[PATCH v2] testsuites/samples/fileio - Increase of stack size
Frank Kuehndel frank.kuehndel at embedded-brains.de
Mon Oct 12 13:49:07 UTC 2020
From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
When I use the 'shell' from the fileio sample with the command below:
   env QEMU_AUDIO_DRV="none" \
   qemu-system-arm -no-reboot -net none -nographic -M realview-pbx-a9 \
   -m 256M \
   -kernel build/arm/realview_pbx_a9_qemu/testsuites/samples/fileio.exe
The executable crashes with an "BLOWN STACK!!!" as soon as I try to login
as 'root' with password. (The logins without password work fine.)
Increasing the stack size of the affected thread a bit solves the issue.
Hence, I suggest this patch.
 My config.ini was
[arm/realview_pbx_a9_qemu]
RTEMS_DEBUG = True
RTEMS_NETWORKING = True
RTEMS_POSIX_API = True
RTEMS_SMP = True
BUILD_TESTS = True
RTEMS origin.master at a479686c112144119866391ceb21c48be6a3eca9
Close #4143
 testsuites/samples/fileio/init.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/testsuites/samples/fileio/init.c b/testsuites/samples/fileio/init.c
index 86b34b99dd..c552d33613 100644
--- a/testsuites/samples/fileio/init.c
+++ b/testsuites/samples/fileio/init.c
@@ -630,7 +630,7 @@ static void fileio_start_shell(void)
   printf(" =========================\n");
   rtems_shell_init(
     "SHLL",                          /* task_name */
-    RTEMS_MINIMUM_STACK_SIZE * 4,    /* task_stacksize */
+    RTEMS_MINIMUM_STACK_SIZE * 5,    /* task_stacksize */
     100,                             /* task_priority */
     "/dev/foobar",                   /* devname */
     /* device is currently ignored by the shell if it is not a pty */
2.26.2
