aarch64/a53_ilp32_qemu: implicit declaration of function 'truncl'
Sat Oct 10 16:24:49 UTC 2020
On Sat, Oct 10, 2020 at 8:13 AM Sebastian Huber <
> On 10/10/2020 15:11, Sebastian Huber wrote:
> > Hello Kinsey,
> > the new aarch64/a53_ilp32_qemu produces a lot of warnings like this:
> > ../../../testsuites/psxtests/psxhdrs/math/truncl.c:45:12: warning:
> > [-Wimplicit-function-declaration]
> > incompatible implicit declaration of built-in function 'truncl'
> > Is this a known issue?
It is likely that this is because some/many architectures do not
have long double support in newlib. Or have a true long double
type. This will require a newlib discussion.
> There is also this warning:
> cpukit/libmisc/stackchk/check.c:455:5: warning: cast to pointer from
> integer of different size [-Wint-to-pointer-cast]
> This is probably an error. Could you please fix the warnings specific to
> the new BSPs.
This looks like code being sloppy that isn't the fault of this BSP. It is
just one where sizeof(int) != sizeof(void *).
Kinsey.. likely solution is to replace the cast/type with intptr_t or
uintptr_t.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201010/fd9252a8/attachment-0001.html>
