waf for RTEMS Applications
Fri Oct 9 22:26:31 UTC 2020
Hi
I decided to try this out today. The users manual is pretty good but has
some spots which lean to 5 and haven't been updated. Also mentions updating
your PATH early and isn't really needed until rtems-run can't find qemu. :)
My big questions are from this exercise are:
+ How would one use this without using git
+ Without using git submodules?
+ What if I didn't want any external network references? I don't see waf or
rtems_waf in the release image.
+ rtems-run's output seemed cryptic when it couldn't find the simulator to
run.
It was easy enough after accounting for odd 5/6 items, misc issues that are
OK for me to encounter but not a starting user, and the example worked. I
am just putting on my user hat as best I can to comment on the process.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201009/d91614b1/attachment.html>
