[rtems commit] libblock: Fix string truncation warning
Joel Sherrill
joel at rtems.org
Sat Oct 10 23:47:17 UTC 2020
On Sat, Oct 10, 2020, 8:16 AM Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: bc7ac71f8aaaff0c73469246c526741ec5b181ed
> Changeset:
> http://git.rtems.org/rtems/commit/?id=bc7ac71f8aaaff0c73469246c526741ec5b181ed
> Author: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> Date: Mon Oct 5 16:37:23 2020 +0200
> This patch does not only fix the compiler warning below. memcpy() is the
> better function at this place as the terminating NUL character is never
> copied here. Instead more characters will be appended to the
> 'logical_disk_name' later on.
> ../../../cpukit/libblock/src/bdpart-register.c:41:5:
> warning: 'strncpy' output truncated before terminating nul copying
> as many bytes from a string as its length [-Wstringop-truncation]
> cpukit/libblock/src/bdpart-register.c | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libblock/src/bdpart-register.c
> b/cpukit/libblock/src/bdpart-register.c
> index 9956e61..8a1de61 100644
> --- a/cpukit/libblock/src/bdpart-register.c
> +++ b/cpukit/libblock/src/bdpart-register.c
> @@ -38,7 +38,7 @@ static char *create_logical_disk_name( const char
> *disk_name, char **marker)
> char *logical_disk_name = malloc( disk_name_size +
> RTEMS_BDPART_NUMBER_SIZE);
> if (logical_disk_name != NULL) {
> - strncpy( logical_disk_name, disk_name, disk_name_size);
> + memcpy( logical_disk_name, disk_name, disk_name_size);
Could we have a comment in the code explaining why this is safe?
Please do that for everywhere memcpy is being inserted. Next time someone
looks at this code, it will not be obvious.
*marker = logical_disk_name + disk_name_size;
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201010/9bb4a6cc/attachment.html>
