I think it is odd that "close" comes before directives like "I/O control" (or whatever it's called) that need to be invoked when the interface is open. If the ordering is intended to correspond to normal usage, as I think Joel said, this is wrong and "close" should be at the end.
If that's how the current documentation is structured we should stick with it and change it later.
> On Oct 8, 2020, at 02:18 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 07/10/2020 21:12, Gedare Bloom wrote:
>> On Wed, Oct 7, 2020 at 11:40 AM Sebastian Huber
>>> On 07/10/2020 17:26, Gedare Bloom wrote:
>>>> Thinking about the discussion about ordering directives in the docs,
>>>> the generated header reorders directives also. Is it also doing
>>>> generation by alphabetical order?
>>>> Should we consider using the same order as defined for the API
>>>> documentation? I guess this would make the Doxygen consistently
>>>> ordered wrt the docs.
>>> This would make things a lot more complicated. For the Doxygen we have
>>> to take also the C language into account. For example before you use a
>>> type, it must be declared. This is done through automatic dependency
>>> tracking and a topological sorting. Adding a manual order into this
>>> stuff would be difficult.
>> Yeah, maybe. The value of ordering in the headers and doxygen is
>> probably less than in a manual. We can revisit later if we like. It
>> shouldn't be too hard in an API header (as opposed to an
>> implementation header with inlines) to group first the typedefs and
>> then the function declarations. But I have no real concern about the
>> ordering here, it was just a thought.
> Good, I added a ticket for this:
> https://devel.rtems.org/ticket/4134#ticket
> It is not on my high priority list.
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201008/d97412d8/attachment.bin>
