[PATCH] testsuites/samples/fileio - Increase of stack size
Joel Sherrill
joel at rtems.org
Fri Oct 9 14:14:54 UTC 2020
On Fri, Oct 9, 2020 at 9:11 AM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> I'm not sure it's specifically a GCC10 issue, but I've encountered
> something like this before (I think it was GCC8 or GCC9).
> https://github.com/ISI-apex/rtems/commit/edd6d90c3ad21393dd0de93056f371c7abc89b78
> I thought I'd sent in a patch for this or at least created a ticket, but I
> can't find either at the moment.
Would switching this BSP from -O0 to -Og be prudent also?
I assume it is using -O0 to ease debugging.
--joel
> Kinsey
> -----Original Message-----
> From: devel <devel-bounces at rtems.org> On Behalf Of Frank Kühndel
> Sent: Friday, October 9, 2020 09:06
> To: joel at rtems.org
> Cc: rtems-devel at rtems.org <devel at rtems.org>
> Subject: Re: [PATCH] testsuites/samples/fileio - Increase of stack size
> Hi Joel,
> Sebastian is the opinion its a "GCC 10 issue".
> On 10/9/20 3:32 PM, Joel Sherrill wrote:
> > This is interesting. When I teach RTEMS classes, I always run this
> > application and the last time, this BSP was the one used. It was a
> > rare case of all Zynq users with no LEON users. :)
> > What version of RTEMS and how did you configure it?
> Version is the newest, I think 6:
> remote.origin.url=git://git.rtems.org/rtems.git
> The branch bases on origin/master.
> The preceding commit was:
> commit 558a19d3adff6a3ecf678f94408b48beccbbc9fb (origin/master,
> origin/HEAD, master)
> The config.ini is
> [arm/realview_pbx_a9_qemu]
> RTEMS_DEBUG = True
> RTEMS_NETWORKING = True
> RTEMS_POSIX_API = True
> RTEMS_SMP = True
> BUILD_TESTS = True
> > This sounds like it may need a ticket since it likely needs to be
> > included on the 5 branch.pa <http://branch.pa>
> I can open a ticket for 5 and 6 if you like.
> Greetings
> Frank
> > I don't doubt it crashed. Just want details so we can apply the patch
> > properly.
> > --joel
> > On Fri, Oct 9, 2020 at 8:07 AM Frank Kuehndel
> > <frank.kuehndel at embedded-brains.de
> > <mailto:frank.kuehndel at embedded-brains.de>> wrote:
> > When I use the 'shell' from the fileio sample with the command below:
> > env QEMU_AUDIO_DRV="none" \
> > qemu-system-arm -no-reboot -net none -nographic -M
> > realview-pbx-a9 -m 256M \
> > -kernel
> > build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
> > The executable crashes with an "BLOWN STACK!!!" as soon as I try to
> > login
> > as 'root' with password. (The logins without password work fine.)
> > Increasing
> > the stack size of the affected thread a bit solves the issue. Hence,
> > I suggest this patch.
> > testsuites/samples/fileio/init.c | 2 +-
> > 1 file changed, 1 insertion(+), 1 deletion(-)
> > diff --git a/testsuites/samples/fileio/init.c
> > b/testsuites/samples/fileio/init.c
> > index 86b34b99dd..c552d33613 100644
> > --- a/testsuites/samples/fileio/init.c
> > +++ b/testsuites/samples/fileio/init.c
> > @@ -630,7 +630,7 @@ static void fileio_start_shell(void)
> > printf(" =========================\n");
> > rtems_shell_init(
> > "SHLL", /* task_name */
> > - RTEMS_MINIMUM_STACK_SIZE * 4, /* task_stacksize */
> > + RTEMS_MINIMUM_STACK_SIZE * 5, /* task_stacksize */
> > 100, /* task_priority */
> > "/dev/foobar", /* devname */
> > /* device is currently ignored by the shell if it is not a pty
> > 2.26.2
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201009/ffd3d348/attachment-0001.html>
