[PATCH] testsuites/samples/fileio - Increase of stack size
Frank Kühndel frank.kuehndel at embedded-brains.de
Fri Oct 9 14:05:40 UTC 2020
Hi Joel,
Sebastian is the opinion its a "GCC 10 issue".
On 10/9/20 3:32 PM, Joel Sherrill wrote:
> This is interesting. When I teach RTEMS classes, I always run this
> application and the last time, this BSP was the one used. It was a rare
> case of all Zynq users with no LEON users. :)
> What version of RTEMS and how did you configure it?
Version is the newest, I think 6:
remote.origin.url=git://git.rtems.org/rtems.git
The branch bases on origin/master.
The preceding commit was:
commit 558a19d3adff6a3ecf678f94408b48beccbbc9fb (origin/master,
origin/HEAD, master)
The config.ini is
[arm/realview_pbx_a9_qemu]
RTEMS_DEBUG = True
RTEMS_NETWORKING = True
RTEMS_POSIX_API = True
RTEMS_SMP = True
BUILD_TESTS = True
> This sounds like it may need a ticket since it likely needs to be
> included on the 5 branch.pa <http://branch.pa>
I can open a ticket for 5 and 6 if you like.
Greetings
Frank
> I don't doubt it crashed. Just want details so we can apply the patch
> properly.
> --joel
> On Fri, Oct 9, 2020 at 8:07 AM Frank Kuehndel
> <frank.kuehndel at embedded-brains.de
> <mailto:frank.kuehndel at embedded-brains.de>> wrote:
>     When I use the 'shell' from the fileio sample with the command below:
>        env QEMU_AUDIO_DRV="none" \
>        qemu-system-arm -no-reboot -net none -nographic -M
>     realview-pbx-a9 -m 256M \
>        -kernel build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
>     The executable crashes with an "BLOWN STACK!!!" as soon as I try to
>     login
>     as 'root' with password. (The logins without password work fine.)
>     Increasing
>     the stack size of the affected thread a bit solves the issue. Hence,
>     I suggest this patch.
>      testsuites/samples/fileio/init.c | 2 +-
>      1 file changed, 1 insertion(+), 1 deletion(-)
>     diff --git a/testsuites/samples/fileio/init.c
>     b/testsuites/samples/fileio/init.c
>     index 86b34b99dd..c552d33613 100644
>     --- a/testsuites/samples/fileio/init.c
>     +++ b/testsuites/samples/fileio/init.c
>     @@ -630,7 +630,7 @@ static void fileio_start_shell(void)
>        printf(" =========================\n");
>        rtems_shell_init(
>          "SHLL",                          /* task_name */
>     -    RTEMS_MINIMUM_STACK_SIZE * 4,    /* task_stacksize */
>     +    RTEMS_MINIMUM_STACK_SIZE * 5,    /* task_stacksize */
>          100,                             /* task_priority */
>          "/dev/foobar",                   /* devname */
>          /* device is currently ignored by the shell if it is not a pty */
>     2.26.2
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org <mailto:devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/devel
