Fwd: [rtems-bsp-builder] 2020-10-13 09:15:22: Profile(s): everything
Wed Oct 14 15:20:27 UTC 2020
On 14/10/2020 17:17, Joel Sherrill wrote:
> On Wed, Oct 14, 2020 at 9:45 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 14/10/2020 15:35, Joel Sherrill wrote:
>     > BSP builder has 81 failures. :(
>     It tried to build BSPs which no longer exist.
> Well that is an easier thing to fix than my concern that it was related to
> giving errors when a BSP does not support a feature. I suppose that will
> show up when the bsp builder switches to waf.
> Can you patch ./config/rtems-bsps-tiers.ini to reflect what you removed?
We should try try to reduce the redundancy in our data sets. Why don't
we record the tier status in the BSP items?
