Fwd: [rtems-bsp-builder] 2020-10-13 09:15:22: Profile(s): everything
Thu Oct 15 06:41:34 UTC 2020
On 15/10/20 5:34 pm, Sebastian Huber wrote:
> On 15/10/2020 08:30, Chris Johns wrote:
>> On 15/10/20 5:26 pm, Sebastian Huber wrote:
>>> On 15/10/2020 08:23, Chris Johns wrote:
>>>> On 15/10/20 5:15 pm, Sebastian Huber wrote:
>>>>> On 15/10/2020 08:05, Chris Johns wrote:
>>>>>> On 15/10/20 4:35 pm, Sebastian Huber wrote:
>>>>>>> On 15/10/2020 00:48, Chris Johns wrote:
>>>>>>>> On 15/10/20 2:27 am, Joel Sherrill wrote:
>>>>>>>>> On Wed, Oct 14, 2020 at 10:20 AM Sebastian Huber
>>>>>>>>> <sebastian.huber at embedded-brains.de
>>>>>>>>> <mailto:sebastian.huber at embedded-brains.de>>
>>>>>>>>> wrote:
>>>>>>>>>         On 14/10/2020 17:17, Joel Sherrill wrote:
>>>>>>>>>         > On Wed, Oct 14, 2020 at 9:45 AM Sebastian Huber
>>>>>>>>>         > <sebastian.huber at embedded-brains.de
>>>>>>>>>         > <mailto:sebastian.huber at embedded-brains.de
>>>>>>>>>         <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>>>>>>>>         >     On 14/10/2020 15:35, Joel Sherrill wrote:
>>>>>>>>>         >     > BSP builder has 81 failures. :(
>>>>>>>>>         >     It tried to build BSPs which no longer exist.
>>>>>>>>>         > Well that is an easier thing to fix than my concern that it was
>>>>>>>>> related to
>>>>>>>>>         > giving errors when a BSP does not support a feature. I
>>>>>>>>> suppose that
>>>>>>>>> will
>>>>>>>>>         > show up when the bsp builder switches to waf.
>>>>>>>>>         > Can you patch ./config/rtems-bsps-tiers.ini to reflect what you
>>>>>>>>> removed?
>>>>>>>>>         We should try try to reduce the redundancy in our data sets. Why
>>>>>>>>> don't
>>>>>>>>>         we record the tier status in the BSP items?
>>>>>>>>> That's a Chris discussion when the builder is switched to using waf.
>>>>>>>> The current data is in rtems-tools.git/config. I needed a spot and could
>>>>>>>> not
>>>>>>>> think of another place that was easy and low impact. I would welcome
>>>>>>>> alternatives. If this data can be generated and updated or runtime loaded
>>>>>>>> from
>>>>>>>> another source, ie spec files, I would welcome this.
>>>>>>>> The current blocker with the spec files is being able to use some shared
>>>>>>>> code to
>>>>>>>> parse and load the YAML data plus being able to load the data quickly. Waf
>>>>>>>> has
>>>>>>>> the loading code in the wscript file so that cannot be easily shared and it
>>>>>>>> uses
>>>>>>>> saved pickled data which I do not think is shareable.
>>>>>>> We have a couple of options to re-use the build specification items. In
>>>>>>> general,
>>>>>>> the Python module to work with these items outside the wscript is in
>>>>>>> rtems-central:
>>>>>>> https://git.rtems.org/rtems-central/tree/rtemsspec/items.py
>>>>>> How long does this code take to load the build spec files in rtems.git?
>>>>> It uses an item cache in pickle format. If you start with an empty cache it
>>>>> needs a couple of seconds. Once the cache is set up it loads in less than
>>>>> half a
>>>>> second.
>>>> Oh nice, that functionality is part of this code? I had (incorrectly it seems)
>>>> assumed the dependency checking was being done by waf.
>>> The wscript uses one pickle file for the complete build specification. The
>>> rtemsspec/item uses one pickle file per directory. This allows faster updates if
>>> you just modify just one file of the specification.
>> Could the module be exported or published from rtems-central into rtems-tools to
>> it can used? Placing it into rtemstoolkit/rtemsspec/items.py to rtems-tools and
>> the tool kit can use it?
> Yes, but it is written in Python 3.6.
Ah ... but waf is python 2 and 3?
