Fwd: Build fail on debian - Toolset build error
Andrew Butterfield Andrew.Butterfield at scss.tcd.ie
Mon Oct 12 10:17:04 UTC 2020
Dear all,
I am having a problem building RTEMs master, on OS X Mojave - see below
> Begin forwarded message:
> From: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Subject: Re: Build fail on debian - Toolset build error
> Date: 12 October 2020 at 10:48:17 IST
> To: Andrew Butterfield <Andrew.Butterfield at scss.tcd.ie>
> Hello Andrew,
> could you please forward this e-mail to devel at rtems.org.
> On 12/10/2020 11:45, Andrew Butterfield wrote:
>> Hi Sebastian,
>>  I get a python error - despite using the virtual environment,
>> which maps `python` to the OS X \System installation of python 3.8
>> It complains about python2 being unusable - see tail of report below...
>> My command-line tools and Xcode are up-to-date. Now this is on a Mojave machine, which is
>> one that is not listed in the User Manual where OS X is discussed.
>> I'll try to do this on my laptop which is now Catalina
>> Regards, Andrew
>> tail of error report follows:
>> checking for library containing socketpair... none required
>> checking for ld used by GCC... /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld
>> checking if the linker (/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld) is GNU ld... no
>> checking for shared library run path origin... done
>> checking for iconv... yes
>> checking how to link with libiconv... -liconv
>> checking for iconv declaration...
>>          extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
>> checking for library containing waddstr... -lncurses
>> checking for library containing tgetent... none required
>> checking size of unsigned long long... 8
>> checking size of unsigned long... 8
>> checking size of unsigned __int128... 16
>> checking for library containing dlopen... none required
>> checking whether to use expat... yes
>> checking for libexpat... yes
>> checking how to link with libexpat... -lexpat
>> checking for XML_StopParser... yes
>> checking whether to use MPFR... auto
>> checking for libmpfr... no
>> configure: WARNING: MPFR is missing or unusable; some features may be unavailable.
>> checking whether to use python... /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
>> checking for python... no
>> configure: error: no usable python found at /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
>> make[1]: *** [configure-gdb] Error 1
>> make: *** [all] Error 2
>> shell cmd failed: /bin/sh -ex  /Users/butrfeld/REPOS/rtems-smp-qualification-qual/modules/rsb/rtems/build/sparc-rtems6-gdb-0295dde-x86_64-apple-darwin18.7.0-1/do-build
>> error: building sparc-rtems6-gdb-0295dde-x86_64-apple-darwin18.7.0-1
>>> On 12 Oct 2020, at 09:19, Sebastian Huber <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>> On 12/10/2020 10:14, Andrew Butterfield wrote:
>>>> Is there any point me trying to build on my OS X machine, or will I just get the same error?
>>> It is unlikely that you get the same error. This seems to be a Debian specific issue.
>> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
>> Lero at TCD, Head of Software Foundations & Verification Research Group
>> School of Computer Science and Statistics,
>> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>> http://www.scss.tcd.ie/Andrew.Butterfield/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201012/44910ebf/attachment.html>
