[PATCH] testsuites/samples/fileio - Increase of stack size
Kinsey Moore
kinsey.moore at oarcorp.com
Fri Oct 9 14:11:14 UTC 2020
I'm not sure it's specifically a GCC10 issue, but I've encountered something like this before (I think it was GCC8 or GCC9).
https://github.com/ISI-apex/rtems/commit/edd6d90c3ad21393dd0de93056f371c7abc89b78
I thought I'd sent in a patch for this or at least created a ticket, but I can't find either at the moment.
Kinsey
-----Original Message-----
From: devel <devel-bounces at rtems.org> On Behalf Of Frank Kühndel
Sent: Friday, October 9, 2020 09:06
To: joel at rtems.org
Cc: rtems-devel at rtems.org <devel at rtems.org>
Subject: Re: [PATCH] testsuites/samples/fileio - Increase of stack size
Hi Joel,
Sebastian is the opinion its a "GCC 10 issue".
On 10/9/20 3:32 PM, Joel Sherrill wrote:
> This is interesting. When I teach RTEMS classes, I always run this
> application and the last time, this BSP was the one used. It was a
> rare case of all Zynq users with no LEON users. :)
> What version of RTEMS and how did you configure it?
Version is the newest, I think 6:
remote.origin.url=git://git.rtems.org/rtems.git
The branch bases on origin/master.
The preceding commit was:
commit 558a19d3adff6a3ecf678f94408b48beccbbc9fb (origin/master, origin/HEAD, master)
The config.ini is
[arm/realview_pbx_a9_qemu]
RTEMS_DEBUG = True
RTEMS_NETWORKING = True
RTEMS_POSIX_API = True
RTEMS_SMP = True
BUILD_TESTS = True
> This sounds like it may need a ticket since it likely needs to be
> included on the 5 branch.pa <http://branch.pa>
I can open a ticket for 5 and 6 if you like.
Greetings
Frank
> I don't doubt it crashed. Just want details so we can apply the patch
> properly.
> --joel
> On Fri, Oct 9, 2020 at 8:07 AM Frank Kuehndel
> <frank.kuehndel at embedded-brains.de
> <mailto:frank.kuehndel at embedded-brains.de>> wrote:
> When I use the 'shell' from the fileio sample with the command below:
> env QEMU_AUDIO_DRV="none" \
> qemu-system-arm -no-reboot -net none -nographic -M
> realview-pbx-a9 -m 256M \
> -kernel
> build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
> The executable crashes with an "BLOWN STACK!!!" as soon as I try to
> login
> as 'root' with password. (The logins without password work fine.)
> Increasing
> the stack size of the affected thread a bit solves the issue. Hence,
> I suggest this patch.
> testsuites/samples/fileio/init.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/testsuites/samples/fileio/init.c
> b/testsuites/samples/fileio/init.c
> index 86b34b99dd..c552d33613 100644
> --- a/testsuites/samples/fileio/init.c
> +++ b/testsuites/samples/fileio/init.c
> @@ -630,7 +630,7 @@ static void fileio_start_shell(void)
> printf(" =========================\n");
> rtems_shell_init(
> "SHLL", /* task_name */
> - RTEMS_MINIMUM_STACK_SIZE * 4, /* task_stacksize */
> + RTEMS_MINIMUM_STACK_SIZE * 5, /* task_stacksize */
> 100, /* task_priority */
> "/dev/foobar", /* devname */
> /* device is currently ignored by the shell if it is not a pty */
> 2.26.2
> devel mailing list
> devel at rtems.org <mailto:devel at rtems.org>
devel mailing list
devel at rtems.org
