Fwd: [rtems-bsp-builder] 2020-10-13 09:15:22: Profile(s): everything
Sebastian Huber
Thu Oct 15 06:43:57 UTC 2020
On 15/10/2020 08:41, Chris Johns wrote:
> On 15/10/20 5:34 pm, Sebastian Huber wrote:
>> On 15/10/2020 08:30, Chris Johns wrote:
>>> On 15/10/20 5:26 pm, Sebastian Huber wrote:
>>>> On 15/10/2020 08:23, Chris Johns wrote:
>>>>> On 15/10/20 5:15 pm, Sebastian Huber wrote:
>>>>>> On 15/10/2020 08:05, Chris Johns wrote:
>>>>>>> On 15/10/20 4:35 pm, Sebastian Huber wrote:
>>>>>>>> On 15/10/2020 00:48, Chris Johns wrote:
>>>>>>>>> On 15/10/20 2:27 am, Joel Sherrill wrote:
>>>>>>>>>> On Wed, Oct 14, 2020 at 10:20 AM Sebastian Huber
>>>>>>>>>> <sebastian.huber at embedded-brains.de
>>>>>>>>>> <mailto:sebastian.huber at embedded-brains.de>>
>>>>>>>>>> wrote:
>>>>>>>>>> On 14/10/2020 17:17, Joel Sherrill wrote:
>>>>>>>>>> > On Wed, Oct 14, 2020 at 9:45 AM Sebastian Huber
>>>>>>>>>> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>>>>>>>>> > On 14/10/2020 15:35, Joel Sherrill wrote:
>>>>>>>>>> > > BSP builder has 81 failures. :(
>>>>>>>>>> > It tried to build BSPs which no longer exist.
>>>>>>>>>> > Well that is an easier thing to fix than my concern that it was
>>>>>>>>>> related to
>>>>>>>>>> > giving errors when a BSP does not support a feature. I
>>>>>>>>>> suppose that
>>>>>>>>>> will
>>>>>>>>>> > show up when the bsp builder switches to waf.
>>>>>>>>>> > Can you patch ./config/rtems-bsps-tiers.ini to reflect what you
>>>>>>>>>> removed?
>>>>>>>>>> We should try try to reduce the redundancy in our data sets. Why
>>>>>>>>>> don't
>>>>>>>>>> we record the tier status in the BSP items?
>>>>>>>>>> That's a Chris discussion when the builder is switched to using waf.
>>>>>>>>> The current data is in rtems-tools.git/config. I needed a spot and could
>>>>>>>>> not
>>>>>>>>> think of another place that was easy and low impact. I would welcome
>>>>>>>>> alternatives. If this data can be generated and updated or runtime loaded
>>>>>>>>> from
>>>>>>>>> another source, ie spec files, I would welcome this.
>>>>>>>>> The current blocker with the spec files is being able to use some shared
>>>>>>>>> code to
>>>>>>>>> parse and load the YAML data plus being able to load the data quickly. Waf
>>>>>>>>> has
>>>>>>>>> the loading code in the wscript file so that cannot be easily shared and it
>>>>>>>>> uses
>>>>>>>>> saved pickled data which I do not think is shareable.
>>>>>>>> We have a couple of options to re-use the build specification items. In
>>>>>>>> general,
>>>>>>>> the Python module to work with these items outside the wscript is in
>>>>>>>> rtems-central:
>>>>>>>> https://git.rtems.org/rtems-central/tree/rtemsspec/items.py
>>>>>>> How long does this code take to load the build spec files in rtems.git?
>>>>>> It uses an item cache in pickle format. If you start with an empty cache it
>>>>>> needs a couple of seconds. Once the cache is set up it loads in less than
>>>>>> half a
>>>>>> second.
>>>>> Oh nice, that functionality is part of this code? I had (incorrectly it seems)
>>>>> assumed the dependency checking was being done by waf.
>>>> The wscript uses one pickle file for the complete build specification. The
>>>> rtemsspec/item uses one pickle file per directory. This allows faster updates if
>>>> you just modify just one file of the specification.
>>> Could the module be exported or published from rtems-central into rtems-tools to
>>> it can used? Placing it into rtemstoolkit/rtemsspec/items.py to rtems-tools and
>>> the tool kit can use it?
>> Yes, but it is written in Python 3.6.
> Ah ... but waf is python 2 and 3?
Yes, waf works with Python 2 and 3.
