Fwd: [rtems-bsp-builder] 2020-10-13 09:15:22: Profile(s): everything
Thu Oct 15 06:45:47 UTC 2020
On 15/10/20 5:43 pm, Sebastian Huber wrote:
> On 15/10/2020 08:41, Chris Johns wrote:
>> On 15/10/20 5:34 pm, Sebastian Huber wrote:
>>> On 15/10/2020 08:30, Chris Johns wrote:
>>>> On 15/10/20 5:26 pm, Sebastian Huber wrote:
>>>>> On 15/10/2020 08:23, Chris Johns wrote:
>>>>>> On 15/10/20 5:15 pm, Sebastian Huber wrote:
>>>>>>> On 15/10/2020 08:05, Chris Johns wrote:
>>>>>>>> On 15/10/20 4:35 pm, Sebastian Huber wrote:
>>>>>>>>> On 15/10/2020 00:48, Chris Johns wrote:
>>>>>>>>>> On 15/10/20 2:27 am, Joel Sherrill wrote:
>>>>>>>>>>> On Wed, Oct 14, 2020 at 10:20 AM Sebastian Huber
>>>>>>>>>>> <sebastian.huber at embedded-brains.de
>>>>>>>>>>> <mailto:sebastian.huber at embedded-brains.de>>
>>>>>>>>>>> wrote:
>>>>>>>>>>>          On 14/10/2020 17:17, Joel Sherrill wrote:
>>>>>>>>>>>          > On Wed, Oct 14, 2020 at 9:45 AM Sebastian Huber
>>>>>>>>>>>          > <sebastian.huber at embedded-brains.de
>>>>>>>>>>>          > <mailto:sebastian.huber at embedded-brains.de
>>>>>>>>>>>          <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>>>>>>>>>>          >     On 14/10/2020 15:35, Joel Sherrill wrote:
>>>>>>>>>>>          >     > BSP builder has 81 failures. :(
>>>>>>>>>>>          >     It tried to build BSPs which no longer exist.
>>>>>>>>>>>          > Well that is an easier thing to fix than my concern that
>>>>>>>>>>> it was
>>>>>>>>>>> related to
>>>>>>>>>>>          > giving errors when a BSP does not support a feature. I
>>>>>>>>>>> suppose that
>>>>>>>>>>> will
>>>>>>>>>>>          > show up when the bsp builder switches to waf.
>>>>>>>>>>>          > Can you patch ./config/rtems-bsps-tiers.ini to reflect
>>>>>>>>>>> what you
>>>>>>>>>>> removed?
>>>>>>>>>>>          We should try try to reduce the redundancy in our data sets.
>>>>>>>>>>> Why
>>>>>>>>>>> don't
>>>>>>>>>>>          we record the tier status in the BSP items?
>>>>>>>>>>> That's a Chris discussion when the builder is switched to using waf.
>>>>>>>>>> The current data is in rtems-tools.git/config. I needed a spot and could
>>>>>>>>>> not
>>>>>>>>>> think of another place that was easy and low impact. I would welcome
>>>>>>>>>> alternatives. If this data can be generated and updated or runtime loaded
>>>>>>>>>> from
>>>>>>>>>> another source, ie spec files, I would welcome this.
>>>>>>>>>> The current blocker with the spec files is being able to use some shared
>>>>>>>>>> code to
>>>>>>>>>> parse and load the YAML data plus being able to load the data quickly.
>>>>>>>>>> Waf
>>>>>>>>>> has
>>>>>>>>>> the loading code in the wscript file so that cannot be easily shared
>>>>>>>>>> and it
>>>>>>>>>> uses
>>>>>>>>>> saved pickled data which I do not think is shareable.
>>>>>>>>> We have a couple of options to re-use the build specification items. In
>>>>>>>>> general,
>>>>>>>>> the Python module to work with these items outside the wscript is in
>>>>>>>>> rtems-central:
>>>>>>>>> https://git.rtems.org/rtems-central/tree/rtemsspec/items.py
>>>>>>>> How long does this code take to load the build spec files in rtems.git?
>>>>>>> It uses an item cache in pickle format. If you start with an empty cache it
>>>>>>> needs a couple of seconds. Once the cache is set up it loads in less than
>>>>>>> half a
>>>>>>> second.
>>>>>> Oh nice, that functionality is part of this code? I had (incorrectly it
>>>>>> seems)
>>>>>> assumed the dependency checking was being done by waf.
>>>>> The wscript uses one pickle file for the complete build specification. The
>>>>> rtemsspec/item uses one pickle file per directory. This allows faster
>>>>> updates if
>>>>> you just modify just one file of the specification.
>>>> Could the module be exported or published from rtems-central into
>>>> rtems-tools to
>>>> it can used? Placing it into rtemstoolkit/rtemsspec/items.py to rtems-tools and
>>>> the tool kit can use it?
>>> Yes, but it is written in Python 3.6.
>> Ah ... but waf is python 2 and 3?
> Yes, waf works with Python 2 and 3.
... and it can load the spec files?
