Fwd: [rtems-bsp-builder] 2020-10-13 09:15:22: Profile(s): everything
    Joel Sherrill
    joel at rtems.org
    Wed Oct 14 15:17:43 UTC 2020
On Wed, Oct 14, 2020 at 9:45 AM Sebastian Huber <
> On 14/10/2020 15:35, Joel Sherrill wrote:
> > BSP builder has 81 failures. :(
> It tried to build BSPs which no longer exist.
Well that is an easier thing to fix than my concern that it was related to
giving errors when a BSP does not support a feature. I suppose that will
show up when the bsp builder switches to waf.
Can you patch ./config/rtems-bsps-tiers.ini to reflect what you removed?
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201014/83ca6e72/attachment.html>
