On Master All GDB Builds Fail on Cygwin
Wed Oct 14 00:45:34 UTC 2020
On Tue, Oct 13, 2020, 6:37 PM Chris Johns <chrisj at rtems.org> wrote:
> On 14/10/20 9:42 am, Joel Sherrill wrote:
> > Finally got an answer from Corinna and she said to report this to gdb.
> But when
> > I went to repeat it, it builds now.
> Weird. Was Cygwin updated?
No. Sebastian bumped the head of gdb.
> > Unfortunately, the source builder ended with this on Cygwin. A Linux VM
> on the
> > same physical computer doesn't have trouble sending to build at . I do
> have a VPN
> > up which is not always on.
> > Build Sizes: usage: 4.963GB total: 1.691GB (sources: 397.768MB, patches:
> > 20.153KB, installed 1.302GB)
> > Mailing report: build at rtems.org <mailto:build at rtems.org>
> > Mail Send Failure: error: sending mail: [Errno 111] Connection refused
> > Build Set: Time 1:49:57.656442
> > Any ideas? Nothing else is in the log.
> Firewall?
> > What's the best way to send test mail from Cygwin?
> This should work. I suspect it is something local to you.
Weird it would just impact Cygwin and not the VM. I didn't have mail or
mailx installed to test with. Is there a direct Python way to try with the
tools?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201013/5d6da178/attachment.html>
