On Master All GDB Builds Fail on Cygwin
Tue Oct 13 23:37:29 UTC 2020
On 14/10/20 9:42 am, Joel Sherrill wrote:
> Finally got an answer from Corinna and she said to report this to gdb. But when
> I went to repeat it, it builds now.
Weird. Was Cygwin updated?
> Unfortunately, the source builder ended with this on Cygwin. A Linux VM on the
> same physical computer doesn't have trouble sending to build at . I do have a VPN
> up which is not always on.
> Build Sizes: usage: 4.963GB total: 1.691GB (sources: 397.768MB, patches:
> 20.153KB, installed 1.302GB)
> Mailing report: build at rtems.org <mailto:build at rtems.org>
> Mail Send Failure: error: sending mail: [Errno 111] Connection refused
> Build Set: Time 1:49:57.656442
> Any ideas? Nothing else is in the log.
Firewall?
> What's the best way to send test mail from Cygwin?
This should work. I suspect it is something local to you.
