Uncrustify
Chris Johns
chrisj at rtems.org
Wed Oct 14 23:03:35 UTC 2020
On 15/10/20 5:04 am, Joel Sherrill wrote:
> On Wed, Oct 14, 2020 at 12:11 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedded-brains.de>>
> wrote:
> Hello,
> I tried to write a configuration file for Uncrustify which is close to
> the RTEMS coding style. This tool has really a lot of options. The
> configuration file has more than 3000 lines. Apparently this is not
> enough. I was not able to get function parameters properly aligned. For
> example:
> - Thread_queue_Context queue_context;
> - Thread_Control *the_thread;
> + Thread_queue_Context queue_context;
> + Thread_Control *the_thread;
> It seems Uncrustify interprets the '*' as some sort of white space.
> Attached is my current configuration file. You can test it for example
> with cpukit/score/src/threadqenqueue.c.
> I'm not a huge fan of moving the * to after the type rather than against
> the name but if we accepted that change to the style, would the parameter
> names line up?
I understand the history with multiple variable declarations per line but to me
the type with the modifier grouped together reads better. In C++ I prefer that
style because there are more type modifiers such as reference and the reference
and address-of is the same character. For example a randomly selected API ...
https://en.cppreference.com/w/cpp/container/vector/vector
... and
vector& operator=( const vector& other );
I had never noticed the C style until I used C++ heavily many years ago.
