RTEMS 5.1 pc686 BSP malloc_info problem?
Chris Johns
chrisj at rtems.org
Thu Oct 15 19:03:34 UTC 2020
On 16/10/20 5:22 am, Alan Cudmore wrote:
> On Thu, Oct 15, 2020 at 11:19 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Oct 15, 2020 at 6:35 AM Joel Sherrill <joel at rtems.org> wrote:
>>> On Thu, Oct 15, 2020, 7:15 AM Alan Cudmore <alan.cudmore at gmail.com> wrote:
>>>> Thanks for all of the help, and thanks for the patch Chris! I was
>>>> hoping to submit a patch this weekend, so you just gave me back some
>>>> time :)
>>> Glad you found this!
>>> The RFS was new in 4.10 as I recall. You guys have missions using this. Do you need to locally fix this?
> We have one active mission that uses it. I will be worth trying to
> determine what word of memory is affected before trying to fix it,
> since it has been operating normally for 5.5 years with the issue.
The number of bits needs to align to a value that fits the whole 32 bit mask so
the last is used to trigger the bug.
